PDI-M305
PDI-M305
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO8-3
    PHOTO DIODE HI SPEED SILICON TO8
PDI-M305 数据手册
PHOTONIC DETECTORS INC. 1.06 Micron, High Speed Silicon Photodiode Quadrant Type PDI-M305 PACKAGE DIMENSIONS INCH [mm] Ø1.000 [Ø25.40] .500 [12.70] Ø.635 [Ø16.13] GUARD RING 1 4 1 3 2 Ø.845 [21.46] 2 3 4 + 6X Ø.030 [0.76] RL RL RL RL .500 [12.70] .060 [1.52] .345 [8.76] ELEMENT #1 CATHODE CASE/ COMMON ANODE .448 [11.37] SQ 3 ELEMENT #4 CATHODE JUMBO TO-8 HERMETIC CAN PACKAGE 4X R.184 [R4.67] ACTIVE AREA 4 1 2 GUARD RING ELEMENT #3 CATHODE Ø.675 [Ø17.15] PIN CIRCLE BOTTOM VIEW ELEMENT #2 CATHODE GUARD RING .007 [0.18] GAP TYP ACTIVE AREA = 17.13 mm2 PER ELEMENT FEATURES .45 A/W @1060 nm 12 ns response time Low noise +100 O TS Soldering Temperature* +260 O IL Light Current C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP UNITS mA Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 170 V 100 Shunt Resistance H = 0, V R = 10 mV - MΩ TC RSH RSH Temp. Coefficient H = 0, V R = 10 mV -10 % / oC CJ Junction Capacitance H = 0, V R = 170 V** λrange Spectral Application Range Spot Scan λp Spectral Response - Peak Spot Scan VBR Breakdown Voltage I = 1 mA NEP tr 375 MAX ISC RSH 1200 -40 1100 Operating Temperature Range 0.4 900 TO C 1000 O 800 +125 700 -55 % 00 =1 QE 0.5 600 Storage Temperature 0.6 500 TSTG 500 V 400 75 0.7 300 Reverse Voltage SPECTRAL RESPONSE 190 VBR APPLICATIONS YAG laser detection Navigation Tracking and Aligning RESPONSIVITY (A/W) DESCRIPTION The PDI-M305 is a high speed photodiode, processed on high resistivity P type silicon. Guard ring construction for enhanced 1060 nm response and 28 Mhz bandwidth. Packaged in a 6 leaded hermetic TO-5 hermetic package. Ideal for Nd YAG laser. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS 380 7 400 250 1000 nA 9 pF 1150 nm 900 nm 300 V -11 Noise Equivalent Power VR = 10 V @ 900 nm 5x10 Response Time RL = 50Ω VR = 170 V 12 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. ** f = 1 MHz [FORM NO. 100-PDI-M305 REV N/C]
PDI-M305
物料型号:PDI-M305
器件简介:该光电二极管是一种高速设备,采用高电阻率P型硅材料制作,具有增强的1060纳米响应和28MHz的带宽,封装在6引脚的TO-5密封封装中,适用于Nd YAG激光。
引脚分配:文档中提供了详细的引脚和元件布局,包括阳极、阴极、公共阳极和保护环。
参数特性:包括反向电压、存储温度、工作温度范围、焊接温度、光电流等。
功能详解:文档详细描述了光电二极管的光谱响应、短路电流、暗电流、并联电阻、结电容、光谱应用范围、峰值光谱响应、击穿电压和噪声等效功率等电光特性。
应用信息:适用于YAG激光探测、导航、跟踪和对准。
封装信息:提供了封装的尺寸和形状,包括直径、高度、引脚圈直径和间隙等。
PDI-M305 价格&库存
很抱歉,暂时无法提供与“PDI-M305”相匹配的价格&库存,您可以联系我们找货
