PHOTONIC
Silicon Photodiode, U.V. Enhanced Photoconductive
Type PDU-C115-Q
DETECTORS INC.
PACKAGE DIMENSIONS INCH [mm]
Ø0.325 [8.25]
QUARTZ WINDOW CAP
(WELDED)
0.168 [4.26]
0.030 [0.76]
0.075 [1.91]
Ø0.250 [6.35]
CL
WIRE
BONDS
0.500
[12.70]
MIN
45°
Ø0.358
[9.09]
CL
73°
VIEWING
ANGLE
CL
0.200 [5.08]
0.035
[0.89]
CL
ANODE
Ø0.018 [0.46]
CATHODE
Ø0.018 [0.46]
HEADER
PHOTODIODE
0.110 [2.79]
SQUARE
Ø0.100 [Ø2.54]
ACTIVE AREA
TO-5 CAN PACKAGE
ACTIVE AREA = 5.07 mm2
APPLICATIONS
Spetrometers
Fluorescent analysers
U.V. meters
Colorimeters
DESCRIPTION
The PDU-C115-Q is a silicon, PIN planar
diffused, U.V. enhanced photodiode. Ideal
for high speed photoconductive applications.
Packaged in a TO-5 metal can with a flat
quartz window.
Light Current
O
500
C
mA
0.2
0.1
WAVELENGTH (nm)
*1/16 inch from case for 3 secs max
ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted)
SYMBOL CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
ISC
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, V R = 5 V
Shunt Resistance
H = 0, V R = 10 mV
TC RSH
RSH Temp. Coefficient
CJ
Junction Capacitance
RSH
λrange
R
V BR
NEP
tr
1200
IL
+240
C
0.3
1100
Soldering Temperature*
+125
0.4
900
TS
-40
O
C
1000
Operating Temperature Range
O
0%
800
TO
+150
=1
QE
700
-55
0.5
600
Storage Temperature
V
500
TSTG
30
400
Reverse Voltage
0.6
300
V BR
SPECTRAL RESPONSE
0.7
190
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
RESPONSIVITY (A/W)
FEATURES
High speed
U.V. enhanced
Low capacitance
Quartz window
45
MAX
UNITS
mA
65
1
5
nA
1
GΩ
H = 0, V R = 10 mV
-8
% / oC
H = 0, V R = 5 V**
40
pF
Spectral Application Range Spot Scan
.25
190
1100
Responsivity
VR = 0 V, l = 254 nm
.12
.18
Breakdown Voltage
I = 10 mA
15
25
Noise Equivalent Power
VR = 10 mV @ Peak
Response Time
RL = 1 KΩ VR = 5 V
A/W
V
-14
1.4x10
56
nm
W/
Hz
nS
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice. **f = 1 MHz
[FORM NO. 100-PDU-C115-Q REV N/C]
很抱歉,暂时无法提供与“PDU-C115Q”相匹配的价格&库存,您可以联系我们找货
