Flammable Gas Sensor
(Model:MQ-6)
Manual
Version: 1.3
Valid from: 2014-05-01
Zhengzhou Winsen Electronics Technology Co., Ltd
Statement
This manual copyright belongs to Zhengzhou Winsen Electronics Technology Co., LTD. Without the
written permission, any part of this manual shall not be copied, translated, stored in database or
retrieval system, also can’t spread through electronic, copying, record ways.
Thanks for purchasing our product. In order to let customers use it better and reduce the faults
caused by misuse, please read the manual carefully and operate it correctly in accordance with the
instructions. If users disobey the terms or remove, disassemble, change the components inside of
the sensor, we shall not be responsible for the loss.
The specific such as color, appearance, sizes &etc, please in kind prevail.
We are devoting ourselves to products development and technical innovation, so we reserve the
right to improve the products without notice. Please confirm it is the valid version before using this
manual. At the same time, users’ comments on optimized using way are welcome.
Please keep the manual properly, in order to get help if you have questions during the usage in the
future.
Zhengzhou Winsen Electronics Technology CO., LTD
www.winsensor.com
MQ-6 Semiconductor Sensor for Flammable Gas
Profile
Sensitive material of MQ-6 gas sensor is SnO2, which
with lower conductivity in clean air. When the target
flammable gas exist, the sensor’s conductivity gets
higher along with the gas concentration rising. Users
can convert the change of conductivity to correspond
output signal of gas concentration through a simple
circuit.
MQ-6 gas sensor can detect kinds of flammable
gases, especially has high sensitivity to LPG
(propane). It is a kind of low-cost sensor for many
applications.
Features
It has good sensitivity to flammable gas(especially propane) in wide range, and has advantages such as
long lifespan, low cost and simple drive circuit &etc.
Main Applications
It is widely used in domestic gas leakage alarm, industrial flammable gas alarm and portable gas detector.
Technical Parameters
Stable 1.
Model
MQ-6
Sens or Type
Semi conductor
Sta nda rd Enca ps ul a ti on
Ba kel i te, Meta l ca p
Ta rget Ga s
LPG
300~10000ppm
Detecti on ra nge
Sta nda rd Ci rcui t
Condi ti ons
Sensor character
(Propa ne)
Loop Vol ta ge
Vc
≤24V DC
Hea ter Vol ta ge
VH
5.0V±0.1V AC or DC
Loa d Res i s ta nce
RL
Adjus ta bl e
Hea ter Res i s ta nce
RH
26Ω±3Ω(room tem.)
Hea ter cons umpti on
PH
≤950mW
Sens i ti vi ty
S
Output Vol ta ge
Vs
Concentration Sl ope
α
under standard
tes t conditions
Tem. Humi di ty
Sta nda rd tes t
condi ti ons
Sta nda rd tes t ci rcui t
Prehea t ti me
Rs (i n air)/Rs( i n 2000ppm
C3H 8)≥5
2.5V~4.0V (i n 2000ppm
C3H 8)
≤0.6(R 3000ppm/R 1000ppm
C3H 8)
20℃±2℃;55%±5%RH
Vc:5.0V±0.1V;
VH:5.0V±0.1V
Over 48 hours
NOTE: Output voltage (Vs) is VRL in test environment.
Tel: 86-371-67169097/67169670
Fax: 86-371-60932988
Fig1.Sensor Structure
Unit: mm
Email: sales@winsensor.com
www.winsensor.com
Basic Circuit
Fig2. MQ-6 Test Circuit
Instructions: The above fig is the basic test circuit of MQ-6.The sensor requires two voltage inputs: heater
voltage (VH) and circuit voltage(VC). VH is used to supply standard working temperature to the sensor and it
can adopt DC or AC power, while VRL is the voltage of load resistance RL which is in series with sensor. Vc
supplies the detect voltage to load resistance RL and it should adopts DC power.
Description of Sensor Characters
C3H 8
Air
CH 4
C2H 5OH
Fig3.Typical Sensitivity Curve
The ordinate is resistance ra tio of the sensor (Rs /R 0),
the abs cissa is concentra tion of gases . Rs means
resistance in ta rget gas wi th di fferent concentra tion,
R 0 mea ns resistance of sensor in clean ai r. All tests
Fig4.Typical temperature/humidity characteristics
The ordina te is resistance ra tio of the sensor (Rs /Rso).Rs
means resistance of sens or in 2000ppm propane (C3H 8) under
di fferent tem. and humidity. Rs o means resistance of the
s ensor i n 2000ppm propane under 20℃/55%RH.
a re fi nished under standard test conditions.
www.winsensor.com
Time(s)
Fig5.Sensitity Curve
Fi g5 shows the VRL i n propane wi th different concentration.
The resistance load R L is 4.7 KΩ a nd the test is finished in
s ta ndard test conditions.
Fig6.Responce and Resume
Fi g5 shows the changing of V RL in the process of putting
the s ensor i nto target gas and removing i t out.
2000ppm C3 H8 (RL=4.7k)
Time(day)
Fig7.long-term Stability
Tes t i s finished in standard test conditions, the a bscissa i s observing time a nd the ordinate is VRL.
Cautions
1 .Following conditions must be prohibited
1.1 Exposed to organic silicon steam
Sensing material will lose sensitivity and never recover if the sensor absorbs organic silicon steam.
Sensors must avoid exposing to silicon bond, fixature, silicon latex, putty or plastic contain silicon
environment.
1.2 High Corrosive gas
If the sensors are exposed to high concentration corrosive gas (such as H 2 S, SOX, Cl2 , HCl etc.), it will
not only result in corrosion of sensors structure, also it cause sincere sensitivity attenuation.
1.3 Alkali, Alkali metals salt, halogen pollution
The sensors performance will be changed badly if sensors be sprayed polluted by alkali metals salt
especially brine, or be exposed to halogen such as fluorine.
www.winsensor.com
1.4 Touch water
Sensitivity of the sensors will be reduced when spattered or dipped in water.
1.5 Freezing
Do avoid icing on sensor’s surface, otherwise sensing material will be broken and lost sensitivity.
1.6 Applied higher voltage
Applied voltage on sensor should not be higher than stipulated value, even if the sensor is not
physically damaged or broken, it causes down-line or heater damaged, and bring on sensors’
sensitivity characteristic changed badly.
1.7 Voltage on wrong pins
For 6 pins sensor, Pin 2&5 is heating electrodes, Pin (1,3)/(4,6) are testing
electrodes (Pin 1 connects with Pin 3, while Pin 4 connects with Pin 6).If
apply voltage on Pin 1&3 or 4&6, it will make lead broken; and no signal
putout if apply on pins 2&4.
Fig8. Lead sketch
2 .Following conditions must be avoided
2.1 Water Condensation
Indoor conditions, slight water condensation will influence sensors’ performance lightly. However, if
water condensation on sensors surface and keep a certain period, sensors’ sensitive will be decreased.
2.2 Used in high gas concentration
No matter the sensor is electrified or not, if it is placed in high gas concentration for long time, sensors
characteristic will be affected. If lighter gas sprays the sensor, it will cause extremely damage.
2.3 Long time storage
The sensors resistance will drift reversibly if it’s stored for long time without electrify, this drift is
related with storage conditions. Sensors should be stored in airproof bag without volatile silicon
compound. For the sensors with long time storage but no electrify, they need long galvanical aging
time for stability before using. The suggested aging time as follow:
Stable2.
Storage Time
Suggested aging time
Less than one month
No less than 48 hours
1 ~ 6 months
No less than 72 hours
More than six months
No less than 168 hours
2.4 Long time exposed to adverse environment
No matter the sensors electrified or not, if exposed to adverse environment for long time, such as high
humidity, high temperature, or high pollution etc., it will influence the sensors’ performance badly.
2.5 Vibration
Continual vibration will result in sensors down-lead response then break. In transportation or
assembling line, pneumatic screwdriver/ultrasonic welding machine can lead this vibration.
2.6 Concussion
If sensors meet strong concussion, it may lead its lead wire disconnected.
2.7 Usage Conditions
2.7.1For sensor, handmade welding is optimal way. The welding conditions as follow:
Soldering flux: Rosin soldering flux contains least chlorine
www.winsensor.com
homothermal soldering iron
Temperature: 250℃
Time:less than 3 seconds
2.7.1If users choose wave-soldering, the following conditions should be obey:
Speed: 1-2 Meter/ Minute
Warm-up temperature:100±20℃
Welding temperature:250±10℃
One time pass wave crest welding machine
If disobey the above using terms, sensors sensitivity will reduce.
Add: No.299, Jinsuo Road, National Hi-Tech Zone,
Zhengzhou 450001 China
Tel: +86-371-67169097/67169670
Fax: +86-371-60932988
E-mail: sales@winsensor.com
Website: www.winsensor.com
