SEN-10221
SEN-10221
    SPARKFUNELECTRONICS
SEN-10221 数据手册
Continuous Fluid Level Sensor PN-12110215TC-8 eTape TM Description The eTape sensor is a solid state, continuous (multi-level) fluid level sensor for measuring levels in water, non-corrosive water based liquids and dry fluids (powders). The eTape sensor is manufactured using printed electronic technologies which employ additive direct printing processes to produce functional circuits. Theory of Operation The eTape sensor's envelope is compressed by hydrostatic pressure of the fluid in which it is immersed resulting in a change in resistance which corresponds to the distance from the top of the sensor to the fluid surface. The eTape sensor provides a resistive output that is inversely proportional to the level of the liquid: the lower the liquid level, the higher the output resistance; the higher the liquid level, the lower the output resistance. Specifications Sensor Length: 10.1" (257 mm) Resolution: < 0.01“(0.25 mm) Thickness: 0.015" (0.381mm) Actuation Depth: Nominal 1” (25.4 mm) Width: 1.0" (25.4 mm) Reference Resistor (Rref): 1500 , ±10% Active Sensor Length: 8.4" (213 mm) Connector: Crimpflex Pins Sensor Output: 1500 Temperature Range: 15°F - 150°F (-9°C - 65°C) empty, 300 Resistance Gradient: 140 full, ±10% /inch (56 /cm), ±10% Power Rating: 0.5 Watts (VMax = 10V) Sensor Output The eTape can be modeled as a variable resistor (300 – 1500 Ω ± 10%). The typical output characteristics of the eTape sensor are show in the figure below: Typical eTape Sensor Output - PN 12110215TC-8 1.60 1.50 1.40 Sensor Output (Kohms) 1.30 1.20 1.10 1.00 0.90 0.80 0.70 0.60 0.50 0.40 0.30 0.20 0.10 0.00 0 1 2 3 4 5 6 7 8 Liquid Level (Inches) Milone Technologies, Inc - 17 Ravenswood Way - Sewell, New Jersey 08080 - Phone: (856) 270-2688 Email: info@milonetech.com Web: www.milonetech.com 9 eTape TM Continuous Fluid Level Sensor PN-12110215TC-8 Connection and Installation Connect to the eTape by attaching a 4 pin connector with pre-soldered wires to the Crimpflex pins. Do not solder directly to the Crimpflex pins. The inner two pins (pins 2 and 3) are the sensor output (Rsense). The outer pins (pins 1 and 4) are the reference resistor (Rref) which can be used for temperature compensation. Suspend the eTape sensor in the fluid to be measured. To work properly the sensor must remain straight and must not be bent vertically or longitudinally. For best results install the sensor inside a section of 1-inch diameter PVC pipe. Double sided adhesive tape may be applied to the upper back portion of the sensor to suspend the sensor in the container to be measured. However, the liquid must be allowed to interact freely with both sides of the sensor. The vent hole located above the max line allows the eTape to equilibrate with atmospheric pressure. The vent hole is fitted with a hydrophobic filter membrane to prevent the eTape from being swamped if inadvertently submerged. Sample Circuits Custom Applications The eTape sensor can be manufactured in custom lengths to fit any application. Contact Milone Technologies if you have an application that requires specific length, configuration or output characteristics. Technical Support If you require technical support for the eTape liquid level sensor, please contact our technical support department by email at: techsupport@milonetech.com. Innovative Fluid Sensing Milone Technologies, Inc - 17 Ravenswood Way - Sewell, New Jersey 08080 - Phone: (856) 270-2688 Email: info@milonetech.com Web: www.milonetech.com
SEN-10221 价格&库存
很抱歉,暂时无法提供与“SEN-10221”相匹配的价格&库存,您可以联系我们找货
