Digi Connect® Tank
Fully integrated, Cellular Enabled Tank Level Sensor
Monitor tank level and location remotely using cellular
technologies to optimize operations.
Overview
Digi Connect Tank is a fully integrated cellular-enabled
tank level sensor providing remote access to deployed tanks,
totes and containers. Part of the Digi Tank solutions offer, it
leverages Digi Device Cloud and integration services, enabling
customers who own or manage large numbers of tanks to easily
integrate into existing applications or work with 3rd party
applications.
Application Highlight
Diesel Exhaust
Fluid (DEF) Distributor
Tank Monitoring
or Supply Chain
Managment Application
Cellular/
VPN
Digi Connect Tank provides logistical and operational
optimization via tank level and location data. Customers can
route feet and personnel efficiently, reduce transportation and
fuel costs, and increase supply chain predictability.
Digi Connect® Tank
Ultrasonic DEF
Level Sensing
top
kS
uc
Tr
Using 3G/2G cellular technologies, Digi Connect Tank can be
installed in locations where network infrastructure may not
available. Its small form factor, durable NEMA 4X enclosure,
industry safety ratings and long-life battery make this product
ideal for use in a broad range of tank applications.
Remote Site
Features/Benefits
Target Applications
• Remote access to tanks located virtually anywhere
• Fully integrated sensor/long life-battery/
global cellular in NEMA 4X enclosure for broad tank
application support
• Tank location and level provides logistical and
operational optimization
Cooking Oil Recycling
Chemicals
Water/Waste Water
- Reduced transportation/fuel costs via efficient
routing of fleet and personnel
- Predictable and efficient supply chain
management
Waste Oil
Agriculture
Diesel Exhaust Fluid
• Integrated ultrasonic sensor for non-contact liquid
level measurements
- Includes temp/sound speed compensation
www.digi.com
Specifications
Digi Connect® Tank
WWAN
Carriers
AT&T, International GSM Carriers*
North American Version: Dual Band UMTS/HSPA+ (850,1900 MHZ)
International Version: Dual Band UMTS/HSPA+ (900/2100 MHZ) Dual-Band GSM (900/1800 MHZ)
Frequency Band
Data Rate
HSDPA Cat. 10 / HSUPA Cat.6 data rates
DL: max. 14.4 Mbps, UL: max. 5.76 Mbps
>> EDGE class 12 data rates:
DL: max. 237 kbps, UL: max. 237 kbps
>> GPRS class 12 data rates
DL: max. 85.6 kbps, UL: max. 85.6 kbps
Antenna
Built-in
SIM Slots
1
Short Range
Sensor
Model
Massa M-300/150
Type
Range
Mid Range
Massa M-300/95
Ultrasonic, Built-in temperature/sound speed compensation
Range at -20˚ C to +65˚ C:
4 inches (100 mm) to 7 feet (2.1 meters)
1 feet (0.3meters) to 13 feet (4 meters)
Range at -30˚ C to -20˚ C:
4 inches (100 mm) to 5 feet (1.5 meters)
1 feet (0.3meters) to 12 feet (3.7 meters)
GPS/Glonass
Channels
Tracking Sensitivity
TTFF (Typical)
Horizontal Accuracy
Antenna
56
GPS: -161 dBm; Glonass: -158 dBm
Cold Start: 30 seconds, Warm Start: 28 seconds; Glonass: Cold Start: 32s, Warm Start 25s
GPS: 2.5m; Glonass: 4m
Built-in
Management
Configuration & Management
Protocol
Device Cloud/Local USB to Serial CLI
TCP
Power
Battery
Battery Life
7.2V, 14.5 Ah, Lithium Thionyl Chloride, non-rechargeable, replaceable
Approximately 2 years (@ 2 reads/transmits per day)
Environmental
Operating Temperature
Storage Temperature
-30˚ C to +65˚ C (See range limitations in Sensor section above)
-30˚ C to +50˚ C (for ATEX rated applications)
-40˚ C to +85˚ C
Relative Humidity
90% (Non-condensing after 90%)
Battery Discharge
很抱歉,暂时无法提供与“CTANK-M510”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7190.286331+929.89953
