PHOTONIC
Silicon Photodiode, U.V. Enhanced Photoconductive
Type PDU-C105
DETECTORS INC.
PACKAGE DIMENSIONS INCH [mm]
WINDOW CAP
(WELDED)
0.030 [0.76]
Ø0.325 [8.25]
Ø 0.250 [6.35]
CL
0.168 [4.26]
0.075 [1.91]
WIRE
BONDS
0.500
[12.70]
MIN
45°
Ø 0.358
[9.09]
78°
VIEWING
ANGLE
CL
CL
0.200 [5.08]
0.035
[0.89]
CL
ANODE
Ø0.018 [0.46]
CATHODE
Ø0.018 [0.46]
HEADER
PHOTODIODE
0.095 [2.41] SQ
TO-5 HERMETIC CAN PACKAGE
0.086 [2.18] SQ ACTIVE
AREA
ACTIVE AREA = 4.48 mm2
500
C
mA
0.1
WAVELENGTH (nm)
*1/16 inch from case for 3 secs max
ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted)
SYMBOL CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
ISC
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, V R = 5 V
Shunt Resistance
H = 0, V R = 10 mV
TC RSH
RSH Temp. Coefficient
CJ
Junction Capacitance
RSH
λrange
R
V BR
NEP
tr
1200
Light Current
O
0.2
1100
IL
+240
C
900
Soldering Temperature*
+125
0.3
1000
TS
-40
O
C
800
Operating Temperature Range
O
0%
700
TO
+150
=1
QE
0.4
600
-55
0.5
500
Storage Temperature
V
0.6
400
30
0.7
300
TSTG
Reverse Voltage
SPECTRAL RESPONSE
190
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
V BR
APPLICATIONS
Spectrometers
Fluorescent analysers
U.V. meters
Colorimeters
DESCRIPTION
The PDU-C105 is a silicon, PIN planar
diffused, U.V. enhanced photodiode. Ideal
for high speed photoconductive applications.
Packaged in a hermetic TO-5 metal can
with a U.V. transmitting window.
RESPONSIVITY (A/W)
FEATURES
High speed
U.V. enhanced
Low capacitance
U.V. window
40
MAX
UNITS
mA
56
1.0
5.0
nA
1.0
GΩ
H = 0, V R = 10 mV
-8
% / oC
H = 0, V R = 5 V**
37
pF
Spectral Application Range Spot Scan
.25
190
1100
Responsivity
VR = 0 V, l = 254 nm
.12
.18
Breakdown Voltage
I = 10 m A
15
25
Noise Equivalent Power
VR = 10 mV @ Peak
Response Time
RL = 1 KΩ VR = 5 V
A/W
V
-14
1.3x10
50
nm
W/
Hz
nS
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice.**f = 1 MHz
[FORM NO. 100-PDU-C105 REV N/C]
很抱歉,暂时无法提供与“PDU-C105”相匹配的价格&库存,您可以联系我们找货
