PDU-C112Q
PDU-C112Q
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    模块
    PHOTODIODE UV 100MM SQ BNC CONN
PDU-C112Q 数据手册
PHOTONIC Silicon Photodiode, U.V. DETECTORS INC. Enhanced Photoconductive Type PDU-C112-Q PACKAGE DIMENSIONS inch (mm) 0.175 [4.45] Ø0.975 [Ø24.77] 0.073 [1.85] PHOTODIODE ACTIVE SURFACE TO TOP OF WINDOW BLACK EPOXY HOUSING PWB QUARTZ WINDOW Ø0.4447 [Ø11.295] ACTIVE AREA (100 mm ) 4X WIRE BONDS 104° VIEWING ANGLE Ø0.625 [Ø15.88] SOLDER Ø0.695 [Ø17.65] PHOTODIODE CHIP 0.400 [10.16] 1.045 [26.54] CAP CATHODE AMP BNC CONNECTOR, ANODE BNC CONNECTOR PACKAGE ACTIVE AREA = .4447 (11.295) DIA = 100 mm2 TO Operating Temperature Range -10 +60 O N/A O TS Soldering Temperature* N/A C C C 0.4 0.3 0.2 0.1 0 Imax Light Current 500 mA *1/16 inch from case for 3 secs max 1200 O 1100 +70 900 -20 1000 Storage Temperature % 00 =1 E Q 0.5 800 TS 0.6 700 V 600 30 0.7 500 Reverse Voltage SPECTRAL RESPONSE 400 VBR · · · · 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS APPLICATIONS Instrumentation Power meters Colorimeters Laser power meters 190 · · · · DESCRIPTION The PDU-C112-Q is a large area, instrumentation grade, U.V. enhanced silicon photodiode. Designed for low capacitance high speed photoconductive applications. Packaged in a BNC connector package. RESPONSIVITY FEATURES High speed U.V. enhanced Low capacitance Quartz window WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP O ISC Short Circuit Current H = 100 fc, 2850 K Dark Current H = 0, VR = 5 V Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance ID RSH lrange R VBR NEP tr 1.0 MAX UNITS 1.3 mA 10 30 nA 15 MW W H = 0, VR = 10 mV -8 % / oC H = 0, VR = 5 V** 600 pF Spectral Application Range Spot Scan 7 190 1100 Responsivity VR = 0 V, l= 254 nm .12 .18 Breakdown Voltage I= 10 µA 15 25 Noise Equivalent Power VR = 10 @ Peak Response Time RL = 1 KW W VR = 5 V A/W V -13 1.5x10 350 nm W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDU-C112-Q REV N/C]
PDU-C112Q 价格&库存
很抱歉,暂时无法提供与“PDU-C112Q”相匹配的价格&库存,您可以联系我们找货
