3
Selection Chart
Page
Series Number
Supply
Voltage
Load Capacity
Description and Special Notes
Curtis liquid level controls
ELS
3
120, 240VAC
1/4 HP, 10 amp non-inductive
120VAC, 1/3 HP, 240 VAC
Economical liquid level control sensitivity range
to 100,000 ohms
ELC
4
120, 240VAC
Low-cost liquid level control with sensitivity up to
50,000 ohms
LCT
5
24, 120, 240VAC
Liquid level control with built-in time delay
feature for standard applications up to 100,000
ohms
LCS
6
24, 120, 240VAC
Liquid level control with adjustable sensitivity
ranges for detection up to 100,000 ohms
LHS
6
24, 120, 240VAC
1/6 HP, 10 amp non-inductive
ranges for detection up to 3,00,000 ohms
LC
7
24, 120, 240VAC
Liquid level control with forward and reverse
operating modes, adjustable sensitivity to
100,000 ohms
DLC
8
24, 120, 240VAC
Dual liquid level control with heater/pump
lockout feature, sensitivity range to 100,000
ohms
Accessories
Rugged, compact contractors and enclosures
meeting NEMA 1, 3, 4, and 12 specifications
9
Liquid level
probe
assemblies
A variety of pressure, temperature and fitting
options available
9
RSA
10
Low-cost amplifier module for liquid level
applications
24, 120, 240VAC
Curtis industrial controls
ELS
11
24, 120, 240VAC
120VAC, 1/3 HP, 230 VAC
For precision photoelectric or temperature
applications
Curtis liquid level control principle of operation
Operating on the principle of conductivity (the ability of a liquid to
conduct electricity), Curtis Liquid Level controls sense and control the
level of almost any fluid or moist solid. These units are available with
fixed or adjustable setpoints to control levels in fluids having an
external circuit resistance up to 3,000,000 ohms. Typical solution
resistivity is shown below.
Typical Liquid Resistivity
Liquid
Nominal Resistivity
Range (ohms/CC)
acids, bases and salts ................................................ 0-20
dilute acids .............................................................. 20-200
milk, beer ........................................................... 200-2,000
non-distilled water ......................................... 2,000-20,000
distilled water ............................................ 20,000-200,000
In operation, two or more submerged liquid level probes pass a
minute electrical current through the liquid to be controlled. This
4
current, typically 500 microamperes, is introduced to a solid-state
resistance-sending amplifier which provides sufficient gate signal to
trigger a silicon-controlled rectifier (SCR). The firing threshold is
accurate to within 2% of operating differential and is adjustable by
means of a potentiometer. The output of the SCR is used to operate
the plug-in control relay. When anticipated loads exceed that of the
standard relay, an auxiliary contactor is utilized.
Control Models ELS, LCS/LHS, LCF and RSA are designed for
forward mode operation. They interpret a decrease of external circuit
resistance from setpoint as an “ON” signal. Model LCR is designed for
reverse mode operation. It energizes when external circuit resistance
increases above setpoint. Model DLC is intended primarily for pump
and heater level/lockout applications. See the appropriate catalog
sections for specific application information.
When selecting a liquid level control, several factors must be taken
into consideration. Questions arise as to what mode of operation is
required, what is the resistivity range of the fluid to be controlled, is a
fixed or variable setpoint called for, are special functions required
such as a pump or heater lockout, etc. Use the connection diagrams
to select the ideal control for your specific application.
Model ELS
Economical unit with sensitivity
up to 100,000 ohms
Features
■ Solid State Amplifier with SCR and Control Relay
■ Low AC Signal Voltage
■ Compact Printed Circuit Design
■ 1/4” Quick-Connect Terminals
■ Insensitive to Transients
■ Built-in Holding Circuit for Differential Levels or Manual Reset
■ Plug-in Dust-Tight Relay
■ Recognized Under the Components Program of Underwriters
Laboratories, Inc. Listed with Canadian Standards Association.
Specifications
Model
ELS-1-A,B,C
ELS-1-A,B,C
Maximum Allowable Supply Voltage Variation: ± 10%
Maximum Power Consumption: 3 Watts
Detectable Range:
ELS-1,2-A
ELS-1,2-B
ELS-1,2-C
Input Supply:
Input Supply
120VAC, 50/60 Hz
240VAC, 50/60 Hz
100,000 ohms
50,000 ohms
25,000 ohms
Maximum Signal or Probe Voltage: 24VAC
Maximum Signal or Probe Current: 10MA
Control Relay: Single Pole Double Throw, Plug-in Type with Dust-Tight Cover
Load Contacts: SPST Rated – 1/4 HP, 10 Amps, 120VAC
1/3 HP, 10 Amps, 240VAC
Ambient Operating Temperature: 32° F to 140° F
Standard Termination:
.250” Quick-Connects
Outline and Mounting Dimensions
Connection Diagrams
This is a fixed-sensitivity, forward mode control. The control relay is energized when
liquid rises to contact the “H” probe. The control relay is pulled in and remains
energized until liquid drops below the “L” probe.
Ordering
Information
Typical Curtis Model Number
ELS-1 -A-
Model (Also refer to “Specifications” above)
Detectable Range (A-100 k ohms, B-50 k ohms, C-25 k ohms)
Enclosure – specify only if necessary –
N3-NEMA 3, N4–NEMA 4 JIC
The composite number above reads as “an ELS amplifier for 120VAC supply, without enclosure, and with 100 K ohms sensitivity.”
For further information on catalog listed controls contact your area Curtis representative or Curtis distributor.
For custom design or modification contact your area Curtis Representative or the factory direct.
5
Model ELC
up to 50,000 ohms
Features
■ Compact, Solid-State Design
■ Single Level, Forward Mode Operation
■ Holding Circuit for Differential Levels, or Manual Reset
■ Transient-Protected Circuit, Positive ON/OFF Eliminates Relay
Chatter
■ Circuit Design Limits Short Circuit Probe Current to
10MA/24VAC
Specifications
Model
ELC-1-S,D
ELC-1-S,D
Detectable Range: Up to 50,000 ohms
Operating Point Differential: 3% (Typical)
Input Supply:
Input Supply
120VAC, 50/60 Hz
240VAC, 50/60 Hz
Control Relay: Plug-in Type with Dust-Tight Cover
Probe Contacts: SPDT internally connected
Load Contacts: SPDT (ELC-1,2-S) or DPDT (ELC-1,2-D)
Rated 10 amp Non-inductive, 120VAC, 1/4 HP
1/3 HP at 240VAC
Ambient Operating Temperature: +32° F to +140° F
.250” Quick-Connect
Mounting Style: 4 Standoffs
Connection Diagrams
Ordering
Information
ELC-1 -S-
The composite number above reads as “an ELC amplifier for 120VAC supply SPDT Output and without Enclosure.”
For custom design or modification contact your area Curtis representative or the factory direct.
6
Curtis liquid level control with
time delay
Model LCT
Features
Low Cost Control for Standard Applications up to 100,000 ohms
Built-in Delay-on-Make
Interchangeable with Curtis Model LCS Liquid Level Controls
Solid-State Amplifier with Potentiometer for Signal Sensitivity
Adjustment
Positive ON/OFF Operation Eliminates Relay Chatter
Circuit Limits Short-Circuit Probe Current to 10MA/24VAC
Pre-wired Auxiliary Contactor Available for Handling Heavy
Loads and Motor Ratings Exceeding Capacity of Plug-in Relay
Specifications
Model
Input Supply
LCT-10
120VAC ±10%, 50/60 Hz
LCT-20
240VAC ±10%, 50/60 Hz
LCT-30
24VAC ±10%, 50/60 Hz.
Sensitivity Range: 1,000 to 100,000 ohms
Detectable Range: Up to 100,000 ohms
Time Delay: Delay on Operate: 3 sec: ±50%
(Other values between 0.5 and 10 sec. available on request.)
Input Supply:
Delay on Release: 0.5 sec. ±50%
Open Circuit Probe Voltage: 24VAC
Short Circuit Probe Current: 10MA
Control Relay: Plug-in type with dust cover
Contact Rating: 10 amp non-inductive, 1/4 HP at 120VAC, 1/3 HP at 240VAC
Auxiliary Contactor: DPST-NO-DB, rated 1 HP at 120VAC, 2 HP at 240VAC
Ambient Operating Temperature: 0° C to +60° C
Standard Termination: Barrier-type terminal blocks accepting wire up to No.
12AWG. Auxiliary contactor has combination screw/double .250” quick-connects
Mounting Style: Flange
Outside Dimensions: 5-1/2” long x 4-1/8” wide x 2-13/16” high
Connection Diagrams
Model LCT is a forward mode control. The control relay is energized when liquid rises to
contact the “H” probe. The time delay on operate is 3 seconds nominal and 0.5 seconds
on release. Other values between 0.5 and 10 seconds are available on request. The
control relay is pulled in and remains energized until liquid drops below the “L” probe.
Sensitivity is adjustable.
Ordering
Information
LCT-20 - -
Contactor (add “C” if desired)
N3-NEMA 3, N3C–NEMA 3/
Contactor, N4 – NEMA 4 JIC
The composite number above reads as an LCT amplifier for 240VAC supply, without enclosure and without contactor.
For further information on catalog listed controls contact your area Curtis Representative or Curtis distributor.
7
Curtis liquid level controls with
Models LCS/LHS
Two sensitivity ranges for
detection up to 3,000,000 ohms
Features
■ Low cost Model LCS for Standard Applications up to 100,000 ohms
■ High-Sensitivity Model LHS for Special Applications from 100,000 to
3,000,000 ohms
■ Solid-State Amplifier with Potentiometer for Signal Sensitivity
Adjustment
■ Positive ON/OFF Operation Eliminates Relay Chatter
■ Circuit Limits Short Circuit Probe Current to 10MA/24VAC
■ Pre-Wired Auxiliary Contactor Available for Handling Heavy Loads
and Motor Ratings Exceeding Capacity of Plug-In Relay
Specifications
Model
Input Supply
Input Supply:
LCS-10/LHS-1
120VAC, 50/60 Hz
LCS-20/LHS-2
240VAC, 50/60 Hz
LCS-30
24VAC, 50/60 Hz.
Detectable Range: Up to 100,000 ohms (LCS); Up to 3,000,000 ohms (LHS)
Adjustable Range: 1,000 to 100,000 ohms (LCS); 1,000 to 3,000,000 ohms (LHS)
Probe Contacts: Internally Connected for Holding Circuit
Load Contacts: LCS – SPDT, 1/4 HP, 10 amp Non-inductive, 120VAC 1/3 HP at 240 VAC
LHS – SPDT, 1/6 HP, 10 amp Non-inductive, 120VAC 1/3 HP at 240VAC
Connection Diagrams
Models LCS/LHS is a forward mode control. The control relay is energized when liquid rises to contact the “H” probe. The control
relay is pulled in and remains energized until liquid drops below the “L” probe. Sensitivity is adjustable.
Ordering
Information
LCS-20 - -
The composite number above reads as an LCS amplifier for 240VAC supply, without enclosure and without contactor.
8
Model LC
Forward or reverse, mode with
single or differential level operation
Features
Specifications
Model
Input Supply
Model
Input Supply
Input Supply: LC-F-1
120VAC, 50/60 Hz
LC-R-1
120VAC, 50/60 Hz
LC-F-2
240VAC, 50/60 Hz
LC-R-2
240VAC, 50/60 Hz
LC-F-3
24VAC, 50/60 Hz
LC-R-3
24VAC, 50/60 Hz
Probe Contacts: Internally connected for holding circuit
Load Contacts: DPDT rated 10 amp, Non-inductive/120VAC, 1/4 HP at 240VAC
Standard Termination: Barrier-type terminal blocks for wire up to No. 12AWG.
Auxiliary contactor has combination screw/double .250” quick-connects. Optional
SPDT contacts have .250” quick-connects
Options: Alarm and indicator lamp for enclosure-mounted controls, high impedance
relays available for extended control dropout time.=
Mounting Style: Standoffs
Adjustable Sensitivity up to 100,000 ohms
Circuit Limits Short Circuit Probe Current 10MA/24VAC
Recommended for Applications Having Longer Than Average
Probe Runs. (Resultant Line Capacitance can be Compensated
for by Adding a Capacitor (CX) of Equivalent Value to Available
Terminals or the Control)
Temperature-Stabilized from +32° F to +140° F
Shielded, Grounded Isolation Transformer
Low Power Consumption
Connection Diagrams
Model LC – Forward Mode
Control energizes when liquid reaches “H”. Control de-energizes when liquid falls below “L” and
remains in an off state until liquid again reaches
“H”. This control maintains a liquid level between
“H” and “L” and will not chatter due to surface ripple.
Single Level Operation (Not Illustrated)
both the LC-F and LC-R may be used without the
“L” Probe. Operation without the “L” Probe gives a
very small differential between the energize and
de-energize levels. This may result in chattering of
the control if splashing or ripple is present at the
liquid surface.
Model LC – Reverse Mode
Control Energizes when liquid falls below “L. Control remains energized until liquid rises past “L” and
contacts “H”. Control de-energizes when liquid
reaches “H” and remains in an off state until liquid
again falls below “L. This control maintains a liquid
level between “L” and “H” and will not chatter due
to surface ripple.
Ordering
Information
LC-R-1 - -
Operational Mode (F – Forward, R – Reverse)
The composite number above reads as an LC amplifier with reverse mode, for 120VAC supply, without enclosure and without contactor.”
9
Models DLC
Dual-level control with
lockout feature
Features
■ Ideal for Pump and Heater Applications Requiring Lockout in the
Event of Loss of Water or Product Being Controlled
■ Circuit Design Limits Short Circuit Probe Current to 10MA/24VAC
■ Three-Probe Circuit Eliminates “Hunting” or Relay Chatter
■ Has Provision for Priming Switch for Applications Requiring Manual
Priming of System
■ Solid-State Amplifier with SCR and Control Relay
■ Sensitivity to 100,000 ohms
Specifications
Model
Input Supply
DLC-1
120VAC, 50/60 Hz
DLC-2
240VAC, 50/60 Hz
DLC-3
24VAC, 50/60 Hz.
Sensitivity Range: External circuit sensitivity fixed at 100,000 ohms; Lockout circuit
sensitivity fixed at 15,000 ohms
Input Supply:
Control Relay: Plug-in types with dust cover
Load Contacts: 1/6 HP, 10 amp, Non-inductive/120VAC, 1/3 HP at 240VAC
One side of No. 1 relay actuates fill water solenoid valve, a second set of contacts
function as an internally connected holding circuit. One side of No. 2 relay is used
to operate a heater load contactor.
Standard Termination: .250” quick-connects
The DLC control maintains liquids between a low and a high level. Activating the main switch on this dualrelay unit pulls in control relay No. 1 and starts filling boiler tank through the solenoid valve. When liquid rises
to “XL”, minimum level, lockout control relay No. 2 energizes to operate the pump, heater core or contactor.
The solenoid valve continues to fill the tank until liquid reaches the “H” probe. When the liquid drops below the
“L” probe, the solenoid fill valve is again activated. Relay No. 2, he lockout control, remains energized as long
as liquid level remains above “XL” minimum level.
Ordering
Information
DLC-1 - -
The composite number above reads as a “DLC amplifier for 120VAC supply, without enclosure and without contactor.
Unless otherwise noted, when a contactor is ordered for the DLC unit, it is wired into the output of the No. 2 (heater control) relay. Contactors may be wired into the output of the No. 1
(solenoid valve control) relay or both No. 1 and No. 2 relays, as application may require. Specify with order. Refer to “Control Accessories,” page 7, for additional information.
10
Curtis liquid level probe assemblies
P Series
Probes for almost any
pressure/temperature requirement
Five basic probe types and 14 model variations provide design versatility matched to
your specific application. Choose from single, dual or multi-probe designs in PVC or
nylon fittings. All probes feature 316 stainless steel electrodes with standard lengths
ranging up to six feet, in one-foot increments. Pressure/temperature limits range as
high as 2500 lbs./700° F. Covered probes are offered for applications subject to
unusually adverse environments or stringent safety codes.
Model EP
Economy probe designed for budget systems. Available
in NPT sizes 3/4” (Single probe), 1” (Dual probe), 1-1/2”
(Triple probe) with Nylon Hex fittings.
Model SP
Simple probe designed with adjustable probe length feature. Must be used with conductive container only. Available in probe size diameters of 1/8”, 3/16” or 1/4” (i.e.
SP125, SP187, SP250).
Models HTPP - HTPGP
High temperature, high pressure 3/8” NPT probe designed
to withstand hydrostatic pressures to 2500 psi and temperatures to 700° F. Standard Model HTPP does not contain added threaded stud for common ground connection,
when required specify HTPGP Model. Constructed from
18-8 non-magnetic stainless steel with alumina insulation.
Model CP
Covered Probe designed for high humidity environments.
Probe headers are splash-proof and moisture-tight. Available in NPT fitting sizes 1-1/2” for dual probe systems and
2” for triple or quadruple probe systems.
Accessories
Control enclosures for
hostile environments
NEMA 3 Enclosures – Weather-Resistant
for Outdoor Applications
Designed to exclude rain, snow and sleet, thee durable
enclosures may also be used indoors wherever dripping
water presents a problem. Construction features heavygauge steel finished in satin gray enamel. Enclosures accepting standard control models are designated N3, while
those accepting the larger contactor mounting panels are
designated N3C. Enclosures also meet NEMA I specifications for general purpose dust resistance.
Standard Control Models ELS, LCS/LHS, LC, RSA, DLC, and PCT are open-style.
Models with contactors are attached to a 6-7/8” x 8-3/4” panel. NEMA 3 and MEA 4JIC enclosures are offered to fit above models with or without contactor mounting
panels. Alarm and indicator lamp options are also available. Contact factory or your
local representative for additional information.
NEMA 4-JIC Enclosures – Water Tight and Oil Tight
Intended for use in areas which are regularly hosed down.
They are suitable for outdoor, shipdeck, dairy or brewery
applications. Enclosures are fabricated of extra-heavy 14gauge steel with welded seams. Construction also features external mounting feet and solid neoprene cover
gasket. These grey hammertone enamel-finished units
accept standard and contactor mounting panel controls.
Enclosures also meet NEMA 12 for dust, dirt and oil protection.
Any standoff or flange-mounted control may be ordered with the auxiliary contactor. Track-mounted controls are
available with auxiliary contactors on special order only. Contact factory for additional info.
Auxiliary Contactors – For Loads
Exceeding That of Standard Relays
When anticipated loads exceed the 10 amp/120VAC rating of relays furnished with our standard controls, use of a
contactor is necessary. These small, ruggedly built units
are available in 24, 120 and 240VAC coil voltages to match
the control input supply voltage. Contactors feature heavyduty DPST-NO-DB contacts rated 1HP/120VAC or 2HP/
240VAC. Terminals are No. 10 pressure screws with .250”
double quick-connect tabs. Contactor/control assembles
are prewired for customer convenience.
Contact factory for additional information.
11
Curtis® low cost amplifier module
for liquid level applications
Model RSA
Control-Trak component
Features
Specifications
■ Inexpensive, Compact Circuitry is Compatible with any Transducer Exhibiting 100,000 ohms Resistance or Less
■ Designed to Fit Curtis TR1 or TR3 Snap-In Track Intended for
Use with Curtis RS2, RS4, RS6, RS12, RS15 or RS16 Relay
Socket Assemblies (See Curtis Relay Socket Catalog)
■ Ideal for Custom, Modified or Experimental Circuits – Control/
Relay Socket Combination Provides Access to the Several
Hundred Relay Styles Available from Most Relay Manufacturers
■ Devices Other Than Relays, such as Solenoids or Valve
Actuators may be Operated Directly Off the Module Providing
that They are Rated 24VDC with Impedance Greater than 250
ohms
■ Includes Fully Adjustable Setpoint and Circuit Designed to Limit
Maximum Direct-Short Transducer Current to 10MA/24VAC
Model
Input Supply
Input Supply: RSA-1
120VAC, 50/60 Hz
RSA-2
240VAC/ 50/60 Hz
RSA-3
24VAC, 50/60 Hz
Maximum Power Consumption: 1 W without relay
Control Relay: Customer furnished – See Curtis Relay Socket Catalog for complete
list of various snap-in assemblies
Control Output: 90MA @ 24VDC
Ambient Operating Temperature: 0° C to +60° C or ±32° F
Standard Termination: .110” quick-connects
Operation
Model RSA Amplifier Module accepts any liquid level transducer displaying less than 100,000 ohms resistance. As an example of its operation as a liquid level control, the control remains de-energized until liquid
rises to contact the “H” probe. The resultant decrease in external circuit
resistance from setpoint will energize output. Output remains energized
until liquid again drops below the “H” probe. Sensitivity of the external
circuit resistance setpoint is fully adjustable up to 100,000 ohms. Model
RSA is designed to work in conjunction with track-mounted, customer
supplied relays. However, the 90MA/24VDC output is sufficient to operate many solenoid and valve devices directly when minimum impedance
exceeds 250 ohms.
Ordering
Information
RSA-1 -TR -
Basic Amplifier Type (Also refer to “Specifications” above)
Mounting (TR-Track, S-Standoff)
The composite number above reads as a “RSA amplifier for 120VAC supply.” Model is track mounted (track ordered separately – see page 11.) An auxiliary contactor offered as
a track-mounted accessory is available on special request only. Track-type units cannot be enclosure-mounted. Contact factory for additional information.
12
Curtis resistance sensing amplifier for
photoelectric, temperature and process control
Model PCT
Features
■ Zener Diode-Regulated Power Supply Limits Operating Point
Variations to Less than 0.5%
■ Standard Adjustable Resistance Sensing Range is Sensitive to
100,000 ohms but can be extended to 250,000 ohms
■ Has Provision for Remote Potentiometer Adjustment of Operating Setpoint as well as Built-In Time Delay which can be
Modified to Meet Individual Customer Specifications
■ May be Wired for Light or Dark Energizing Operation
■ Circuit Design Limits Short Circuit Transducer Current to a
Maximum 4MA/9VDC
■ Auxiliary Contactor Available for Loads Exceeding Capacity of
Plug-in Relay
■ Differential Adjustment Provided
Plug-in Relay
Operation
Ordering
Information
Specifications
Model
Input Supply
PCT-1
120VAC, 50/60 Hz
PCT-2
240VAC/ 50/60 Hz
PCT-3
24VAC, 50/60 Hz
Maximum Power Consumption: 3.5 Watts
Detectable Range: Up to 100,000 ohms Standard; may be extended to 250,000
ohms
Adjustable Range: 1,000 to 100,000 ohms Standard; 1,000 to 250,000 ohms for
extended sensitivity circuits
Operating Point Differential: 1% (With Sensing Element Resistance Above 15k
ohms) Typical
Maximum Signal or Probe Voltage (Element Exhibiting Infinite Resistance): 9VDC
Maximum Signal or Probe Current: 4MA
Control Relay: DPDT Plug-In Type with Cover
Load Contacts: 1/6 HP, 10 amp, Non-inductive/120VAC; 1/3 HP at 230VAC
Ambient Operating Temperature: -25° F to +140° F
Standard Termination: Barrier-Type Terminal Blocks.
Accepting Wire up to No. 12AWG
Input Supply:
Model PCT control may be wired to energize the control relay following
either an increase or a decrease in external circuit resistance. Unit provides a .25MA/9VDC signal to a variable resistance sensing element. A
control-mounted potentiometer allows adjustment of pull-in or drop-out point.
The unit has provision for extension of the operating point as well as remote potentiometer adjustment. A built-in time delay eliminates false
riggering due to minor sensing element impulses. Standard response time,
typically 100 milliseconds, can be altered by changing the value of capacitor C2. Provides a response time of 10 to 15 milliseconds.
PCT-1 -
above)
Contactor (if desired add “C”)
(N3 – NEMA 3, N3C – NEMA 3/
The composite number above reads as a “PCT amplifier for 120VAC supply without contactor and less enclosure.” Contact factory for additional information.
13
