605-00010
605-00010
    PARALLAXINC.
605-00010 数据手册
Hanwei Electronics MG-811 MG811 http: //www.hwsensor.com CO2 Sensor Features Good sensitivity and selectivity to CO2 Low humidity and temperature dependency Long stability and reproducibility Application Air Quality Control Ferment Process Control Room Temperature CO2 concentration Detection Structure and Testing Circuit Sensor Structure and Testing Circuit as Figure, It composed by solid electrolyte layer (1) ,Gold electrodes(2) ,Platinum Lead (3) ,Heater(4) ,Porcelain Tube(5) ,100m double-layer steeless net(6),Nickel and copper plated ring(7) ,Bakelite (8),Nickel and copper plated pin(9) 。 Figure 1B Figure 1A Working Principle Sensor adopt solid electrolyte cell Principle,It is composed by the following solid cells: Air,Au|NASICON|| carbonate|Au, air,CO2 When the sensor exposed to CO2,the following electrodes reaction occurs: Cathodic reaction:2Li + + CO2 + 1/2O2 + 2e - = Li2CO3 Anodic reaction:2Na+ + 1/2O2 + 2e- = Na2O Overall chemical reaction:Li2CO3 + 2Na + = Na2O + 2Li + + CO2 The Electromotive force(EMF) result from the above electrode reaction, accord with according to Nernst’s equation:: EMF = Ec - (R x T) / (2F) ln (P(CO2)) P(CO2)—CO2--- partial Pressure Ec—Constant Volume R—Gas Constant volume T— Absolute Temperature (K)F—Faraday constant From Figure 1B, Sensor Heating voltage supplied from other circuit , When its surface temperature is high enough , the sensor equals to a cell, its two sides would output voltage signal ,and its result accord with Nernst’s equation。 In sensor testing, the impedance of amplifier should be within 100—1000GΩ,Its testing Tel: 86-371-67169080 Fax: 86 371 67169090 E-mail: sales@hwsensor.com Hanwei Electronics MG-811 http: //www.hwsensor.com current should be control below 1pA. Specifications : Symbol Parameter Name Technical VH Heating Voltage 6.0±0.1 V RH Heating Resistor 30.0±5%Ω IH Heating Current @200mA PH Heating Power @1200mW Tao Operating Temperature -20—50 Tas Storage Temperature -20—70 Output 30—50mV EM F Remarks AC or DC Room Temperature 350—10000ppmCO2 Sensitivity : Figure 2 Shows gas sensor sensitivity curve. : Conditions: Tem :28℃、 RH:65%、 Oxygen :21% EMF: sensor EMF under different gas and concentration . Response and Resume Characteristic: Figure 3 shows Solid electrolyte sensor response and resume characteristics. Temperature and Humidity Dependency : Tel: 86-371-67169080 Fax: 86 371 67169090 E-mail: sales@hwsensor.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Parallax: 605-00010
605-00010
物料型号:MG811 CO2传感器
器件简介: - 该传感器对CO2具有良好的灵敏度和选择性。 - 湿度和温度依赖性低。 - 长期稳定性和可重复性好。
应用信息: - 空气质量控制 - 发酵过程控制 - 室温下CO2浓度检测
结构和测试电路: - 由固体电解质层、金电极、铂引线、加热器、瓷管、100m双螺旋网、镍铜镀环、酚醛树脂、镍铜镀针组成。
工作原理: - 基于固体电解质电池原理,当传感器暴露于CO2时,会发生电极反应,产生电势差(EMF),符合能斯特方程。
参数特性: - 加热电压:6.0±0.1V(交流或直流) - 加热电阻:30.0±5%(室温) - 加热电流:200mA - 加热功率:1200mW - 工作温度范围:-20-50°C - 存储温度范围:-20-70°C - 输出:30-50mV(在350-10000ppm CO2下)
功能详解: - 灵敏度曲线显示在特定条件下对不同气体和浓度的EMF响应。 - 响应和恢复特性曲线展示了在3500ppm CO2下的响应和恢复特性。 - 温度和湿度依赖性图表显示了在不同温度和湿度条件下传感器的性能。
封装信息: - 文档中未提供封装信息,但通常这类传感器会有详细的封装规格说明。
605-00010 价格&库存
很抱歉,暂时无法提供与“605-00010”相匹配的价格&库存,您可以联系我们找货
