IMN45188M12
IMN45188M12
    CROUZET(高诺斯)
    IPD M18 NONSHLD 2W DC NO M12
IMN45188M12 数据手册
Inductive Proximity Sensors M18 Inductive Proximity Sensors Standard Length “Mini's” Extended Sensing 3 Wire DC 2 Wire DC 2 Wire AC (Wiring Schematic) 3 Wire DC 2 Wire DC PNP – Normally Open (1) IMM32185C IMM35188C IMN32185C IMN35188C IMN32185M12 PNP – Normally Closed (1) IMM33185C IMM36188C IMN33185C IMN36188C IMN33185M12 PNP – Selectable (4) IMM34185C IMM37188C IMN34185C IMN37188C IMN34185M12 NPN – Normally Open (2) IMM22185C IMM25188C IMN22185C IMN25188C IMN22185M12 NPN – Normally Closed (2) IMM23185C IMM26188C IMN23185C IMN26188C IMN23185M12 NPN – Selectable (5) IMM24185C IMM27188C IMN24185C IMN27188C IMN24185M12 - - - - - M18 Shielded M18 Non-Shielded M18 Shielded M18 Non-Shielded M18 Shielded 5mm 8mm 5mm 8mm 5mm 2.0 Meter Cable M12 Connector 700 Hz 700 Hz Normally Open Normally Closed 2 Wire AC Normally Open Normally Closed Mating cables / connectors Form Nominal Sensing Distance (Sn) Nickel Plated Brass Housing Material Termination Type 2.0 Meter Cable 2.0 Meter Cable Min / Max Supply Voltage 10 to 30Vdc Max. Load Current (Ir) 200mA ≤ 10% Max ripple factor (Vr) Voltage Drop (Ud) ≤ 3V @ 200mA Power Consumption (Io) Switching Frequency (Hz) Repeatability Hysteresis Short Circuit Protection Output LED Operating Temperature IP Rating 2.0 Meter Cable ≤ 10mA 700 Hz 700 Hz 700 Hz < 2% nominal sensing distance ≤ 10% Sn Yes Yes -25 to +70 C IP67 (with connector mounted) Wiring Diagram For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Inductive Proximity Sensors PNP – NO IMN35188M12 IMN32185P IMN35188P IMC32185C IMC35188C IMC32185M12 IMC35188M12 PNP – NC IMN36188M12 IMN33185P IMN36188P IMC33185C IMC36188C IMC33185M12 IMC36188M12 PNP – NO/NC IMN37188M12 IMN34185P IMN37188P IMC34185C IMC37188C IMC34185M12 IMC37188M12 NPN – NO IMN25188M12 IMN22185P IMN25188P IMC22185C IMC25188C IMC22185M12 IMC25188M12 NPN – NC IMN26188M12 IMN23185P IMN26188P IMC23185C IMC26188C IMC23185M12 IMC26188M12 NPN – NO/NC IMN27188M12 IMN24185P IMN27188P IMC24185C IMC27188C IMC24185M12 IMC27188M12 2W DC NO - - - - - - - 2W DC NC - - - - - - - 2W AC NO - - - - - - - 2W AC NC - - - - - - - M18 Shielded M18 Non-Shielded M18 Shielded M18 Non-Shielded M18 Shielded M18 Non-Shielded 5mm 8mm 5mm 8mm 5mm 8mm 2.0 Meter Cable M12 Connector M12 Connector 1kHz 1.2kHz 1kHz Mates Form M18 Non-Shielded Sn 8mm Nickel Plated Brass Housing Termination M12 Connector Sub-Base Plug Sub-Base Plug 200mA Max Load ≤ 10% Max ripple ≤ 3V @ 200mA Ud ≤ 10mA Io Hz Repeatability Hysteresis Short Protection LED 2.0 Meter Cable 10 to 30Vdc Supply Vdc 700 Hz 700 Hz 700 Hz 1.2kHz < 2% nominal sensing distance ≤ 10% Sn Yes Yes Op Temp -25 to +70 C IP Rating IP67 (with connector mounted) For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Inductive Proximity Sensors M18 Inductive Proximity Sensors Standard Length “Mini's” Extended Sensing 3 Wire DC 2 Wire DC 2 Wire AC (Wiring Schematic) 3 Wire DC 2 Wire DC PNP – Normally Open (1) IMM32188C IMM351816C IMN32188C IMN351816C IMN32188M12 PNP – Normally Closed (1) IMM33188C IMM361816C IMN33188C IMN361816C IMN33188M12 PNP – Selectable (4) - - - - - NPN – Normally Open (2) IMM22188C IMM251816C IMN22188C IMN251816C IMN22188M12 NPN – Normally Closed (2) IMM23188C IMM261816C IMN23188C IMN261816C IMN23188M12 NPN – Selectable (5) - - - - - - - - - - M18 Shielded M18 Non-Shielded M18 Shielded M18 Non-Shielded M18 Shielded 8mm 16mm 8mm 16mm 8mm 2.0 Meter Cable M12 Connector 400 Hz 700 Hz Normally Open Normally Closed 2 Wire AC Normally Open Normally Closed Mating cables / connectors Form Nominal Sensing Distance (Sn) Nickel Plated Brass Housing Material Termination Type 2.0 Meter Cable 2.0 Meter Cable Min / Max Supply Voltage 10 to 30Vdc Max. Load Current (Ir) 200mA ≤ 10% Max ripple factor (Vr) Voltage Drop (Ud) ≤ 3V @ 200mA Power Consumption (Io) Switching Frequency (Hz) Repeatability Hysteresis Short Circuit Protection Output LED Operating Temperature IP Rating 2.0 Meter Cable ≤ 10mA 700 Hz 400 Hz 700 Hz < 2% nominal sensing distance ≤ 10% Sn Yes Yes -25 to +70 C IP67 (with connector mounted) Wiring Diagram For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Inductive Proximity Sensors PNP – NO IMN351816M12 IMN32188P IMN351816P IMC32188C IMC351816C IMC32188M12 IMC351816M12 PNP – NC IMN361816M12 IMN33188P IMN361816P IMC33188C IMC361816C IMC33188M12 IMC361816M12 - - - - - - - NPN – NO IMN251816M12 IMN22188P IMN251816P IMC22188C IMC251816C IMC22188M12 IMC251816M12 NPN – NC PNP – NO/NC IMN261816M12 IMN23188P IMN261816P IMC23188C IMC261816C IMC23188M12 IMC261816M12 NPN – NO/NC - - - - - - - 2W DC NO - - - - - - - 2W DC NC - - - - - - - 2W AC NO - - - - - - - 2W AC NC - - - - - - - M18 Shielded M18 Non-Shielded M18 Shielded M18 Non-Shielded M18 Shielded M18 Non-Shielded 8mm 16mm 8mm 16mm 8mm 16mm 2.0 Meter Cable M12 Connector M12 Connector 700Hz 400Hz Mates Form M18 Non-Shielded Sn 16mm Nickel Plated Brass Housing Termination M12 Connector Sub-Base Plug Sub-Base Plug 200mA Max Load ≤ 10% Max ripple ≤ 3V @ 200mA Ud ≤ 1.8V ≤ 10mA Io Hz Repeatability Hysteresis Short Protection LED 2.0 Meter Cable 10 to 30Vdc Supply Vdc 400 Hz 700 Hz 400 Hz 700Hz 400Hz < 2% nominal sensing distance ≤ 10% Sn Yes Yes Op Temp -25 to +70 C IP Rating IP67 (with connector mounted) For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Inductive Proximity Sensors M18 Inductive Proximity Sensors Standard Length “Mini's” Extended Sensing 3 Wire DC 2 Wire DC 2 Wire AC (Wiring Schematic) 3 Wire DC 2 Wire DC 2 Wire AC PNP – Normally Open (1) - - - - - PNP – Normally Closed (1) - - - - - PNP – Selectable (4) - - - - - NPN – Normally Open (2) - - - - - NPN – Normally Closed (2) - - - - - NPN – Selectable (5) - - - - - (6) IMM42185C IMM45188C IMN42185M12 IMN45188M12 - Normally Closed (6) IMM43185C IMM46188C IMN43185M12 IMN46188M12 - Normally Open (7) - - - - IMM62185C Normally Closed (7) - - - - IMM63185C M18 Shielded M18 Non-Shielded M18 Shielded M18 Non-Shielded M18 Shielded 5mm 8mm 5mm 8mm 5mm M12 Connector 2.0 Meter Cable Normally Open Mating cables / connectors Form Nominal Sensing Distance (Sn) Nickel Plated Brass Housing Material Termination Type 2.0 Meter Cable 2.0 Meter Cable Min / Max Supply Voltage Max. Load Current (Ir) M12 Connector 10 to 30Vdc 20 to 220 Vac 100mA 400 mA Max ripple factor (Vr) ≤ 10% - Voltage Drop (Ud) ≤ 7 Vdc ≤ 4.5Vac Power Consumption (Io) Switching Frequency (Hz) Repeatability Hysteresis ≤ 0.7mA 700 Hz 400 Hz 700 Hz ≤ 2.5mA 400 Hz 20 Hz < 2% nominal sensing distance ≤ 10% Sn Short Circuit Protection Yes No Output LED Yes Yes Operating Temperature IP Rating -25 to +70 C IP67 (with connector mounted) Wiring Diagram For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Inductive Proximity Sensors PNP – NO - - - - - - - PNP – NC - - - - - - - PNP – NO/NC - - - - - - - NPN – NO - - - - - - - - - - - - NPN – NC NPN – NO/NC - - - - - - - 2W DC NO - - - - - - - 2W DC NC - - - - - - - 2W AC NO IMM65188C IMN62185C IMN65188C IMN62185M12 IMN65188M12 IMN62185P IMN65188P 2W AC NC IMM66188C IMN63185C IMN66188C IMN63185M12 IMN66188M12 IMN63185P IMN66188P M18 Shielded M18 Non-Shielded M18 Shielded M18 Non-Shielded M18 Shielded M18 Non-Shielded 8mm 16mm 8mm 16mm 8mm 16mm M12 Connector Sub-Base Plug Sub-Base Plug 20 Hz 20 Hz 20 Hz Mates Form M18 Non-Shielded Sn 16mm Nickel Plated Brass Housing Termination 2.0 Meter Cable 2.0 Meter Cable 2.0 Meter Cable 400mA Max Load - Max ripple ≤ 4.5Vac Ud ≤ 2.5mA Io Hz Repeatability Hysteresis M12 Connector 20 to 220Vac Supply Vdc 20 Hz 20 Hz 20 Hz 20 Hz < 2% nominal sensing distance ≤ 10% Sn Short Protection No LED Yes Op Temp -25 to +70 C IP Rating IP67 (with connector mounted) For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com
IMN45188M12
物料型号: - 3线DC型:IMM32185C, IMM35188C, IMN32185C, IMN35188C, IMN32185M12等 - 2线DC型:未列出具体型号 - 2线AC型:IMM62185C, IMM63185C, IMN62185C, IMN63185C等
器件简介: - 接近传感器用于检测金属物体的接近,具有不同的感应距离和输出类型。
引脚分配: - 3线DC型传感器具有PNP和NPN输出选项,包括常开(NO)、常闭(NC)和可切换(NO/NC)配置。
参数特性: - 供电电压范围:10到30V直流或20到220V交流 - 最大负载电流:直流200mA,交流400mA - 电压降:直流≤3V@200mA,交流≤4.5Vac - 功耗:直流≤10mA,交流≤2.5mA - 开关频率:直流700Hz/400Hz,交流20Hz - 重复性:小于2%的名义感应距离 - 滞后:10%的名义感应距离 - 短路保护:是
功能详解: - 输出类型包括PNP和NPN,具有不同的逻辑配置。 - 有LED指示灯显示传感器状态。
应用信息: - 工作温度范围:-25至+70摄氏度 - IP等级:IP67(安装连接器后)
封装信息: - 传感器采用镀镍黄铜材料,有M12连接器和2米电缆的终止类型。
IMN45188M12 价格&库存
很抱歉,暂时无法提供与“IMN45188M12”相匹配的价格&库存,您可以联系我们找货
