CPN32188C
CPN32188C
    CROUZET(高诺斯)
    SENS PROX CAP M18 PNP NO 2M
CPN32188C 数据手册
Capacitive Proximity Sensors M18 Capacitive Proximity Sensors Standard Length NAMUR 3 Wire DC ABS Material PTFE Material NAMUR 3 Wire DC 2 Wire DC (Wiring Schematic) CPN72185C (1) CPN32188C CPN32188M12 CPN32188C.A CPN32188C.F PNP – Normally Closed (1) CPN33188C CPN33188M12 CPN33188C.A CPN33188C.F PNP – Selectable (4) CPN34188C CPN34188M12 CPN34188C.A CPN34188C.F NPN – Normally Open (2) CPN22188C CPN252188M12 CPN22188C.A CPN22188C.F NPN – Normally Closed (2) CPN23188C CPN23188M12 CPN23188C.A CPN23188C.F NPN – Selectable (5) CPN24188C CPN24188M12 CPN24188C.A CPN24188C.F - - - - - M18 Shielded M18 Shielded M18 Shielded M18 Shielded M18 Shielded 1 to 5mm 1 to 8mm 1 to 8mm 1 to 8mm Housing Material ABS Nickel Plated Brass Nickel Plated Brass ABS Termination Type 2.0 Meter Cable 2.0 Meter Cable 2.0 Meter Cable 2.0 Meter Cable M12 Connector 100 Hz 100 Hz Normally Open Normally Closed 2 Wire AC (3) PNP – Normally Open Normally Open Normally Closed Mating cables / connectors Form Nominal Sensing Distance (Sn) Min / Max Supply Voltage 10 to 30Vdc Max. Load Current (Ir) 200mA ≤ 10% Max ripple factor (Vr) Voltage Drop (Ud) ≤ 3V @ 200mA Power Consumption (Io) Switching Frequency (Hz) Repeatability Hysteresis Short Circuit Protection Output LED Operating Temperature IP Rating 1 to 8mm Teflon – PTFE ≤ 15mA 100 Hz 100 Hz 100 Hz < 10% nominal sensing distance 2 to15% Sn Yes Yes -20 to +70 C IP65 (with connector mounted) Wiring Diagram For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com Capacitive Proximity Sensors PNP – NO CPN351815C CPN351815M12 CPN351815C.A CPN351815C.F - - - PNP – NC CPN361815C CPN361815M12 CPN361815C.A CPN361815C.F - - - PNP – NO/NC CPN371815C CPN371815M12 CPN371815C.A CPN371815C.F - - - NPN – NO CPN251815C CPN2351815M12 CPN251815C.A CPN251815C.F - - - NPN – NC CPN261815C CPN261815M12 CPN261815C.A CPN261815C.F - - - NPN – NO/NC CPN271815C CPN271815M12 CPN271815C.A CPN271815C.F - - - 2W DC NO - - - - - - - 2W DC NC - - - - - - - 2W AC NO - - - - - - - 2W AC NC - - - - - - - M18 Non-Shielded M18 Non-Shielded 2 to 15mm 2 to 15mm 2 to 15mm Nickel Plated Brass ABS PTFE M12 Connector 2.0 Meter Cable 2.0 Meter Cable 100 Hz 100 Hz Mates Form Sn Housing Nickel Plated Brass Termination 2.0 Meter Cable Supply Vdc 10 to 30Vdc Max Load 200mA Max ripple ≤ 10% Ud ≤ 3V @ 200mA 2 to 15mm ≤ 15mA Io Hz M18 Non-Shielded M18 Non-Shielded 100 Hz 100 Hz Repeatability < 10% nominal sensing distance Hysteresis ≤ 10% Sn Short Protection Yes LED Yes Op Temp -20 to +70 C IP Rating IP65 (with connector mounted) For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com
CPN32188C 价格&库存
很抱歉,暂时无法提供与“CPN32188C”相匹配的价格&库存,您可以联系我们找货
