2W Solar Panel 80X180
SKU 313070003
Description
This solar panel is made of single-crystal material that performs high solar energy transformation
efficiency at 17%. It has a fine resin surface and sturdy back suitable for outdoor environments. A 2mm
JST connecter is attached to the penal, which makes it perfect to team up with most of our can-usesolar-power-supply boards, like Seeeduino microcontroller series, Lipo Rider charging boards
seriesand XBee carrier WSN products series.
The typical open circuit voltage is around 5V, depending on light intensity. In those bright summer days
with clear sky and big sun, the peak OC voltage can rush up to 10V. To prevent any damage to boards
that accept a narrow range of input voltage, like Lipo Rider, it’s recommended to check whether
the OC voltage is safe before any connection
Features
Dimensions: 180x80x2.5(±0.2) mm
Typical voltage: 5.5V
Typical current: 360mA
Open-circuit voltage: 8.2 V
Maximum load voltage: 6.4V
Copyright © 2008-2016 Seeed Development Limited All rights reserved
很抱歉,暂时无法提供与“313070003”相匹配的价格&库存,您可以联系我们找货
