InGaAs Photodetectors
SD 008-11-41-211
PACKAGE DIMENSIONS INCH [mm]
0.210 [5.33]
0.059 [1.50]
3X 0.019 [0.48]
0.165 [4.19]
0.184 [4.67]
88°
CHIP
0.145 [3.69]
0.50 [12.7]
CHIP DIMENSIONS INCH [mm]
1 ANODE
2 CASE GROUND
0.016 [0.40]
3 CATHODE
SCHEMATIC
0.016 [0.40]
TO-46 PACKAGE
.0079 [.200] ACTIVE AREA
FEATURES
• Low noise
• Low dark current
• High response
DESCRIPTION
APPLICATIONS
The SD 008-11-41-211 is a high sensitivity low noise
characteristics InGaAs photodiode packaged in a
leaded hermetic TO-46 metal package.
• Communication
• Industrial
• Medical
SPECTRAL RESPONSE
ABSOLUTE MAXIMUM RATING (TA)= 23°C UNLESS OTHERWISE NOTED
VBR
PARAMETER
MIN
Reverse Voltage
MAX
75
UNITS
V
TSTG
Storage Temperature
-55
+100
TO
Operating Temperature
-40
+85
°C
°C
TS
Soldering Temperature*
+260
°C
* 1/16 inch from case for 3 seconds max.
1.2
1
Responsivity (A/W)
SYMBOL
0.8
0.6
0.4
0.2
900
1000
1100
1200
1300
1400
1500
1600
1700
Wavelength (nM)
ELECTRO-OPTICAL CHARACTERISTICS RATING (TA)= 23°C UNLESS OTHERWISE NOTED
SYMBOL
ID
RSH
CJ
lrange
R
VBR
NEP
tr
CHARACTERISTIC
Dark Current
Shunt Resistance
Junction Capacitance
Spectral Application Range
Responsivity
Breakdown Voltage
Noise Equivalent Power
Response Time**
TEST CONDITIONS
VR = 5V
VR = 10 mV
VR = 5V, f = 1 MHz
Spot Scan
l= 1310nm, VR = 5V
I = 1jA
VR = 5V @ l=1310nm
RL = 50 ,VR = 5V
MIN
100
800
0.83
TYP
1
300
9
MAX
5.0
10
1700
0.92
10
1.79X10-14
0.23
UNITS
nA
MW
pF
nm
A/W
V
W/ ¥ Hz
nS
**Response time of 10% to 90% is specified at 1310nm wavelength light.
Information in this technical datasheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are
subject to change without notice.
Advanced Photonix Inc. 1240 Avenida Acaso, Camarillo CA 93012 • Phone (805) 987-0146 • Fax (805) 484-9935 • www.advancedphotonix.com
REV 7/31/06
很抱歉,暂时无法提供与“SD008-11-41-211”相匹配的价格&库存,您可以联系我们找货
