PDU-C105Q
PDU-C105Q
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE UV 4.48MM SQ TO-5
PDU-C105Q 数据手册
PHOTONIC Silicon Photodiode, U.V. Enhanced Photoconductive Type PDU-C105-Q DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] QUARTZ WINDOW CAP (WELDED) 0.030 [0.76] Ø0.325 [8.25] Ø0.250 [6.35] CL 0.168 [4.26] 0.075 [1.91] WIRE BONDS 0.500 [12.70] MIN 45° Ø0.358 [9.09] CL 78° VIEWING ANGLE CL 0.200 [5.08] 0.035 [0.89] CL ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] HEADER PHOTODIODE 0.095 [2.41] SQ 0.086 [2.18] SQ ACTIVE AREA TO-5 CAN PACKAGE ACTIVE AREA = 4.48 mm2 500 C mA 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 5 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange R V BR NEP tr 1200 Light Current O 0.2 1100 IL +240 C 900 Soldering Temperature* +125 0.3 1000 TS -40 O C 800 Operating Temperature Range O 0% 700 TO +150 0 =1 QE 0.4 600 -55 0.5 500 Storage Temperature V 0.6 400 30 0.7 300 TSTG Reverse Voltage SPECTRAL RESPONSE 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS V BR APPLICATIONS Spectrometers Fluorescent analysers U.V. meters Colorimeters DESCRIPTION The PDU-C105-Q is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a TO-5 metal can with a flat quartz window. RESPONSIVITY (A/W) FEATURES High speed U.V. enhanced Low capacitance Quartz window 40 MAX UNITS mA 56 1.0 5.0 nA 1.0 GΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 5 V** 37 pF Spectral Application Range Spot Scan .25 190 1100 Responsivity VR = 0 V, l = 254 nm .12 .18 Breakdown Voltage I = 10 m A 15 25 Noise Equivalent Power VR = 10 mV @ Peak Response Time RL = 1 KΩ VR = 5 V A/W V -14 1.3x10 50 nm W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz [FORM NO. 100-PDU-C105-Q REV N/C]
PDU-C105Q 价格&库存
很抱歉,暂时无法提供与“PDU-C105Q”相匹配的价格&库存,您可以联系我们找货
