Capacitive Proximity Sensors
M18 Capacitive Proximity Sensors
Standard Length
NAMUR
3 Wire DC
ABS Material
PTFE Material
NAMUR
3 Wire DC
2 Wire DC
(Wiring Schematic)
CPN72185C
(1)
CPN32188C
CPN32188M12
CPN32188C.A
CPN32188C.F
PNP – Normally Closed
(1)
CPN33188C
CPN33188M12
CPN33188C.A
CPN33188C.F
PNP – Selectable
(4)
CPN34188C
CPN34188M12
CPN34188C.A
CPN34188C.F
NPN – Normally Open
(2)
CPN22188C
CPN252188M12
CPN22188C.A
CPN22188C.F
NPN – Normally Closed
(2)
CPN23188C
CPN23188M12
CPN23188C.A
CPN23188C.F
NPN – Selectable
(5)
CPN24188C
CPN24188M12
CPN24188C.A
CPN24188C.F
M18 Shielded
M18 Shielded
M18 Shielded
M18 Shielded
M18 Shielded
1 to 5mm
1 to 8mm
1 to 8mm
1 to 8mm
Housing Material
ABS
Nickel Plated Brass
Nickel Plated Brass
ABS
Termination Type
2.0 Meter Cable
2.0 Meter Cable
2.0 Meter Cable
2.0 Meter Cable
M12 Connector
100 Hz
100 Hz
Normally Open
Normally Closed
2 Wire AC
(3)
PNP – Normally Open
Normally Open
Normally Closed
Mating cables / connectors
Form
Nominal Sensing Distance (Sn)
Min / Max Supply Voltage
10 to 30Vdc
Max. Load Current (Ir)
200mA
≤ 10%
Max ripple factor (Vr)
Voltage Drop (Ud)
≤ 3V @ 200mA
Power Consumption (Io)
Switching Frequency (Hz)
Repeatability
Hysteresis
Short Circuit Protection
Output LED
Operating Temperature
IP Rating
1 to 8mm
Teflon – PTFE
≤ 15mA
100 Hz
100 Hz
100 Hz
< 10% nominal sensing distance
2 to15% Sn
Yes
Yes
-20 to +70 C
IP65 (with connector mounted)
Wiring Diagram
For Technical Assistance and / or Customer Service, call 800/677-5311, www.crouzet-usa.com
PNP – NO
CPN351815C
CPN351815M12
CPN351815C.A CPN351815C.F
PNP – NC
CPN361815C
CPN361815M12
CPN361815C.A CPN361815C.F
PNP – NO/NC
CPN371815C
CPN371815M12
CPN371815C.A CPN371815C.F
NPN – NO
CPN251815C
CPN2351815M12 CPN251815C.A CPN251815C.F
NPN – NC
CPN261815C
CPN261815M12
CPN261815C.A CPN261815C.F
NPN – NO/NC
CPN271815C
CPN271815M12
CPN271815C.A CPN271815C.F
2W DC NO
2W DC NC
2W AC NO
2W AC NC
M18 Non-Shielded
M18 Non-Shielded
2 to 15mm
2 to 15mm
2 to 15mm
Nickel Plated Brass
ABS
PTFE
M12 Connector
2.0 Meter Cable
2.0 Meter Cable
100 Hz
100 Hz
Mates
Form
Sn
Housing Nickel Plated Brass
Termination
2.0 Meter Cable
Supply Vdc
10 to 30Vdc
Max Load
200mA
Max ripple
≤ 10%
Ud
≤ 3V @ 200mA
2 to 15mm
≤ 15mA
Io
Hz
M18 Non-Shielded M18 Non-Shielded
100 Hz
100 Hz
Repeatability
Hysteresis
≤ 10% Sn
Short Protection
Yes
LED
Yes
Op Temp
-20 to +70 C
IP Rating
很抱歉,暂时无法提供与“CPN22188M12”相匹配的价格&库存,您可以联系我们找货
