PHOTONIC
Silicon Photodiode, U.V. Enhanced Photoconductive
Type PDU-C102
DETECTORS INC.
PACKAGE DIMENSIONS INCH [mm]
WINDOW CAP
(WELDED)
Ø0.184[4.67]
0.150[3.81]
0.040[1.02]
Ø0.155[3.94]
0.060[1.52]
WIRE
BONDS
CL
0.500
[12.70]
MIN
45°
CL
Ø0.210[5.33]
PHOTODIODE
CL
0.100[2.54]
CL
72°
VIEWING
ANGLE
0.042
[1.06]
ANODE
Ø0.018[0.46]
HEADER
CATHODE
Ø0.018[0.46]
0.053[1.35] SQUARE
0.030[0.76] ACTIVE AREA
TO-46 HERMETIC CAN PACKAGE
0.045[1.14] ACTIVE AREA
ACTIVE AREA = .87 mm2
DESCRIPTION
The PDU-C102 is a silicon, PIN planar
diffused, U.V. enhanced photodiode. Ideal
for high speed photoconductive applications.
Packaged in a hermetic TO-46 metal can
with a U.V. transmitting window.
-40
+125
O
TS
Soldering Temperature*
+240
O
IL
Light Current
C
C
mA
0.3
0.2
0.1
*1/16 inch from case for 3 secs max
WAVELENGTH (nm)
ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted)
SYMBOL CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
ISC
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, V R = 5V
Shunt Resistance
H = 0, V R = 10 mV
TC RSH
RSH Temp. Coefficient
CJ
Junction Capacitance
RSH
λrange
R
VBR
NEP
tr
1200
Operating Temperature Range
1100
TO
C
900
O
1000
+150
800
-55
0.4
700
Storage Temperature
00
=1
QE
0.5
600
TSTG
500
V
500
30
0.6
400
Reverse Voltage
0.7
300
VBR
SPECTRAL RESPONSE
190
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
APPLICATIONS
Spectrometers
Fluorescent analysers
U.V. meters
Colorimeters
RESPONSIVITY (A/W)
FEATURES
High speed
U.V. enhanced
Low capacitance
U.V. window
8.5
MAX
UNITS
mA
9
45
150
pA
1
GΩ
H = 0, V R = 10 mV
-8
% / oC
H = 0, V R = 5 V**
10
pF
Spectral Application Range Spot Scan
.25
190
1100
nm
Responsivity
VR = 0 V, l = 254 nm
.12
.18
A/W
Breakdown Voltage
I = 10 m A
15
25
V
-14
Noise Equivalent Power
VR = 10 mV @ Peak
5x10
Response Time
RL = 1 KΩ VR = 5 V
40
W/
Hz
nS
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice. **f = 1 MHz
[FORM NO. 100-PDU-C102 REV N/C]
很抱歉,暂时无法提供与“PDU-C102”相匹配的价格&库存,您可以联系我们找货
