FIT0330
FIT0330
    DFROBOT
    SOLARPANEL(9V220MA)
FIT0330 数据手册
    Solar Panel (9v 220mA) SKU:FIT0330 INTRODUCTION Need a clean energy source for your project? Check out this compact,high quality,high output endurable solar panel.The peak power output is around 9V at 220mA.Can also be used in series to work as recharger for 12V batteries. Ultra-white glass lamination process provides an efficient and waterproof surface for the panel.The back of the panel has separate aluminium wires. Note:The above refers to the electrical performance parameters measured under standard test conditions, namely: light intensity 1000W / ㎡, spectrum AM1.5, cell temperature 25 Ԩ APPLICATIONS    Solar Powering Transport sector Communication / communications Specification         Working voltage: 9V Operating Current: 220mA Open circuit voltage: 9.6V Short circuit current: 500mA Power: 2W Use of the environment: -40 Ԩ ~ 80 Ԩ Performance: corrosion, moisture Size: Length 135mm(5.31") X width 125mm(4.92") Powered By DFRobot © 2008-2017
FIT0330 价格&库存
很抱歉,暂时无法提供与“FIT0330”相匹配的价格&库存,您可以联系我们找货
FIT0330
    库存:4
