IMM653015C
IMM653015C
    CROUZET(高诺斯)
    IPD M30 NONSHLD 2W AC SPST 2M
IMM653015C 数据手册
Inductive Proximity Sensors M30 Inductive Proximity Sensors Standard Length “Mini's” Extended Sensing 3 Wire DC 2 Wire DC 2 Wire AC (Wiring Schematic) 3 Wire DC 2 Wire DC PNP – Normally Open (1) IMM323010C IMM353015C IMN323010C IMN353015C IMN323010M12 PNP – Normally Closed (1) IMM333010C IMM363015C IMN333010C IMN363015C IMN333010M12 PNP – Selectable (4) IMM343010C IMM373015C IMN343010C IMN373015C IMN343010M12 NPN – Normally Open (2) IMM223010C IMM253015C IMN223010C IMN253015C IMN223010M12 NPN – Normally Closed (2) IMM233010C IMM263015C IMN233010C IMN263015C IMN233010M12 NPN – Selectable (5) IMM243010C IMM273015C IMN243010C IMN273015C IMN243010M12 - - - - - M30 Shielded M30 Non-Shielded M30 Shielded M30 Non-Shielded M30 Shielded 10mm 15mm 10mm 15mm 10mm 2.0 Meter Cable M12 Connector 200 Hz 200 Hz Normally Open Normally Closed 2 Wire AC Normally Open Normally Closed Mating cables / connectors Form Nominal Sensing Distance (Sn) Nickel Plated Brass Housing Material Termination Type 2.0 Meter Cable 2.0 Meter Cable Min / Max Supply Voltage 10 to 30Vdc Max. Load Current (Ir) 200mA ≤ 10% Max ripple factor (Vr) Voltage Drop (Ud) ≤ 3V @ 200mA Power Consumption (Io) Switching Frequency (Hz) Repeatability Hysteresis Short Circuit Protection Output LED Operating Temperature IP Rating 2.0 Meter Cable ≤ 10mA 200 Hz 200 Hz 200 Hz < 2% nominal sensing distance ≤ 10% Sn Yes Yes -25 to +70 C IP67 (with connector mounted) Wiring Diagram For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Inductive Proximity Sensors PNP – NO IMN353015M12 IMN323010P IMN353015P IMC323010C IMC353015C IMC323010M12 IMC353015M12 PNP – NC IMN363015M12 IMN333010P IMN363015P IMC333010C IMC363015C IMC333010M12 IMC363015M12 PNP – NO/NC IMN373015M12 IMN343010P IMN373015P IMC343010C IMC373015C IMC343010M12 IMC373015M12 NPN – NO IMN253015M12 IMN223010P IMN253015P IMC223010C IMC253015C IMC223010M12 IMC253015M12 NPN – NC IMN263015M12 IMN233010P IMN263015P IMC233010C IMC263015C IMC233010M12 IMC263015M12 NPN – NO/NC IMN273015M12 IMN243010P IMN273015P IMC243010C IMC273015C IMC243010M12 IMC273015M12 2W DC NO - - - - - - - 2W DC NC - - - - - - - 2W AC NO - - - - - - - 2W AC NC - - - - - - - M30 Shielded M30 Non-Shielded M30 Shielded M30 Non-Shielded M30 Shielded M30 Non-Shielded 10mm 15mm 10mm 15mm 10mm 15mm 2.0 Meter Cable M12 Connector M12 Connector 200 Hz 200 Hz 200 Hz Mates Form M30 Non-Shielded Sn 15mm Nickel Plated Brass Housing Termination M12 Connector Sub-Base Plug Sub-Base Plug 200mA Max Load ≤ 10% Max ripple ≤ 3V @ 200mA Ud ≤ 10mA Io Hz Repeatability Hysteresis Short Protection LED 2.0 Meter Cable 10 to 30Vdc Supply Vdc 200 Hz 200 Hz 200 Hz 200 Hz < 2% nominal sensing distance ≤ 10% Sn Yes Yes Op Temp -25 to +70 C IP Rating IP67 (with connector mounted) For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Inductive Proximity Sensors M30 Inductive Proximity Sensors Standard Length “Mini's” Extended Sensing 3 Wire DC 2 Wire DC 2 Wire AC (Wiring Schematic) 3 Wire DC 2 Wire DC PNP – Normally Open (1) IMM323020C IMM353035C IMN323020C IMN353035C IMN323020M12 PNP – Normally Closed (1) IMM333020C IMM363035C IMN333020C IMN363035C IMN333020M12 PNP – Selectable (4) - - - - - NPN – Normally Open (2) IMM223020C IMM253035C IMN223020C IMN253035C IMN223020M12 NPN – Normally Closed (2) IMM233020C IMM263035C IMN233020C IMN263035C IMN233020M12 NPN – Selectable (5) - - - - - - - - - - M30 Shielded M30 Non-Shielded M30 Shielded M30 Non-Shielded M30 Shielded 20mm 35mm 20mm 35mm 20mm 2.0 Meter Cable M12 Connector 100 Hz 200 Hz Normally Open Normally Closed 2 Wire AC Normally Open Normally Closed Mating cables / connectors Form Nominal Sensing Distance (Sn) Nickel Plated Brass Housing Material Termination Type 2.0 Meter Cable 2.0 Meter Cable Min / Max Supply Voltage 10 to 30Vdc Max. Load Current (Ir) 200mA ≤ 10% Max ripple factor (Vr) Voltage Drop (Ud) ≤ 3V @ 200mA Power Consumption (Io) Switching Frequency (Hz) Repeatability Hysteresis Short Circuit Protection Output LED Operating Temperature IP Rating 2.0 Meter Cable ≤ 10mA 200 Hz 100 Hz 200 Hz < 2% nominal sensing distance ≤ 10% Sn Yes Yes -25 to +70 C IP67 (with connector mounted) Wiring Diagram For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Inductive Proximity Sensors PNP – NO IMN353035M12 IMN323020P IMN353035P IMC323020C IMC353035C IMC323020M12 IMC353035M12 PNP – NC IMN363035M12 IMN333020P IMN363035P IMC333020C IMC363035C IMC333020M12 IMC363035M12 - - - - - NPN – NO IMN253035M12 IMN223020P IMN253035P IMC223020C IMC253035C IMC223020M12 IMC253035M12 NPN – NC IMC233020M12 IMC263035M12 PNP – NO/NC - - IMN263035M12 IMN233020P IMN263035P IMC233020C IMC263035C NPN – NO/NC - - - - - - - 2W DC NO - - - - - - - 2W DC NC - - - - - - - 2W AC NO - - - - - - - 2W AC NC - - - - - - - M30 Shielded M30 Non-Shielded M30 Shielded M30 Non-Shielded M30 Shielded M30 Non-Shielded 20mm 35mm 20mm 35mm 20mm 35mm 2.0 Meter Cable M12 Connector M12 Connector 200Hz 100Hz Mates Form M30 Non-Shielded Sn 35mm Nickel Plated Brass Housing Termination M12 Connector Sub-Base Plug Sub-Base Plug 200mA Max Load ≤ 10% Max ripple ≤ 3V @ 200mA Ud ≤ 1.8Vdc ≤ 10mA Io Hz Repeatability Hysteresis Short Protection LED 2.0 Meter Cable 10 to 30Vdc Supply Vdc 100Hz 200Hz 100Hz 200Hz 100Hz < 2% nominal sensing distance ≤ 10% Sn Yes Yes Op Temp -25 to +70 C IP Rating IP67 (with connector mounted) For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Inductive Proximity Sensors M30 Inductive Proximity Sensors Standard Length “Mini's” Extended Sensing 3 Wire DC 2 Wire DC 2 Wire AC (Wiring Schematic) 3 Wire DC 2 Wire DC 2 Wire AC PNP – Normally Open (1) - - - - - PNP – Normally Closed (1) - - - - - PNP – Selectable (4) - - - - - NPN – Normally Open (2) - - - - - NPN – Normally Closed (2) - - - - - NPN – Selectable (5) - - - - (6) IMM423010C IMM453015C IMN423010M12 IMN453015M12 IMM623010C Normally Closed (6) IMM433010C IMM463015C IMN433010M12 IMN463015M12 IMM633010C Normally Open (7) - - - - Normally Closed (7) - - - - M30 Shielded M30 Non-Shielded M30 Shielded M30 Non-Shielded M30 Shielded 10mm 15mm 10mm 15mm 10mm M12 Connector 2.0 Meter Cable Normally Open - Mating cables / connectors Form Nominal Sensing Distance (Sn) Nickel Plated Brass Housing Material Termination Type 2.0 Meter Cable 2.0 Meter Cable Min / Max Supply Voltage Max. Load Current (Ir) Max ripple factor (Vr) Voltage Drop (Ud) Power Consumption (Io) Switching Frequency (Hz) Repeatability Hysteresis M12 Connector 10 to 30Vdc 20 to 220 Vac 100mA 400 mA ≤ 10% - ≤ 7.5 Vdc ≤ 4.5Vac ≤ 0.7mA 200 Hz 200 Hz 200 Hz ≤ 2.5mA 200 Hz 20 Hz < 2% nominal sensing distance ≤ 10% Sn Short Circuit Protection Yes No Output LED Yes Yes Operating Temperature IP Rating -25 to +70 C IP67 (with connector mounted) Wiring Diagram For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Inductive Proximity Sensors PNP – NO - - - - - - - PNP – NC - - - - - - - PNP – NO/NC - - - - - - - NPN – NO - - - - - - - - - - - - NPN – NC NPN – NO/NC - - - - - - - 2W DC NO - - - - - - - - - - - 2W DC NC - - - 2W AC NO IMM653015C IMN623010M12 IMN653015M12 IMN623010P IMN653015P 2W AC NC IMM663015C IMN633010M12 IMN663015M12 IMN633010P IMN663015P Mates Form M30 Non-Shielded Sn 15mm M30 Shielded M30 Non-Shielded M30 Shielded M30 Non-Shielded - - 10mm 15mm 10mm 15mm - - Nickel Plated Brass Housing Termination 2.0 Meter Cable M12 Connector M12 Connector - Max ripple ≤ 4.5Vac Ud ≤ 2.5mA Io Repeatability Hysteresis Sub-Base Plug 400mA Max Load Hz Sub-Base Plug 20 to 220Vac Supply Vdc 20 Hz 20 Hz 20 Hz 20 Hz 20 Hz < 2% nominal sensing distance ≤ 10% Sn Short Protection No LED Yes Op Temp -25 to +70 C IP Rating IP67 (with connector mounted) For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com
IMM653015C
物料型号:文档中列出了多种型号,包括IMM323010C、IMM353015C、IMN323010C等,这些型号可能代表不同的配置或功能。
器件简介:M30系列感应式接近传感器,具有标准长度的“Mini's”和扩展感应范围,适用于3线DC、2线DC和2线AC配置。
引脚分配:文档提供了接线图和电路图,展示了不同类型传感器的引脚分配
参数特性:包括感应距离(Sn)、供电电压范围、最大负载电流、电压降、功耗、开关频率、重复性、滞后、短路保护、输出LED、工作温度范围和IP等级等。
功能详解:文档详细描述了传感器的工作原理和特性,如重复性、滞后和短路保护等。
应用信息:虽然文档没有直接提供应用场景,但从传感器的特性可以推断,它们适用于工业自动化、机器人、检测系统等领域。
封装信息:传感器的封装材料为镀镍黄铜,提供了M30屏蔽和非屏蔽形式,以及M12连接器和2米电缆的终止类型。
IMM653015C 价格&库存
很抱歉,暂时无法提供与“IMM653015C”相匹配的价格&库存,您可以联系我们找货
