PDU-C111Q
PDU-C111Q
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-8密封
    PHOTODIODE UV 100.2MM SQ TO-8
PDU-C111Q 数据手册
PHOTONIC Silicon Photodiode, U.V. Enhanced Photoconductive Type PDU-C111-Q DETECTORS INC. PACKAGE DIMENSIONS INCH (mm) Ø0.795 Ø[20.19] Ø0.500 [ Ø12.70] PIN CIRCLE 0.230 [5.84] Ø0.720 Ø[18.29] 0.165 [4.19] QUARTZ WINDOW CAP Ø0.608 Ø[15.44] ANODE 0.375 [9.53] Ø0.030 [0.76] TYP WIRE BONDS VIEWING ANGLE 54° Ø0.4447 ACTIVE AREA HEADER 0.030[0.76] PHOTODIODE CHIP UNUSED PIN 0.200 [5.08] CATHODE CASE GROUND TO-8 .795 INCH (20.19) DIA PACKAGE ACTIVE AREA = 100.20 mm2 +125 O TS Soldering Temperature* +224 O IL Light Current 500 C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, VR = 5 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV CJ Junction Capacitance H = 0, V R = 5 V** RSH λrange R V BR NEP tr 1200 -40 1100 Operating Temperature Range 900 TO C 1000 O 800 +150 0% 700 -55 0 =1 QE 0.4 600 Storage Temperature TSTG 0.5 500 V 400 30 0.6 300 Reverse Voltage SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS V BR APPLICATIONS Spectrometers Fluorescent analysers U.V. meters Colorimeters DESCRIPTION The PDU-C111-Q is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a low cost TO-8 metal can with a flat quartz window. RESPONSIVITY (A/W) FEATURES High speed U.V. enhanced Low capacitance Quartz window Spectral Application Range Spot Scan 1.0 1.3 UNITS mA 10 7 MAX 30 nA 15 MΩ -8 % / oC 600 pF 190 1100 Responsivity VR = 0 V, l = 254 nm .12 .18 Breakdown Voltage I = 10 m A 15 25 nm A/W V -13 Noise Equivalent Power VR = 10 mV @ Peak 1.5x10 Response Time RL = 1 KΩ VR = 5 V 350 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDU-C111-Q REV N/C]
PDU-C111Q 价格&库存
很抱歉,暂时无法提供与“PDU-C111Q”相匹配的价格&库存,您可以联系我们找货
