Original In Red
all sensors
• Medical Instrumentation
• Environmental Instrumentation
• HVAC Instrumentation
• Pneumatic Controls
General Description
The Amplified line of middle pressure sensors is based upon a proprietary package technology to reduce errors. This model provides a
In addition the sensor utilizes a silicon, micromachined, stress
Each sensor is internally compensated using an ASIC compensation technique. This series is intended for use with non-
The output of the device is ratiometric to the supply voltage over a supply voltage range of 4.5 to 5.5 volts.
Physical Dimensions
Pin Size
0.010 x 0.020
(0.25 x 0.50)
Pin 1 2 3 4
0.174 to 0.190
(4.4 to 4.8)
0.21
(5.3)
1
A
0.66
(16.0)
0.55
(14.0)
Pin 2: Voutput
0.42
(10.5)
Pin 3: Common
B
0.80
(20.3)
0.85
(21.6)
Pin
Pin
Pin
Pin
1: Vsupply
2: Voutput
3: Common
4: Do not connect
All Sensors
06/20/2006
ASCX Series Compatible Rev A
DS-0023 Rev A
Origina
iginal In Red
All Sensors reserves the right to make changes to any products herein. All Sensors does not assume any liability arising out of the application or use of any product or circuit
described herein, neither does it convey any license under its patent rights nor the rights of others.
www.allsensors
llsensors.com
R
1.10
(27.9)
R
NOTES:
1) Dimensions in inches (millimeters)
Original In Red
1.08
(27.4)
0.48
(12.2)
Pin 1: Vsupply
0.10 Typical
(2.54)
www.allsensors.com
Original In Red
R
Equivalent Circuit
R
0.25
(6.4)
www.allsensors.com
p 408 225 4314
corrosive, non-ionic working fluids such as air, dry gases and the like.
Original In Red
Original In Red
These calibrated and temperature compensated sensors give an accurate and stable output over a wide temperature range.
www.allsensors.com
www.allsensors.com
R
concentration enhanced structure to provide a very linear output to measured pressure.
a 16035 Vineyard Blvd., Morgan Hill, CA 95037
reduce package induced parasitic stress and strain.
f 408 225 2079
ratiometric 4.5-volt output span with superior output characteristics. The sensor housing has been designed specifically to
R
e www.allsensors.com
Applications
Original In Red
Original In Red
R
5 Vdc Supply
High Level Voltage Output
Ratiometric 4.5 V Span
Temperature Compensated
Calibrated Zero and Span
MULTIPLE Pressure Ranges
R
www.allsensors.com
www.allsensors.com
Features
Original In Red
COMPATIBLE TO SENSYM ASCX SERIES
www.allsensors.com
www.allsensors.com
R
Red
ASCX Series Compatible Pressure Sensors
Original In Red
Supply Voltage, Vs
+4.5 to +5.5 Vdc
Lead Soldering Temperature (2-4 sec.)
Quiescent Current
(6)
Operating Temperature
-25 to 105°C
7.5 mA
Storage Temperature
-55 to 125°C
Humidity Limits (non condensing)
0 to 95% RH
Original In Red
R
www.allsensors.com
Burst Pressure
1 PSI-D-4V-ASCX
0 - 1 PSID
5 PSI
10 PSI
5 PSI-D-4V-ASCX
0 - 5 PSID
15 PSI
30 PSI
15 PSI-D-4V-ASCX
0 - 15 PSID
45 PSI
75 PSI
15 PSI-A-4V-ASCX
0 - 15 PSIA
45 PSI
75 PSI
30 PSI-D-4V-ASCX
0 - 30 PSID
100 PSI
150 PSI
30 PSI-A-4V-ASCX
0 - 30 PSIA
100 PSI
150 PSI
100 PSI-D-4V-ASCX
0 - 100 PSID
150 PSI
150 PSI
100 PSI-A-4V-ASCX
0 - 100 PSIA
150 PSI
150 PSI
(1)
Offset Voltage @ zero pressure
Offset Shift (0 °C to 70 °C)
(2)
Combined Linearity and Hysteresis Error
(4)
(7)
Repeatability
Response Time
(8)
4.50
4.57
Volt
±0.2
±1.5
%Span
0.18
0.25
0.32
Volt
±0.5
±1.5
%Span
±0.1
±0.5
%Span
±0.2
±0.5
% Span
100
uSec
(1)
(5)
(2)
Repeatability
(7)
Response Time
(8)
(4)
Minimum
Nominal
Maximum
Units
4.45
4.50
4.55
Volt
±0.2
±1.0
%Span
0.20
0.25
0.30
Volt
±0.5
±1.0
%Span
±0.1
±0.5
%Span
±0.2
±0.5
% Span
100
uSec
Origina
DS-0023 Rev A
www.allsensors
R
Specification Notes
1) ALL PARAMETERS ARE MEASURED AT 5.0 VOLT EXCITATION, FOR THE NOMINAL FULL SCALE PRESSURE AND ROOM TEMPERATURE UNLESS OTHERWISE SPECIFIED .
PRESSURE MEASUREMENTS ARE WITH POSITIVE PRESSURE APPLIED TO P ORT B. ABSOLUTE DEVICES ARE WITH PRESSURE APPLIED TO PORT A.
2) SHIFT IS RELATIVE TO 25°C.
4) MEASURED AT ONE-HALF FULL SCALE RATED PRESSURE USING BEST STRAIGHT LINE CURVE FIT FOR THE SPAN INDICATED.
5) THE VOLTAGE ADDED TO THE OFFSET VOLTAGE AT FULL SCALE PRESSURE. NOMINALLY THE OUTPUT VOLTAGE RANGE IS 0.25 TO 4.75 VOLTS FOR MINUS TO
PLUS FULL SCALE PRESSURE .
6) PARAMETER IS COMPUTED AS MAXIMUM FOR DESIGN REFERENCE AND IS NOT TESTED.
7) MAXIMUM DIFERENCE IN OUTPUT AT ANY PRESSURE WITHIN THE OPERATING PRESSURE RANGE AND COMPENSATED TEMPERATURE RANGE AFTER: A) 1000
TEMPERATURE CYCLES AND B) 1.0 MILLION PRESSURE CYCLES .
8) RESPONSE TIME FOR A ZERO TO FULL SCALE PRESSURE STEP CHANGE, 10% TO 90% RISE TIME.
Original In Red
Original In Red
4.43
www.allsensors.com
iginal In Red
Units
R
Parameter
Span Shift (0 °C to 70 °C)
R
Maximum
Performance Characteristics for 15/30/100 PSI-x-4V-ASCX
Output Span
www.allsensors.com
Nominal
Original In Red
Original In Red
Minimum
www.allsensors.com
www.allsensors.com
R
Output Span
(5)
R
Performance Characteristics for 1/5 PSI-D-4V-ASCX
Original In Red
Proof Pressure
www.allsensors.com
Operating Pressure
R
Pressure Ranges
Parameter
R
0 to 70°C
250 °C
Part Number
llsensors.com
Compensated Temperature
Original In Red
Environmental Specifications
www.allsensors.com
www.allsensors.com
R
Red
Maximum Ratings
很抱歉,暂时无法提供与“15PSI-D-4V-ASCX”相匹配的价格&库存,您可以联系我们找货
