PDV-C406-LP
PDV-C406-LP
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5-2透镜顶部金属罐
    Photodiode 50ns 102° TO-5-2 Lens Top Metal Can
PDV-C406-LP 数据手册
PHOTONIC Silicon Photodiode, Filter Combination Photoconductive DETECTORS INC.Visible Spectral Response Range Type PDV-C406-LP Industry Equivalent: BPW-21 PACKAGE DIMENSIONS INCH [mm] 0.125 [3.17] 0.105 [2.67] WINDOW CAP (WELDED) Ø0.325 [8.25] Ø0.250 [6.35] 0.030 [0.76] 0.075 [1.91] CHIP SURFACE CL 0.500 [12.70] MIN 45° Ø0.358 [9.09] 102° CL 0.200 [5.08] VIEWING ANGLE 0.035 [0.89] CL ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] PHOTOPIC FILTER PHOTODIODE CL HEADER 0.125 [3.18] 0.113 [2.87] ACTIVE AREA TO-5 HERMETIC CAN PACKAGE 0.113 [2.87] ACTIVE AREA ACTIVE AREA = 7.95 mm2 DESCRIPTION APPLICATIONS The PDV-C406-LP is a silicon, PIN planar Photometry diffused, photodiode with a visible spectral Radiometry response range. The detector filter combination Low noise, low capacitance Film color processing has a wide bandwidth designed to simulate the Hermetic package spectral response of the human eye. Packaged in a low profile hermetic TO-5 metal can. SPECTRAL RESPONSE ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) 0.7 SYMBOL PARAMETER MIN MAX UNITS 0.6 500 C mA 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH lrange mA 110 5 UNITS 20 nA MΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 10 V** 60 Spectral Application Range Flooded Spectral Response Peak (FWHM) V BR Breakdown Voltage I = 10 m A tr 90 MAX 300 lp NEP 1200 Light Current O 0.2 1100 IL +240 C 0.3 900 Soldering Temperature* -40 0.4 1000 TS +85 O C 800 Operating Temperature Range O 700 TO +100 0% 600 -50 0 =1 QE 0.5 500 Storage Temperature V 400 TSTG 100 300 Reverse Voltage 190 V BR RESPONSIVITY (A/W) FEATURES Wide view angle Human eye response Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 10 V 150 350 75 150 pF 820 nm 550 nm 100 V -14 5x10 50 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.** f = 1 MHz [FORM NO. 100-PDV-C406-LP REV A]
PDV-C406-LP
物料型号:PDV-C406-LP
器件简介: - 该光电二极管是硅基、PIN平面扩散型,具有可见光谱响应范围。 - 探测器与滤波器组合设计,以模拟人眼的光谱响应。 - 封装在低轮廓的密封TO-5金属罐中。
引脚分配: - 阳极:直径0.018英寸(0.46毫米) - 阴极:直径0.018英寸(0.46毫米)
参数特性: - 反向电压(VBR):最大100V - 存储温度(TSTG):-50℃至+100℃ - 工作温度范围(To):-40℃至+85℃ - 焊接温度(Ts):最大+240℃ - 光电流:最大500mA
功能详解: - 具有宽视场角和人眼响应特性。 - 低噪声、低电容。 - 密封封装。
应用信息: - 光度学、辐射度学、胶片颜色处理。
封装信息: - 封装类型:TO-5密封罐 - 封装尺寸:0.125英寸(3.17毫米)x 0.105英寸(2.67毫米) - 窗口盖(焊接):直径0.325英寸(8.25毫米) - 芯片表面:直径0.500英寸(12.70毫米) - 视场角:最小102° - 活动区域:0.125英寸(3.18毫米)x 0.113英寸(2.87毫米),面积为7.95 mm²
光谱响应: - 响应度(A/W)在550nm处达到峰值,半高宽(FWHM)为550nm。
电光特性: - 短路电流(Isc):在100 fc,2850K条件下,最小值为90 LA。 - 暗电流(ID):在0光,10V反向电压下,典型值为5 nA。 - 并联电阻(RSH):在0光,10mV反向电压下,典型值为300 MO。 - 结电容(CJ):在0光,10V反向电压下,典型值为60 pF。 - 光谱应用范围:350nm至820nm。 - 响应时间(tr):在1KΩ负载下,典型值为50 ns。
PDV-C406-LP 价格&库存
很抱歉,暂时无法提供与“PDV-C406-LP”相匹配的价格&库存,您可以联系我们找货
