1525
1525
    ADAFRUIT
    SOLAR PANEL LARGE 6V 5.6W
1525 数据手册
Page 1 of 2 POWER / SOLAR Huge 6V 5.6W Solar panel PRODUCT ID: 1525 Page 2 of 2 DESCRIPTION - These panels come to us from Voltaic Systems, makers of fine solar-powered bags and packs. These are waterproof, scratch resistant, and UV resistant. They use a high efficiency monocrystalline cell. They output 6V at 930 mA via 3.5mm x 1.3mm DC jack connector - a nice upgrade to the 2W or 3W panels we have been carrying. The substrate is an aluminum / plastic composite, specifically designed to be strong and lightweight. They can easily stand up to typical outdoor use including being dropped and leaned on. They're very high quality and suggested for projects that will be exposed to the outdoors. These now come with 4 plastic mounting screws which makes it easy to attach the panel, even to fabric! To connect, we suggest a 3.8mm OD/1.3mm ID DC jack If you want to use this to charge a battery or run your project, check out our optimized Solar Lithium Ion/Polymer charger! For some nifty ideas on what to do with your solar panels, check out Voltaic's DIY page http://www.adafruit.com/products/1525 7/24/2015
很抱歉,暂时无法提供与“1525”相匹配的价格&库存,您可以联系我们找货
