PDB-C440-46B
PDB-C440-46B
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2透镜顶部金属罐
    PHOTO DIODE TO-46 VIOLET
PDB-C440-46B 数据手册
PHOTONIC Silicon Photodiode, Filter Combination Photoconductive DETECTORS INC. (center wavelength 400 nm) Type PDB-C440-46B PACKAGE DIMENSIONS INCH [mm] Ø.184 [4.67] .275 [6.99] .060 [1.52] .040 [1.02] Ø.155 [3.94] C L 0.500 [12.70] MIN 45° CL .100 [2.54] CL CL Ø.210 [5.33] .042 [1.06] .125 [3.18] .066 [1.68] ANODE Ø.018 [0.46] FILTER CAP SUBASSEMBLY PHOTODIODE CATHODE Ø.018 [0.46] HEADER .046 [1.17] ACTIVE AREA .104 [2.64] ACTIVE AREA TO-46 CAN PACKAGE ACTIVE AREA = 2.98 mm2 DESCRIPTION The PDB-C440-46B is a silicon, PIN planar diffused, photodiode with a wide band interference filter. The detector filter combination has a wide 40 nm half bandwidth designed for high speed photoconductive applications. Packaged in a TO-46 metal can. -15 +70 O TS Soldering Temperature* +240 O IL Light Current C C mA 0.3 0.2 0.1 0 *1/16 inch from case for 3 secs max FWHM = 40 nm @ 45% Tx MIN WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current*** H = 100 fc, 2850 K ID Dark Current H = 0, VR = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ 40 MAX UNITS mA 45 150 300 pA 1.0 GΩ H = 0, V R = 10 mV -8 % / oC Junction Capacitance H = 0, V R = 0 V** 10 pF CWL Center Wavelength (CWL, l o) +/- 2 nm 400 nm HBW Half Bandwidth (FWHM) 40 nm V BR Breakdown Voltage I = 10 m A NEP Noise Equivalent Power VR = 10 mV @ Peak Response Time RL = 1 KΩ VR = 0 V RSH tr 1200 Operating Temperature Range 1100 TO 500 C 900 O 1000 +85 0.4 800 -20 % 00 =1 E Q 0.5 700 Storage Temperature 0.6 600 V SPECTRAL RESPONSE 0.7 500 75 Liquid chromatography 400 TSTG Reverse Voltage Chemistry instrumentation 300 V BR APPLICATIONS Spectrophotometry 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS RESPONSIVITY (A/W) FEATURES 400 nm CWL 40 nm FWHM Large active area .5 70 100 V 1.5x10 -14 10 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz, ***without filter [FORM NO. 100-PDB-C440-46B REV N/C]
PDB-C440-46B 价格&库存
很抱歉,暂时无法提供与“PDB-C440-46B”相匹配的价格&库存,您可以联系我们找货
