PDI-V495-46
PDI-V495-46
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2,金属罐
    PHOTODIODE 950NM 2.98MM SQ TO-46
PDI-V495-46 数据手册
PHOTONIC Silicon Photodiode, Filter Combination Photovoltaic DETECTORS INC. (center wavelength 950 nm) Type PDI-V495-46 PACKAGE DIMENSIONS INCH [mm] Ø.184 [4.67] .275 [6.99] .060 [1.52] .040 [1.02] Ø.155 [3.94] CL 0.500 [12.70] MIN 45° CL .100 [2.54] CL CL Ø.210 [5.33] .042 [1.06] .125 [3.18] .066 [1.68] ANODE Ø.018 [0.46] FILTER CAP SUBASSEMBLY PHOTODIODE CATHODE Ø.018 [0.46] HEADER .046 [1.17] ACTIVE AREA .104 [2.64] ACTIVE AREA TO-46 CAN PACKAGE ACTIVE AREA = 2.98 mm2 FEATURES 950 nm CWL 65 nm FWHM Large active area DESCRIPTION The PDI-V495-46 is a silicon, PIN planar diffused, photodiode with a wide band interferance filter. The detector filter combiMatched to 940 nm LEDs nation has a wide 65 nm half bandwidth designed for low noise photovoltaic applications. Packaged in a TO-46 metal can. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS O IL Light Current 0.5 C mA 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current*** H = 100 fc, 2850 K ID Dark Current H = 0, VR = 10 V Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient H = 0, VR = 10 mV CJ Junction Capacitance CWL HBW 35 MAX mA 40 150 UNITS 300 pA 6 GΩ -8 % / oC H = 0, VR = 0 V** 340 pF Center Wavelength (CWL, lo) +/- 2 nm 950 nm Half Bandwidth (FWHM) 65 nm V BR Breakdown Voltage I = 10 m A 50 V N EP Noise Equivalent Power VR = 10 mV @ Peak 5x10-14 Response Time RL = 1 KΩ VR = 0 V 450 RSH tr 1200 +240 FWHM = 65 nm @ 75% Tx MIN 0.2 1100 Soldering Temperature* C 900 TS -15 1000 Operating Temperature Range 0.3 800 TO C 0% 700 +70 O 0 =1 QE 0.4 600 O 0.5 500 +85 -20 0.6 400 Storage Temperature V SPECTRAL RESPONSE 0.7 300 75 I.R. detector GaAs LED sensor 190 TSTG Reverse Voltage Chemistry instrumentation RESPONSIVITY (A/W) V BR APPLICATIONS Spectrophotometry 1.0 30 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz, ***without filter [FORM NO. 100-PDI-V495-46 REV A]
PDI-V495-46 价格&库存
很抱歉,暂时无法提供与“PDI-V495-46”相匹配的价格&库存,您可以联系我们找货
