PDU-V112Q
PDU-V112Q
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    模块
    PHOTODIODE UV W/QW 100MM SQ BNC
PDU-V112Q 数据手册
PHOTONIC Silicon Photodiode, U.V. DETECTORS INC. Enhanced Photovoltaic Type PDU-V112-Q PACKAGE DIMENSIONS inch (mm) 0.175 [4.45] Ø0.975 [Ø24.77] PWB QUARTZ WINDOW Ø0.4447 [Ø11.295] ACTIVE AREA (100 mm ) 4X WIRE BONDS 0.073 [1.85] PHOTODIODE ACTIVE SURFACE TO TOP OF WINDOW BLACK EPOXY HOUSING 104° VIEWING ANGLE Ø0.625 [Ø15.88] SOLDER Ø0.695 [Ø17.65] PHOTODIODE CHIP 0.400 [10.16] 1.045 [26.54] CAP CATHODE AMP BNC CONNECTOR, ANODE BNC CONNECTOR PACKAGE ACTIVE AREA = .4447 (11.295) DIA = 100 mm2 DESCRIPTION APPLICATIONS The PDU-V112-Q is a large area, instrumentation Instrumentation grade, U.V. enhanced silicon photodiode. Power meters Designed for low noise photovoltaic applications. High shunt resistance Colorimeters Packaged in a BNC connector package. Quartz window Laser power meters FEATURES Low noise U.V. enhanced · · · · Operating Temperature Range -10 +60 O TS Soldering Temperature* N/A N/A O Light Current 500 C C 0.3 0.2 0.1 0 mA *1/16 inch from case for 3 secs max 1200 TO Imax C 1100 O 900 +70 1000 -20 0.4 800 Storage Temperature % 00 =1 QE 0.5 700 TS 0.6 600 V 500 30 400 Reverse Voltage 0.7 190 VBR SPECTRAL RESPONSE 300 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS RESPONSIVITY · · · · WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP O ISC Short Circuit Current H = 100 fc, 2850 K Dark Current H = 0, VR = 10 mV Shunt Resistance H = 0, VR = 10 mV TC RSH RSH Temp. Coefficient CJ Junction Capacitance ID RSH lrange .09 330 pA MW H = 0, VR = 10 mV -8 % / oC H = 0, VR = 0 V** 10,000 Spectral Application Range Spot Scan 190 VR = 0 V, l= 254 nm VBR Breakdown Voltage I= 10 µA NEP Noise Equivalent Power VR = 10 @ Peak 2x10 Response Time RL = 1 KW VR = 0 V 2,000 tr mA 50 Responsivity R UNITS 1.2 200 30 MAX 12,000 pF 1100 nm .12 .18 A/W 5 10 V -14 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. **f = 1 MHz [FORM NO. 100-PDU-V112-Q REV N/C]
PDU-V112Q 价格&库存
很抱歉,暂时无法提供与“PDU-V112Q”相匹配的价格&库存,您可以联系我们找货
