OMNIIRBP1277
OMNIIRBP1277
    THOMASRESEARCHPRODUCTS
    INFRARED CEILING SENSOR
OMNIIRBP1277 数据手册
BP1277 Installation Instructions DESCRIPTION The BP1277 is a permanently connected, outlet box mounted, combination universal power supply (120-277VAC) and switching relay. The device is electrically connected to a Class 2, OMNI® series occupancy sensor and the two devices are twist locked together to form an integral line voltage occupancy sensor. The BP1277 provides a 24VDC, Class 2 supply for the sensor and controls power to the light load in response to the sensor’s occupancy signal. PRECAUTIONS CAUTION: RISK OF ELECTRICAL SHOCK. Turn power off at service panel before beginning installation. Never wire energized electrical components. More than one disconnect switch may be required to de-energize the equipment before servicing. Read and understand all instructions before beginning installation. NOTICE: For installation by a licensed electrician in accordance to national and/ or local electrical codes and the following instructions. NOTICE: For indoor use only. CAUTION: USE COPPER CONDUCTORS ONLY Confirm that the device ratings are suitable for application prior to installation. NOTICE: Do not install if any damage to the product is noticed. INSTALLATION 1. 2. 3. 4. 5. 6. 7. 8. Turn power off at the service panel. If power pack is shipped with sensor, disconnect sensor from power pack by rotating the sensor until it unlocks, then disconnecting the Quick-to-Install (QTI) connectors. Electrically connect the power pack to the building and load wiring as shown in the wiring diagram. Use approved wire nuts for all electrical connections (Figure 1). Mount power pack in single gang mud ring secured to a four inch square electrical box (Figure 2). Use screws (not included) as appropriate to application. NOTE: The OmniBP will fit on the following boxes or adapters: A round 1 gang mud ring with 2-3/4" OC mounting holes. (RACO # 756-759, 767 or similar). A 4” octagon box (RACO #125 or similar). Connect sensor to power pack using QTI connector. Tuck QTI connector into pocket of power pack cover plate. Twist sensor on to power pack mounting plate until secured (Figure 3). Restore power at the service panel. Figure 1 Figure 2 Figure 3 9601 Dessau Road | Building One | Austin, Texas 78754 512-450-1100 | 512-450-1215 fax | www.hubbell-automation.com 72-00515 REV B
OMNIIRBP1277 价格&库存
很抱歉,暂时无法提供与“OMNIIRBP1277”相匹配的价格&库存,您可以联系我们找货
