Inductive Proximity Sensors
M30 Inductive Proximity Sensors
Standard Length
“Mini's”
Extended Sensing
3 Wire DC
2 Wire DC
2 Wire AC
(Wiring Schematic)
3 Wire DC
2 Wire DC
PNP – Normally Open
(1)
IMM323010C
IMM353015C
IMN323010C
IMN353015C
IMN323010M12
PNP – Normally Closed
(1)
IMM333010C
IMM363015C
IMN333010C
IMN363015C
IMN333010M12
PNP – Selectable
(4)
IMM343010C
IMM373015C
IMN343010C
IMN373015C
IMN343010M12
NPN – Normally Open
(2)
IMM223010C
IMM253015C
IMN223010C
IMN253015C
IMN223010M12
NPN – Normally Closed
(2)
IMM233010C
IMM263015C
IMN233010C
IMN263015C
IMN233010M12
NPN – Selectable
(5)
IMM243010C
IMM273015C
IMN243010C
IMN273015C
IMN243010M12
M30 Shielded
M30 Non-Shielded
M30 Shielded
M30 Non-Shielded
M30 Shielded
10mm
15mm
10mm
15mm
10mm
2.0 Meter Cable
M12 Connector
200 Hz
200 Hz
Normally Open
Normally Closed
2 Wire AC
Normally Open
Normally Closed
Mating cables / connectors
Form
Nominal Sensing Distance (Sn)
Nickel Plated Brass
Housing Material
Termination Type
2.0 Meter Cable
2.0 Meter Cable
Min / Max Supply Voltage
10 to 30Vdc
Max. Load Current (Ir)
200mA
≤ 10%
Max ripple factor (Vr)
Voltage Drop (Ud)
≤ 3V @ 200mA
Power Consumption (Io)
Switching Frequency (Hz)
Repeatability
Hysteresis
Short Circuit Protection
Output LED
Operating Temperature
IP Rating
2.0 Meter Cable
≤ 10mA
200 Hz
200 Hz
200 Hz
< 2% nominal sensing distance
≤ 10% Sn
Yes
Yes
-25 to +70 C
IP67 (with connector mounted)
Wiring Diagram
For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com
PNP – NO
IMN353015M12
IMN323010P
IMN353015P
IMC323010C
IMC353015C
IMC323010M12 IMC353015M12
PNP – NC
IMN363015M12
IMN333010P
IMN363015P
IMC333010C
IMC363015C
IMC333010M12 IMC363015M12
PNP – NO/NC
IMN373015M12
IMN343010P
IMN373015P
IMC343010C
IMC373015C
IMC343010M12 IMC373015M12
NPN – NO
IMN253015M12
IMN223010P
IMN253015P
IMC223010C
IMC253015C
IMC223010M12 IMC253015M12
NPN – NC
IMN263015M12
IMN233010P
IMN263015P
IMC233010C
IMC263015C
IMC233010M12 IMC263015M12
NPN – NO/NC
IMN273015M12
IMN243010P
IMN273015P
IMC243010C
IMC273015C
IMC243010M12 IMC273015M12
2W DC NO
2W DC NC
2W AC NO
2W AC NC
M30 Shielded
M30 Non-Shielded
M30 Shielded
M30 Non-Shielded
M30 Shielded
M30 Non-Shielded
10mm
15mm
10mm
15mm
10mm
15mm
2.0 Meter Cable
M12 Connector
M12 Connector
200 Hz
200 Hz
200 Hz
Mates
Form M30 Non-Shielded
Sn
15mm
Nickel Plated Brass
Housing
Termination
M12 Connector
Sub-Base Plug
Sub-Base Plug
200mA
Max Load
≤ 10%
Max ripple
≤ 3V @ 200mA
Ud
≤ 10mA
Io
Hz
Repeatability
Hysteresis
Short Protection
LED
2.0 Meter Cable
10 to 30Vdc
Supply Vdc
200 Hz
200 Hz
200 Hz
200 Hz
≤ 10% Sn
Yes
Yes
Op Temp
-25 to +70 C
IP Rating
Standard Length
“Mini's”
Extended Sensing
3 Wire DC
2 Wire DC
2 Wire AC
(Wiring Schematic)
3 Wire DC
2 Wire DC
PNP – Normally Open
(1)
IMM323020C
IMM353035C
IMN323020C
IMN353035C
IMN323020M12
(1)
IMM333020C
IMM363035C
IMN333020C
IMN363035C
IMN333020M12
PNP – Selectable
(4)
NPN – Normally Open
(2)
IMM223020C
IMM253035C
IMN223020C
IMN253035C
IMN223020M12
(2)
IMM233020C
IMM263035C
IMN233020C
IMN263035C
IMN233020M12
NPN – Selectable
(5)
M30 Shielded
M30 Non-Shielded
M30 Shielded
M30 Non-Shielded
M30 Shielded
20mm
35mm
20mm
35mm
20mm
2.0 Meter Cable
M12 Connector
100 Hz
200 Hz
Normally Open
Normally Closed
2 Wire AC
Normally Open
Normally Closed
Form
Nickel Plated Brass
Housing Material
Termination Type
2.0 Meter Cable
2.0 Meter Cable
10 to 30Vdc
200mA
≤ 10%
Voltage Drop (Ud)
≤ 3V @ 200mA
Repeatability
Hysteresis
Output LED
IP Rating
2.0 Meter Cable
≤ 10mA
200 Hz
100 Hz
200 Hz
≤ 10% Sn
Yes
Yes
-25 to +70 C
Wiring Diagram
PNP – NO
IMN353035M12
IMN323020P
IMN353035P
IMC323020C
IMC353035C
IMC323020M12 IMC353035M12
PNP – NC
IMN363035M12
IMN333020P
IMN363035P
IMC333020C
IMC363035C
IMC333020M12 IMC363035M12
NPN – NO
IMN253035M12
IMN223020P
IMN253035P
IMC223020C
IMC253035C
IMC223020M12 IMC253035M12
NPN – NC
IMC233020M12 IMC263035M12
PNP – NO/NC
IMN263035M12
IMN233020P
IMN263035P
IMC233020C
IMC263035C
NPN – NO/NC
2W DC NO
2W DC NC
2W AC NO
2W AC NC
M30 Shielded
M30 Non-Shielded
M30 Shielded
M30 Non-Shielded
M30 Shielded
M30 Non-Shielded
20mm
35mm
20mm
35mm
20mm
35mm
2.0 Meter Cable
M12 Connector
M12 Connector
200Hz
100Hz
Mates
Sn
35mm
Nickel Plated Brass
Housing
Termination
M12 Connector
Sub-Base Plug
Sub-Base Plug
200mA
Max Load
≤ 10%
Max ripple
≤ 3V @ 200mA
Ud
≤ 1.8Vdc
≤ 10mA
Io
Hz
Repeatability
Hysteresis
Short Protection
LED
2.0 Meter Cable
10 to 30Vdc
Supply Vdc
100Hz
200Hz
100Hz
200Hz
100Hz
≤ 10% Sn
Yes
Yes
Op Temp
-25 to +70 C
IP Rating
Standard Length
“Mini's”
Extended Sensing
3 Wire DC
2 Wire DC
2 Wire AC
(Wiring Schematic)
3 Wire DC
2 Wire DC
2 Wire AC
PNP – Normally Open
(1)
(1)
PNP – Selectable
(4)
NPN – Normally Open
(2)
(2)
NPN – Selectable
(5)
(6)
IMM423010C
IMM453015C
IMN423010M12 IMN453015M12
IMM623010C
Normally Closed
(6)
IMM433010C
IMM463015C
IMN433010M12 IMN463015M12
IMM633010C
Normally Open
(7)
Normally Closed
(7)
M30 Shielded
M30 Non-Shielded
M30 Shielded
M30 Non-Shielded
M30 Shielded
10mm
15mm
10mm
15mm
10mm
M12 Connector
2.0 Meter Cable
Normally Open
Form
Nickel Plated Brass
Housing Material
Termination Type
2.0 Meter Cable
2.0 Meter Cable
Voltage Drop (Ud)
Repeatability
Hysteresis
M12 Connector
10 to 30Vdc
20 to 220 Vac
100mA
400 mA
≤ 10%
≤ 7.5 Vdc
≤ 4.5Vac
≤ 0.7mA
200 Hz
200 Hz
200 Hz
≤ 2.5mA
200 Hz
20 Hz
≤ 10% Sn
Yes
No
Output LED
Yes
Yes
IP Rating
-25 to +70 C
Wiring Diagram
PNP – NO
PNP – NC
PNP – NO/NC
NPN – NO
NPN – NC
NPN – NO/NC
2W DC NO
2W DC NC
2W AC NO
IMM653015C
IMN623010M12 IMN653015M12
IMN623010P
IMN653015P
2W AC NC
IMM663015C
IMN633010M12 IMN663015M12
IMN633010P
IMN663015P
Mates
Sn
15mm
M30 Shielded
M30 Non-Shielded
M30 Shielded
M30 Non-Shielded
10mm
15mm
10mm
15mm
Nickel Plated Brass
Housing
Termination
2.0 Meter Cable
M12 Connector
M12 Connector
Max ripple
≤ 4.5Vac
Ud
≤ 2.5mA
Io
Repeatability
Hysteresis
Sub-Base Plug
400mA
Max Load
Hz
Sub-Base Plug
20 to 220Vac
Supply Vdc
20 Hz
20 Hz
20 Hz
20 Hz
20 Hz
≤ 10% Sn
Short Protection
No
LED
Yes
Op Temp
-25 to +70 C
IP Rating
很抱歉,暂时无法提供与“IMN253035C”相匹配的价格&库存,您可以联系我们找货
