PDI-701
PDI-701
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    Photodiode 940nm
PDI-701 数据手册
PHOTONIC DETECTORS INC. I.R. Remote control, Opto Receiver I.C. Type PDI-701 PACKAGE DIMENSIONS INCH [mm] .256 [6.50] .866 [22.00] BLACK PLASTIC .059 [1.50] .039 [0.99] .020 [0.51] TYP .100 [2.54] TYP .236 [5.99] .098 [2.49] VCC GROUND V OUT .157 [3.99] .047 [1.19] R.091 [R2.31] .079 [2.01] .016 [0.41] .142 [3.61] FEATURES 38 KHz B.P.F. freq. Built-in EMI sheild Compact- Low cost Matched to 880 & 940 nm LEDs PLASTIC PACKAGE DESCRIPTION: The PDI-701 is a compact, low cost opto I.C. receiver, designed for audio, video, industrial and other NIR remote control applications. B.P.F. center frequency set at 38 KHz, built-in EMI shield with magnification lens. Matched toPDI-E800 & PDI-E900 LEDs (880 & 940 nm). APPLICATIONS Audio remote control Video remote control Industrial remote ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS VCC Supply Voltage 6.3 V TSTG Storage Temperature -30 +100 O TO Operating Temperature Range -10 +75 O TS Soldering Temperature* +260 O C C C *3 mm from case for 5 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP VCC Supply Voltage I CC Current Consumption 4.5 No Signal Input L Detection Length 10 Vh High Level Voltage 4.5 Vl Low Level Voltage MAX UNITS 5.0 5.5 V 1.5 2.0 mA 16 M V 0.5 V TON On-pulse Width 400 600 800 mS TOFF Off-pulse Width 400 600 800 mS l Sensitivity Peak Wavelength 940 nm FO Central Frequency 38.0 KHz 35/ 30 deg O80% Horizon Angle/ Vertical Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. [FORM NO. 100-PDI-701 REV N/C]
PDI-701 价格&库存
很抱歉,暂时无法提供与“PDI-701”相匹配的价格&库存,您可以联系我们找货
