PDV-C403-46
PDV-C403-46
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2透镜顶部金属罐
    PHOTO DIODE TO-46 RED
PDV-C403-46 数据手册
PHOTONIC Silicon Photodiode, Filter Combination Photoconductive 600 nm (red color) Type PDV-C403-46 DETECTORS INC. PACKAGE DIMENSIONS INCH [mm] Ø.184 [4.67] .275 [6.99] .060 [1.52] .040 [1.02] Ø.155 [3.94] 0.500 [12.70] MIN CL 45° CL .100 [2.54] CL CL Ø.210 [5.33] .042 [1.06] PHOTODIODE ANODE Ø.018 [0.46] FILTER CAP SUBASSEMBLY .125 [3.18] CATHODE Ø.018 [0.46] HEADER ACTIVE .046 [1.17] AREA .066 [1.68] .104 [2.64] ACTIVE AREA TO-46 CAN PACKAGE ACTIVE AREA = 2.98 mm2 DESCRIPTION The PDV-C403-46 is a silicon, PIN planar diffused, photodiode with a red color 600 nm +/- 2 nm CWL wide band interference filter and a wide 65 nm half bandwidth. Ideal for photometry and radiometry measurment applications. -15 +70 O TS Soldering Temperature* +240 O IL Light Current C C mA 0.3 0.2 FWHM = 65 nm @ 75 % Tx MIN 0.1 0 *1/16 inch from case for 3 secs max WAVELENGTH (nm) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP ISC Short Circuit Current*** H = 100 fc, 2850 K ID Dark Current H = 0, VR = 10 V Shunt Resistance H = 0, V R = 10 mV TC RSH RSH Temp. Coefficient CJ 40 MAX UNITS mA 45 .15 1.0 nA 1.0 GΩ H = 0, V R = 10 mV -8 % / oC Junction Capacitance H = 0, VR = 10 V** 10 pF CWL Center Wavelength (CWL, l o) +/- 2 nm 600 nm HBW Half Bandwidth (FWHM) 65 nm V BR Breakdown Voltage I = 10 m A NEP Noise Equivalent Power VR = 10 V @ Peak Response Time RL = 1 KΩ VR = 50 V RSH tr 1200 Operating Temperature Range 1100 TO 500 C 900 O 1000 +85 0.4 800 -20 % 00 =1 E Q 0.5 700 Storage Temperature 0.6 600 V 500 100 400 TSTG Reverse Voltage SPECTRAL RESPONSE 0.7 300 V BR APPLICATIONS Red color matching Color meters Film processing 190 ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS RESPONSIVITY (A/W) FEATURES 600 nm CWL 65 nm FWHM Low noise .5 70 100 V 1.5x10 -14 10 W/ Hz nS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice.**f = 1 MHz, ***without filter [FORM NO. 100-PDV-C403-46 REV N/C]
PDV-C403-46
物料型号:PDV-C403-46
器件简介:PDV-C403-46是一款硅PIN平面扩散光电二极管,具有红色600纳米±2纳米中心波长宽波段滤波器和65纳米半带宽,非常适合光度和辐射度测量应用。
引脚分配:文档中未明确列出引脚分配,但通常光电二极管会有阳极和阴极。
参数特性: - ISC:短路电流,测试条件为100 fc,2850 K时,最小值为40 mA,典型值为45 mA。 - ID:暗电流,测试条件为H = 0, VR = 10 V时,最小值为0.15 nA,典型值为1.0 nA。 - RSH:并联电阻,测试条件为H = 0, VR = 10 mV时,最小值为0.5 GΩ,典型值为1.0 GΩ。 - TC R SH:RSH温度系数,测试条件为H = 0, VR = 10 mV时,为-8% / ℃。 - CJ:结电容,测试条件为H = 0, VR = 10 V时,为10 pF。 - CWL:中心波长,为600 nm。 - HBW:半带宽,为65 nm。 - V BR:击穿电压,测试条件为I = 10 mA时,最小值为70 V,最大值为100 V。 - N EP:噪声等效功率,测试条件为VR = 10 V @ Peak时,为1.5x10^-14 W/ Hz。 - tr:响应时间,测试条件为RL = 1 KΩ VR = 50 V时,为10 nS。
功能详解:PDV-C403-46光电二极管适用于红色光匹配、色彩测量仪、胶片处理等应用。
应用信息:适用于红色光匹配、色彩测量仪、胶片处理。
封装信息:TO-46封装,包括阳极、阴极、滤光帽等部件。
PDV-C403-46 价格&库存
很抱歉,暂时无法提供与“PDV-C403-46”相匹配的价格&库存,您可以联系我们找货
