PDU-C103
PDU-C103
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2,金属罐
    PHOTODIODE UV 2.03MM SQ TO-46
PDU-C103 数据手册
PHOTONIC Silicon Photodiode, U.V. Enhanced Photoconductive Type PDU-C103 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) Ø0.184[4.67] 0.150[3.81] 0.040[1.02] Ø0.155[3.94] 0.060[1.52] WIRE BONDS CL 0.500 [12.70] MIN 45° CL Ø0.210[5.33] CL 0.100[2.54] CL 58° VIEWING ANGLE 0.042 [1.06] ANODE Ø0.018[0.46] HEADER PHOTODIODE CATHODE Ø0.018[0.46] 0.068[1.73] SQUARE 0.059[1.50] SQ ACTIVE AREA TO-46 HERMETIC CAN PACKAGE ACTIVE AREA = 2.03 mm2 DESCRIPTION The PDU-C103 is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a hermetic TO-46 metal can with a U.V. transmitting window. Operating Temperature Range -40 +125 O TS Soldering Temperature* +240 O IL Light Current 500 C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 5 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange R VBR NEP tr 1200 TO C 1100 O 900 +150 1000 -55 0.4 800 Storage Temperature % 00 =1 QE 0.5 700 TSTG 0.6 600 V 500 30 400 Reverse Voltage 300 VBR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Spectrometers Fluorescent analysers U.V. meters Colorimeters RESPONSIVITY (A/W) FEATURES High Speed U.V. enhanced Low capacitance U.V. window 20 MAX UNITS mA 25 65 250 pA 1 GΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 5 V** 20 pF Spectral Application Range Spot Scan .25 190 1100 Responsivity VR = 0 V, l = 254 nm .12 .18 Breakdown Voltage I = 10 m A 15 25 Noise Equivalent Power VR = 10 mV @ Peak Response Time RL = 1 KΩ VR = 5 V A/W V -14 10x10 45 nm W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDU-C103 REV N/C]
PDU-C103 价格&库存
很抱歉,暂时无法提供与“PDU-C103”相匹配的价格&库存,您可以联系我们找货
