Inductive Proximity Sensors
M12 Inductive Proximity Sensors
Standard Length
“Mini's”
Extended Sensing
3 Wire DC
2 Wire DC
2 Wire AC
(Wiring Schematic)
3 Wire DC
2 Wire DC
PNP – Normally Open
(1)
IMM32122C
IMM35124C
IMN32122C
IMN35124C
IMN32122M12
PNP – Normally Closed
(1)
IMM33122C
IMM36124C
IMN33122C
IMN36124C
IMN33122M12
PNP – Selectable
(4)
IMM34122C
IMM37124C
IMN34122C
IMN37124C
IMN34122M12
NPN – Normally Open
(2)
IMM22122C
IMM25124C
IMN22122C
IMN25124C
IMN22122M12
NPN – Normally Closed
(2)
IMM23122C
IMM26124C
IMN23122C
IMN26124C
IMN23122M12
NPN – Selectable
(5)
IMM24122C
IMM27124C
IMN24122C
IMN27124C
IMN24122M12
M12 Shielded
M12 Non-Shielded
M12 Shielded
M12 Non-Shielded
M12 Shielded
2mm
4mm
2mm
4mm
2mm
2.0 Meter Cable
M12 Connector
1kHz
1.5kHz
Normally Open
Normally Closed
2 Wire AC
Normally Open
Normally Closed
Mating cables / connectors
Form
Nominal Sensing Distance (Sn)
Nickel Plated Brass
Housing Material
Termination Type
2.0 Meter Cable
2.0 Meter Cable
Min / Max Supply Voltage
10 to 30Vdc
Max. Load Current (Ir)
200mA
≤ 10%
Max ripple factor (Vr)
Voltage Drop (Ud)
≤ 3V @ 200mA
Power Consumption (Io)
Switching Frequency (Hz)
Repeatability
Hysteresis
Short Circuit Protection
Output LED
Operating Temperature
IP Rating
2.0 Meter Cable
≤ 10mA
1.5kHz
1kHz
1.5kHz
< 2% nominal sensing distance
≤ 10% Sn
Yes
Yes
-25 to +70 C
IP67 (with connector mounted)
Wiring Diagram
For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com
PNP – NO
IMN35124M12
IMN32122P
IMN35124P
IMC32122C
IMC35124C
IMC32122M12
IMC35124M12
PNP – NC
IMN36124M12
IMN33122P
IMN36124P
IMC33122C
IMC36124C
IMC33122M12
IMC36124M12
PNP – NO/NC
IMN37124M12
IMN34122P
IMN37124P
IMC34122C
IMC36124C
IMC34122M12
IMC37124M12
NPN – NO
IMN25124M12
IMN22122P
IMN25124P
IMC22122C
IMC25124C
IMC22122M12
IMC25124M12
NPN – NC
IMN26124M12
IMN23122P
IMN26124P
IMC23122C
IMC26124C
IMC23122M12
IMC26124M12
NPN – NO/NC
IMN27124M12
IMN24122P
IMN27124P
IMC24122C
IMC26124C
IMC24122M12
IMC27124M12
2W DC NO
2W DC NC
2W AC NO
2W AC NC
M12 Shielded
M12 Non-Shielded
M12 Shielded
M12 Non-Shielded
M12 Shielded
M12 Non-Shielded
2mm
4mm
2mm
4mm
2mm
4mm
2.0 Meter Cable
M12 Connector
M12 Connector
1kHz
1.5kHz
1kHz
Mates
Form M12 Non-Shielded
Sn
4mm
Nickel Plated Brass
Housing
Termination
M12 Connector
Sub-Base Plug
Sub-Base Plug
200mA
Max Load
≤ 10%
Max ripple
≤ 3V @ 200mA
Ud
≤ 10mA
Io
Hz
Repeatability
Hysteresis
Short Protection
LED
2.0 Meter Cable
10 to 30Vdc
Supply Vdc
1kHz
1.5kHz
1kHz
1.5kHz
≤ 10% Sn
Yes
Yes
Op Temp
-25 to +70 C
IP Rating
Standard Length
“Mini's”
Extended Sensing
3 Wire DC
2 Wire DC
2 Wire AC
(Wiring Schematic)
3 Wire DC
2 Wire DC
PNP – Normally Open
(1)
IMM32124C
IMM35128C
IMN32124C
IMN35128C
IMN32124M12
(1)
IMM33124C
IMM36128C
IMN33124C
IMN36128C
IMN33124M12
PNP – Selectable
(4)
NPN – Normally Open
(2)
IMM22124C
IMM25128C
IMN22124C
IMN25128C
IMN22124M12
(2)
IMM23124C
IMM26128C
IMN23124C
IMN26128C
IMN23124M12
NPN – Selectable
(5)
M12 Shielded
M12 Non-Shielded
M12 Shielded
M12 Non-Shielded
M12 Shielded
4mm
8mm
4mm
8mm
4mm
2.0 Meter Cable
M12 Connector
1kHz
1kHz
Normally Open
Normally Closed
2 Wire AC
Normally Open
Normally Closed
Form
Nickel Plated Brass
Housing Material
Termination Type
2.0 Meter Cable
2.0 Meter Cable
10 to 30Vdc
200mA
≤ 10%
Voltage Drop (Ud)
≤ 3V @ 200mA
Repeatability
Hysteresis
Output LED
IP Rating
2.0 Meter Cable
≤ 10mA
1kHz
1kHz
1kHz
≤ 10% Sn
Yes
Yes
-25 to +70 C
Wiring Diagram
PNP – NO
IMN35128M12
IMN32124P
IMN35128P
IMC32124C
IMC35128C
IMC32124M12
IMC35128M12
PNP – NC
IMN36128M12
IMN33124P
IMN36128P
IMC33124C
IMC36128C
IMC33124M12
IMC36128M12
NPN – NO
IMN25128M12
IMN22124P
IMN25128P
IMC22124C
IMC25128C
IMC22124M12
IMC25128M12
NPN – NC
PNP – NO/NC
IMN26128M12
IMN23124P
IMN26128P
IMC23124C
IMC26128C
IMC23124M12
IMC26128M12
NPN – NO/NC
2W DC NO
2W DC NC
2W AC NO
2W AC NC
M12 Shielded
M12 Non-Shielded
M12 Shielded
M12 Non-Shielded
M12 Shielded
M12 Non-Shielded
4mm
8mm
4mm
8mm
4mm
8mm
2.0 Meter Cable
M12 Connector
M12 Connector
1kHz
1kHz
1kHz
Mates
Sn
8mm
Nickel Plated Brass
Housing
Termination
M12 Connector
Sub-Base Plug
Sub-Base Plug
200mA
Max Load
≤ 10%
Max ripple
≤ 3V @ 200mA
Ud
≤ 10mA
Io
Hz
Repeatability
Hysteresis
Short Protection
LED
2.0 Meter Cable
10 to 30Vdc
Supply Vdc
1kHz
1kHz
1kHz
1kHz
≤ 10% Sn
Yes
Yes
Op Temp
-25 to +70 C
IP Rating
Standard Length
“Mini's”
Extended Sensing
3 Wire DC
2 Wire DC
2 Wire AC
(Wiring Schematic)
3 Wire DC
2 Wire DC
2 Wire AC
PNP – Normally Open
(1)
(1)
PNP – Selectable
(4)
NPN – Normally Open
(2)
(2)
NPN – Selectable
(5)
(6)
IMM42122C
IMM45124C
IMN42122M12
IMN45124M12
Normally Closed
(6)
IMM43122C
IMM46124C
IMN43122M12
IMN46124M12
Normally Open
(7)
IMM62122C
Normally Closed
(7)
IMM63122C
M12 Shielded
M12 Non-Shielded
M12 Shielded
M12 Non-Shielded
M12 Shielded
2mm
4mm
2mm
4mm
2mm
M12 Connector
2.0 Meter Cable
Normally Open
Form
Nickel Plated Brass
Housing Material
Termination Type
2.0 Meter Cable
2.0 Meter Cable
M12 Connector
10 to 30Vdc
20 to 220 Vac
100mA
400 mA
≤ 10%
Voltage Drop (Ud)
≤ 7 Vdc
≤ 4.5Vac
Repeatability
Hysteresis
≤ 0.7mA
1kHz
800 Hz
1kHz
≤ 2.5mA
800 Hz
20 Hz
≤ 10% Sn
Yes
No
Output LED
Yes
Yes
IP Rating
-25 to +70 C
Wiring Diagram
PNP – NO
PNP – NC
PNP – NO/NC
NPN – NO
NPN – NC
NPN – NO/NC
2W DC NO
2W DC NC
2W AC NO
IMM65124C
IMN62122C
IMN65124C
IMN62122M12
IMN65124M12
IMN62122P
IMN65124P
2W AC NC
IMM66124C
IMN63122C
IMN66124C
IMN63122M12
IMN66124M12
IMN63122P
IMN66124P
M12 Shielded
M12 Non-Shielded
M12 Shielded
M12 Non-Shielded
M12 Shielded
M12 Non-Shielded
2mm
4mm
2mm
4mm
2mm
4mm
M12 Connector
Sub-Base Plug
Sub-Base Plug
20 Hz
20 Hz
20 Hz
Mates
Sn
4mm
Nickel Plated Brass
Housing
Termination
2.0 Meter Cable
2.0 Meter Cable
2.0 Meter Cable
400mA
Max Load
Max ripple
≤ 4.5Vac
Ud
≤ 2.5mA
Io
Hz
Repeatability
Hysteresis
M12 Connector
20 to 220Vac
Supply Vdc
20 Hz
20 Hz
20 Hz
20 Hz
≤ 10% Sn
Short Protection
No
LED
Yes
Op Temp
-25 to +70 C
IP Rating
很抱歉,暂时无法提供与“IMC32122M12”相匹配的价格&库存,您可以联系我们找货
