PDU-C110Q
PDU-C110Q
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    2-DIP模块
    PHOTODIODE UV 100MM SQ CERAMIC
PDU-C110Q 数据手册
PHOTONIC Silicon Photodiode, U.V. Enhanced Photoconductive Type PDU-C110-Q DETECTORS INC. PACKAGE DIMENSIONS INCH (mm) 0.592 [15.04] 0.409 [10.39] SQUARE WIRE BONDS 0.080 [2.03] NOTCH INDICATES ANODE PIN 0.50 [12.7] QUARTZ WINDOW CL WHITE CERAMIC 0.650 [16.51] ANODE 120° VIEWING ANGLE 0.484 [12.29] PHOTODIODE CHIP C L Ø0.017 [0.43] 2 PLACES CERAMIC PACKAGE ACTIVE AREA = 100.00 mm2 +60 O TS Soldering Temperature* +220 O IL Light Current 500 C C mA 0.3 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 5 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 5 V** RSH λrange R V BR NEP tr 1200 -20 1100 Operating Temperature Range 900 TO C 1000 O 800 +80 0% 700 -20 0 =1 QE 0.4 600 Storage Temperature TSTG 0.5 500 V 400 30 0.6 300 Reverse Voltage SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS V BR APPLICATIONS Spectometers Fluorescent analysers U.V. meters Colorimeters DESCRIPTION The PDU-C110-Q is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in low profile ceramic substrate with a flat quartz window. RESPONSIVITY (A/W) FEATURES High speed U.V. enhanced Low capacitance Quartz window CATHODE Spectral Application Range Spot Scan 1.0 30 VR = 0 V, l = 254 nm .12 Breakdown Voltage I = 10 m A 15 nA 15 MΩ -8 % / oC 600 pF 190 Responsivity UNITS mA 1.3 10 7 MAX 1100 .18 25 nm A/W V -13 Noise Equivalent Power VR = 10 mV @ Peak 1.5x10 Response Time RL = 1 KΩ VR = 5 V 350 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz [FORM NO. 100-PDU-C110-Q REV N/C]
PDU-C110Q 价格&库存
很抱歉,暂时无法提供与“PDU-C110Q”相匹配的价格&库存,您可以联系我们找货
