PDU-C115
PDU-C115
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-5
    PHOTODIODE UV 5.07MM SQ TO-5
PDU-C115 数据手册
PHOTONIC Silicon Photodiode, U.V. Enhanced Photoconductive Type PDU-C115 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] WINDOW CAP (WELDED) Ø0.325 [8.25] Ø0.250 [6.35] 0.168 [4.26] 0.030 [0.76] CL 0.075 [1.91] WIRE BONDS 0.500 [12.70] MIN 45° Ø0.358 [9.09] 73° VIEWING ANGLE CL CL 0.200 [5.08] 0.035 [0.89] CL ANODE Ø0.018 [0.46] CATHODE Ø0.018 [0.46] HEADER PHOTODIODE 0.110 [2.79] SQUARE Ø0.100 [Ø2.54] ACTIVE AREA TO-5 HERMETIC CAN PACKAGE ACTIVE AREA = 5.07 mm2 APPLICATIONS Spetrometers Fluorescent analysers U.V. meters Colorimeters DESCRIPTION The PDU-C115 is a silicon, PIN planar diffused, U.V. enhanced photodiode. Ideal for high speed photoconductive applications. Packaged in a hermetic TO-5 metal can with a U.V. transmitting window. Light Current O 500 C mA 0.2 0.1 0 WAVELENGTH (nm) *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current H = 100 fc, 2850 K ID Dark Current H = 0, V R = 5 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance RSH λrange R V BR NEP tr 1200 IL +240 C 0.3 1100 Soldering Temperature* +125 0.4 900 TS -40 O C 1000 Operating Temperature Range O 0% 800 TO +150 0 =1 QE 700 -55 0.5 600 Storage Temperature V 500 TSTG 30 400 Reverse Voltage 0.6 300 V BR SPECTRAL RESPONSE 0.7 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS RESPONSIVITY (A/W) FEATURES High speed U.V. enhanced Low capacitance U.V. window 45 MAX UNITS mA 65 1 5 nA 1 GΩ H = 0, V R = 10 mV -8 % / oC H = 0, V R = 5 V** 40 pF Spectral Application Range Spot Scan .25 190 1100 Responsivity VR = 0 V, l = 254 nm .12 .18 Breakdown Voltage I = 10 mA 15 25 Noise Equivalent Power VR = 10 mV @ Peak Response Time RL = 1 KΩ VR = 5 V A/W V -14 1.4x10 56 nm W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDU-C115 REV N/C]
PDU-C115 价格&库存
很抱歉,暂时无法提供与“PDU-C115”相匹配的价格&库存,您可以联系我们找货
