Inductive Proximity Sensors
M18 Inductive Proximity Sensors
Standard Length
“Mini's”
Extended Sensing
3 Wire DC
2 Wire DC
2 Wire AC
(Wiring Schematic)
3 Wire DC
2 Wire DC
PNP – Normally Open
(1)
IMM32185C
IMM35188C
IMN32185C
IMN35188C
IMN32185M12
PNP – Normally Closed
(1)
IMM33185C
IMM36188C
IMN33185C
IMN36188C
IMN33185M12
PNP – Selectable
(4)
IMM34185C
IMM37188C
IMN34185C
IMN37188C
IMN34185M12
NPN – Normally Open
(2)
IMM22185C
IMM25188C
IMN22185C
IMN25188C
IMN22185M12
NPN – Normally Closed
(2)
IMM23185C
IMM26188C
IMN23185C
IMN26188C
IMN23185M12
NPN – Selectable
(5)
IMM24185C
IMM27188C
IMN24185C
IMN27188C
IMN24185M12
M18 Shielded
M18 Non-Shielded
M18 Shielded
M18 Non-Shielded
M18 Shielded
5mm
8mm
5mm
8mm
5mm
2.0 Meter Cable
M12 Connector
700 Hz
700 Hz
Normally Open
Normally Closed
2 Wire AC
Normally Open
Normally Closed
Mating cables / connectors
Form
Nominal Sensing Distance (Sn)
Nickel Plated Brass
Housing Material
Termination Type
2.0 Meter Cable
2.0 Meter Cable
Min / Max Supply Voltage
10 to 30Vdc
Max. Load Current (Ir)
200mA
≤ 10%
Max ripple factor (Vr)
Voltage Drop (Ud)
≤ 3V @ 200mA
Power Consumption (Io)
Switching Frequency (Hz)
Repeatability
Hysteresis
Short Circuit Protection
Output LED
Operating Temperature
IP Rating
2.0 Meter Cable
≤ 10mA
700 Hz
700 Hz
700 Hz
< 2% nominal sensing distance
≤ 10% Sn
Yes
Yes
-25 to +70 C
IP67 (with connector mounted)
Wiring Diagram
For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com
PNP – NO
IMN35188M12
IMN32185P
IMN35188P
IMC32185C
IMC35188C
IMC32185M12
IMC35188M12
PNP – NC
IMN36188M12
IMN33185P
IMN36188P
IMC33185C
IMC36188C
IMC33185M12
IMC36188M12
PNP – NO/NC
IMN37188M12
IMN34185P
IMN37188P
IMC34185C
IMC37188C
IMC34185M12
IMC37188M12
NPN – NO
IMN25188M12
IMN22185P
IMN25188P
IMC22185C
IMC25188C
IMC22185M12
IMC25188M12
NPN – NC
IMN26188M12
IMN23185P
IMN26188P
IMC23185C
IMC26188C
IMC23185M12
IMC26188M12
NPN – NO/NC
IMN27188M12
IMN24185P
IMN27188P
IMC24185C
IMC27188C
IMC24185M12
IMC27188M12
2W DC NO
2W DC NC
2W AC NO
2W AC NC
M18 Shielded
M18 Non-Shielded
M18 Shielded
M18 Non-Shielded
M18 Shielded
M18 Non-Shielded
5mm
8mm
5mm
8mm
5mm
8mm
2.0 Meter Cable
M12 Connector
M12 Connector
1kHz
1.2kHz
1kHz
Mates
Form M18 Non-Shielded
Sn
8mm
Nickel Plated Brass
Housing
Termination
M12 Connector
Sub-Base Plug
Sub-Base Plug
200mA
Max Load
≤ 10%
Max ripple
≤ 3V @ 200mA
Ud
≤ 10mA
Io
Hz
Repeatability
Hysteresis
Short Protection
LED
2.0 Meter Cable
10 to 30Vdc
Supply Vdc
700 Hz
700 Hz
700 Hz
1.2kHz
≤ 10% Sn
Yes
Yes
Op Temp
-25 to +70 C
IP Rating
Standard Length
“Mini's”
Extended Sensing
3 Wire DC
2 Wire DC
2 Wire AC
(Wiring Schematic)
3 Wire DC
2 Wire DC
PNP – Normally Open
(1)
IMM32188C
IMM351816C
IMN32188C
IMN351816C
IMN32188M12
(1)
IMM33188C
IMM361816C
IMN33188C
IMN361816C
IMN33188M12
PNP – Selectable
(4)
NPN – Normally Open
(2)
IMM22188C
IMM251816C
IMN22188C
IMN251816C
IMN22188M12
(2)
IMM23188C
IMM261816C
IMN23188C
IMN261816C
IMN23188M12
NPN – Selectable
(5)
M18 Shielded
M18 Non-Shielded
M18 Shielded
M18 Non-Shielded
M18 Shielded
8mm
16mm
8mm
16mm
8mm
2.0 Meter Cable
M12 Connector
400 Hz
700 Hz
Normally Open
Normally Closed
2 Wire AC
Normally Open
Normally Closed
Form
Nickel Plated Brass
Housing Material
Termination Type
2.0 Meter Cable
2.0 Meter Cable
10 to 30Vdc
200mA
≤ 10%
Voltage Drop (Ud)
≤ 3V @ 200mA
Repeatability
Hysteresis
Output LED
IP Rating
2.0 Meter Cable
≤ 10mA
700 Hz
400 Hz
700 Hz
≤ 10% Sn
Yes
Yes
-25 to +70 C
Wiring Diagram
PNP – NO
IMN351816M12
IMN32188P
IMN351816P
IMC32188C
IMC351816C
IMC32188M12
IMC351816M12
PNP – NC
IMN361816M12
IMN33188P
IMN361816P
IMC33188C
IMC361816C
IMC33188M12
IMC361816M12
NPN – NO
IMN251816M12
IMN22188P
IMN251816P
IMC22188C
IMC251816C
IMC22188M12
IMC251816M12
NPN – NC
PNP – NO/NC
IMN261816M12
IMN23188P
IMN261816P
IMC23188C
IMC261816C
IMC23188M12
IMC261816M12
NPN – NO/NC
2W DC NO
2W DC NC
2W AC NO
2W AC NC
M18 Shielded
M18 Non-Shielded
M18 Shielded
M18 Non-Shielded
M18 Shielded
M18 Non-Shielded
8mm
16mm
8mm
16mm
8mm
16mm
2.0 Meter Cable
M12 Connector
M12 Connector
700Hz
400Hz
Mates
Sn
16mm
Nickel Plated Brass
Housing
Termination
M12 Connector
Sub-Base Plug
Sub-Base Plug
200mA
Max Load
≤ 10%
Max ripple
≤ 3V @ 200mA
Ud
≤ 1.8V
≤ 10mA
Io
Hz
Repeatability
Hysteresis
Short Protection
LED
2.0 Meter Cable
10 to 30Vdc
Supply Vdc
400 Hz
700 Hz
400 Hz
700Hz
400Hz
≤ 10% Sn
Yes
Yes
Op Temp
-25 to +70 C
IP Rating
Standard Length
“Mini's”
Extended Sensing
3 Wire DC
2 Wire DC
2 Wire AC
(Wiring Schematic)
3 Wire DC
2 Wire DC
2 Wire AC
PNP – Normally Open
(1)
(1)
PNP – Selectable
(4)
NPN – Normally Open
(2)
(2)
NPN – Selectable
(5)
(6)
IMM42185C
IMM45188C
IMN42185M12
IMN45188M12
Normally Closed
(6)
IMM43185C
IMM46188C
IMN43185M12
IMN46188M12
Normally Open
(7)
IMM62185C
Normally Closed
(7)
IMM63185C
M18 Shielded
M18 Non-Shielded
M18 Shielded
M18 Non-Shielded
M18 Shielded
5mm
8mm
5mm
8mm
5mm
M12 Connector
2.0 Meter Cable
Normally Open
Form
Nickel Plated Brass
Housing Material
Termination Type
2.0 Meter Cable
2.0 Meter Cable
M12 Connector
10 to 30Vdc
20 to 220 Vac
100mA
400 mA
≤ 10%
Voltage Drop (Ud)
≤ 7 Vdc
≤ 4.5Vac
Repeatability
Hysteresis
≤ 0.7mA
700 Hz
400 Hz
700 Hz
≤ 2.5mA
400 Hz
20 Hz
≤ 10% Sn
Yes
No
Output LED
Yes
Yes
IP Rating
-25 to +70 C
Wiring Diagram
PNP – NO
PNP – NC
PNP – NO/NC
NPN – NO
NPN – NC
NPN – NO/NC
2W DC NO
2W DC NC
2W AC NO
IMM65188C
IMN62185C
IMN65188C
IMN62185M12
IMN65188M12
IMN62185P
IMN65188P
2W AC NC
IMM66188C
IMN63185C
IMN66188C
IMN63185M12
IMN66188M12
IMN63185P
IMN66188P
M18 Shielded
M18 Non-Shielded
M18 Shielded
M18 Non-Shielded
M18 Shielded
M18 Non-Shielded
8mm
16mm
8mm
16mm
8mm
16mm
M12 Connector
Sub-Base Plug
Sub-Base Plug
20 Hz
20 Hz
20 Hz
Mates
Sn
16mm
Nickel Plated Brass
Housing
Termination
2.0 Meter Cable
2.0 Meter Cable
2.0 Meter Cable
400mA
Max Load
Max ripple
≤ 4.5Vac
Ud
≤ 2.5mA
Io
Hz
Repeatability
Hysteresis
M12 Connector
20 to 220Vac
Supply Vdc
20 Hz
20 Hz
20 Hz
20 Hz
≤ 10% Sn
Short Protection
No
LED
Yes
Op Temp
-25 to +70 C
IP Rating
很抱歉,暂时无法提供与“IMN24185M12”相匹配的价格&库存,您可以联系我们找货
