PDU-C101
PDU-C101
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2,金属罐
    PHOTODIODE UV 0.31MM SQ TO-46
PDU-C101 数据手册
PHOTONIC Silicon Photodiode, U.V. Enhanced Photoconductive Type PDU-C101 DETECTORS INC. PACKAGE DIMENSIONS inch [mm] WINDOW CAP (WELDED) Ø0.184[4.67] 0.150[3.81] 0.040[1.02] Ø0.155[3.94] 0.060[1.52] WIRE BONDS CL 0.500 [12.70] MIN 45° C L Ø0.210[5.33] CL 0.100[2.54] CL 74° VIEWING ANGLE 0.042 [1.06] ANODE Ø0.018[0.46] HEADER PHOTODIODE CATHODE & CASE Ø0.018[0.46] 0.053[1.35] SQUARE Ø0.0247[Ø0.627] ACTIVE AREA TO-46 HERMETIC CAN PACKAGE ACTIVE AREA = 0.31 mm2 DESCRIPTION The PDU-C101 is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a hermetic TO-46 metal can with a U.V. transmitting window. Operating Temperature Range -40 +125 O TS Soldering Temperature* +240 O IL Light Current 500 C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max 1200 TO C 1100 O 900 +150 1000 -55 0% 800 Storage Temperature 0 =1 QE 0.4 700 TSTG 0.5 600 V 500 30 0.6 400 Reverse Voltage 0.7 300 VBR SPECTRAL RESPONSE 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Spectrometers Fluorescent analysers U.V. meters Colorimeters RESPONSIVITY (A/W) FEATURES High speed U.V. enhanced Low capacitance U.V. window WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP O ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 5 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH l range R VBR NEP tr 3.2 MAX mA 4.6 40 UNITS 150 pA 2.5 GW H = 0, V R = 10 mV -8 % / oC H = 0, V R = 5 V** 35 pF Spectral Application Range Spot Scan .25 190 1100 nm Responsivity VR = 0 V, l = 254 nm .12 .18 A/W Breakdown Voltage I = 10 m A 15 25 V -14 Noise Equivalent Power VR = 10 mV @ Peak 1x10 Response Time RL = 1 KW V R = 5 V 35 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDU-C101 REV N/C]
PDU-C101 价格&库存
很抱歉,暂时无法提供与“PDU-C101”相匹配的价格&库存,您可以联系我们找货
