SEN-09403
SEN-09403
    SPARKFUNELECTRONICS
SEN-09403 数据手册
Toxic Gas Sensor (Model:MQ-7) Manual Version: 1.3 Valid from: 2014-05-01 Zhengzhou Winsen Electronics Technology Co., Ltd Statement This manual copyright belongs to Zhengzhou Winsen Electronics Technology Co., LTD. Without the written permission, any part of this manual shall not be copied, translated, stored in database or retrieval system, also can’t spread through electronic, copying, record ways. Thanks for purchasing our product. In order to let customers use it better and reduce the faults caused by misuse, please read the manual carefully and operate it correctly in accordance with the instructions. If users disobey the terms or remove, disassemble, change the components inside of the sensor, we shall not be responsible for the loss. The specific such as color, appearance, sizes &etc, please in kind prevail. We are devoting ourselves to products development and technical innovation, so we reserve the right to improve the products without notice. Please confirm it is the valid version before using this manual. At the same time, users’ comments on optimized using way are welcome. Please keep the manual properly, in order to get help if you have questions during the usage in the future. Zhengzhou Winsen Electronics Technology CO., LTD Zhengzhou Winsen Electronics Technology Co., Ltd www.winsensor.com MQ-7 Semiconductor Sensor for Carbon Monoxide Profile Sensitive material of MQ-7 gas sensor is SnO2, which with lower conductivity in clean air. It make detection by method of cycle high and low temperature, and detect CO at low temperature(heated by 1.5V).The sensor’s conductivity gets higher along with the CO gas concentration rising. At high temperature(heated by 5.0V),it cleans the other gases adsorbed at low temperature. Users can convert the change of conductivity to correspond output signal of gas concentration through a simple circuit. Features It has good sensitivity to carbon monoxide in wide range, and has advantages such as long lifespan, low cost and simple drive circuit &etc. Main Applications It is widely used in domestic CO gas leakage alarm, industrial CO gas alarm and portable CO gas detector. Technical Parameters Stable.1 Model MQ-7 Sensor Type Semiconductor Standard Encapsulation Plastic cap Target Gas carbon monoxide Detection range 10~500ppm CO Loop Voltage Vc Heater Voltage VH Heater Time TL Load Resistance RL Adjustable Heater Resistance RH 29Ω±3Ω(room tem.) Sensor character Heater consumption PH ≤900mW under standard Sensitivity S Rs(in air)/Rs(in 150ppm CO)≥5 test conditions Output Voltage Vs 2.5V~4.3V (in 150ppm CO) Concentration Slope α ≤0.6(R300ppm/R50ppm CO) Standard Circuit Conditions Tem. Standard test conditions Humidity ≤10V DC 5.0V±0.1V AC or DC(High tem.) 1.5V±0.1V AC or DC(Low tem.) 60 S±1S(High tem.) , 90 S±1S(Low tem.) 20℃±2℃;55%±5%RH Vc:5.0V±0.1V; Standard test circuit VH(High tem.) : 5.0V±0.1V; VH (Low tem.) : 1.5V±0.1V Preheat time Over 48 hours Fig1.Sensor Structure Unit: mm NOTE: Output voltage (Vs) is VRL in test environment. Tel: 86-371-67169097/67169670 Fax: 86-371-60932988 Email: sales@winsensor.com Zhengzhou Winsen Electronics Technology Co., Ltd www.winsensor.com Basic Circuit VH AC or DC High voltage and low voltage can switch Fig2. MQ-7 Test Circuit Instructions: The above fig is the basic test circuit of MQ-7.The sensor requires two voltage inputs: heater voltage (VH) and circuit voltage(VC). VH is used to supply standard working temperature to the sensor and it can adopt DC or AC power. For this model sensor, VH should be at 1.5V±0.1V low voltage when detect CO while should be at 5V±0.1V at non detection status(resuming period). VRL is the voltage of load resistance RL which is in series with sensor. Vc supplies the detect voltage to load resistance RL and it should adopts DC power. Description of Sensor Characters CO Air CH4 H2 Fig3.Typical Sensitivity Curve The ordinate is resistance ratio of the sensor (Rs/R0), the abscissa is concentration of gases. Rs means resistance in target gas with different concentration, R0 means resistance of sensor in clean air. All tests are finished Fig4.Typical temperature/humidity characteristics The ordinate is resistance ratio of the sensor (Rs/Rso).Rs means resistance of sensor in 150ppm CO gas under different tem. and humidity. Rso means resistance of the sensor in 150ppm CO gas under 20℃/55%RH. under standard test conditions. Tel: 86-371-67169097/67169670 Fax: 86-371-60932988 Email: sales@winsensor.com Zhengzhou Winsen Electronics Technology Co., Ltd www.winsensor.com 150ppm CO gas (RL=4.7k) Time(s) Fig5.Sensitity Curve Fig6.Responce and Resume Fig5 shows the VRL in CO gas with different concentration. The resistance load RL is 4.7 KΩ and the test is finished in Fig5 shows the changing of VRL in the process of putting the sensor into target gas and removing it out. standard test conditions. 150ppm CO gas (RL=4.7k) Time(day) Fig7.long-term Stability Test is finished in standard test conditions, the abscissa is observing time and the ordinate is VRL. Cautions 1 .Following conditions must be prohibited 1.1 Exposed to organic silicon steam Sensing material will lose sensitivity and never recover if the sensor absorbs organic silicon steam. Sensors must avoid exposing to silicon bond, fixature, silicon latex, putty or plastic contain silicon environment. 1.2 High Corrosive gas If the sensors are exposed to high concentration corrosive gas (such as H2S, SOX, Cl2, HCl etc.), it will not only result in corrosion of sensors structure, also it cause sincere sensitivity attenuation. 1.3 Alkali, Alkali metals salt, halogen pollution The sensors performance will be changed badly if sensors be sprayed polluted by alkali metals salt Tel: 86-371-67169097/67169670 Fax: 86-371-60932988 Email: sales@winsensor.com Zhengzhou Winsen Electronics Technology Co., Ltd especially brine, or be exposed to halogen such as fluorine. www.winsensor.com 1.4 Touch water Sensitivity of the sensors will be reduced when spattered or dipped in water. 1.5 Freezing Do avoid icing on sensor’s surface, otherwise sensing material will be broken and lost sensitivity. 1.6 Applied higher voltage Applied voltage on sensor should not be higher than stipulated value, even if the sensor is not physically damaged or broken, it causes down-line or heater damaged, and bring on sensors’ sensitivity characteristic changed badly. 1.7 Voltage on wrong pins For 6 pins sensor, Pin 2&5 is heating electrodes, Pin (1,3)/(4,6) are testing electrodes (Pin 1 connects with Pin 3, while Pin 4 connects with Pin 6).If apply voltage on Pin 1&3 or 4&6, it will make lead broken; and no signal putout if apply on pins 2&4. Fig8. Lead sketch 2 .Following conditions must be avoided 2.1 Water Condensation Indoor conditions, slight water condensation will influence sensors’ performance lightly. However, if water condensation on sensors surface and keep a certain period, sensors’ sensitive will be decreased. 2.2 Used in high gas concentration No matter the sensor is electrified or not, if it is placed in high gas concentration for long time, sensors characteristic will be affected. If lighter gas sprays the sensor, it will cause extremely damage. 2.3 Long time storage The sensors resistance will drift reversibly if it’s stored for long time without electrify, this drift is related with storage conditions. Sensors should be stored in airproof bag without volatile silicon compound. For the sensors with long time storage but no electrify, they need long galvanical aging time for stability before using. The suggested aging time as follow: Stable2. Storage Time Suggested aging time Less than one month No less than 48 hours 1 ~ 6 months No less than 72 hours More than six months No less than 168 hours 2.4 Long time exposed to adverse environment No matter the sensors electrified or not, if exposed to adverse environment for long time, such as high humidity, high temperature, or high pollution etc., it will influence the sensors’ performance badly. 2.5 Vibration Continual vibration will result in sensors down-lead response then break. In transportation or assembling line, pneumatic screwdriver/ultrasonic welding machine can lead this vibration. 2.6 Concussion If sensors meet strong concussion, it may lead its lead wire disconnected. 2.7 Usage Conditions 2.7.1For sensor, handmade welding is optimal way. The welding conditions as follow:  Soldering flux: Rosin soldering flux contains least chlorine Tel: 86-371-67169097/67169670 Fax: 86-371-60932988 Email: sales@winsensor.com Zhengzhou Winsen Electronics Technology Co., Ltd www.winsensor.com  homothermal soldering iron  Temperature: 250℃  Time:less than 3 seconds 2.7.1If users choose wave-soldering, the following conditions should be obey:      Soldering flux: Rosin soldering flux contains least chlorine Speed: 1-2 Meter/ Minute Warm-up temperature:100±20℃ Welding temperature:250±10℃ One time pass wave crest welding machine If disobey the above using terms, sensors sensitivity will reduce. Zhengzhou Winsen Electronics Technology Co., Ltd Add: No.299, Jinsuo Road, National Hi-Tech Zone, Zhengzhou 450001 China Tel: +86-371-67169097/67169670 Fax: +86-371-60932988 E-mail: sales@winsensor.com Website: www.winsensor.com Tel: 86-371-67169097/67169670 Fax: 86-371-60932988 Email: sales@winsensor.com
SEN-09403 价格&库存
很抱歉,暂时无法提供与“SEN-09403”相匹配的价格&库存,您可以联系我们找货
