ACY011
ACY011
    MATRIXORBITAL
    NTCTHERMISTOR10KOHM0.5CBEAD
ACY011 数据手册
ACCU-CURVE™ Precision Interchangeable Thermistors Extremely Accurate Temperature Sensing for Medical, Industrial, Automotive, HVAC, and Aerospace Applications Ametherm’s Interchangeable ACCU-CURVE™ NTC thermistors provide a high degree of measurement accuracy over the -0°C to +70°C temperature range. With a fast response time and long-term stability, these cost effective devices are ideal for a wide range of applications. Available at 800 - 808 - 2434 www.ametherm.com Precision Temperature Measurement & Control Devices NTC THERMISTORS Negative Temperature Coefficient (NTC) thermistors are thermally sensitive semiconductor resistors which ACCU-CURVE™ exhibit a decrease in resistance as absolute temperature increases. Change in the resistance of the NTC FEATURES thermistor can be brought about either by a change in the ambient temperature or internally by self-heating resulting from current flowing through the device. Most of the practical applications of NTC thermistors are • Wide Ohmic Value Range based on these material characteristics. • Accurate & Stable • D.C. 1mW/°C INTERCHANGEABLE THERMISTORS Ametherm manufactures precision resistance-temperature matched ACCU-CURVE™ thermistors. These devices offer interchangeability over a broad temperature range and eliminate the need to individually calibrate or provide circuit compensation for part variability. Accurate temperature measurement to + O.1°C is available over the 0°C to 70°C temperature range. Standard ohmic values at 25°C range from 2,252 to 100,000 ohms. • Fast Thermal Response Time • T.C. 10 Sec. in Air • Compact Epoxy Package Style • High Sensitivity THERMISTOR TERMINOLOGY FOR TEMPERATURE MEASUREMENT & CONTROL DEVICES • D.C. — The dissipation constant is the ratio, normally expressed in milliwatts per degree C (mw/°C), at a specified ambient temperature, of a change in power dissipated in a thermistor to the resultant change in body temperature. • T.C. — The thermal time constant is the time required for a thermistor to change 63.2% of the total difference between its initial and final body temperature when subjected to a step function change in temperature under zero-power conditions and is normally expressed in seconds (S). • Alpha (Ω) or Temperature Coefficient of Resistance — The temperature coefficient of resistance is the ratio at a specified temperature, T, of the rate of change of zero-power resistance with temperature to the zero-power resistance of the thermistor. The temperature coefficient is commonly expressed in percent per degree C (%/°C). Applications There are numerous ways of measuring temperature electronically. Improvements in thermistor technology, coupled with the introduction of integrated circuitry, have made precision temperature measurement systems very cost effective. Microprocessors, A/D converters, interface electronics and displays are readily available. Circuit designs with built-in thermistor resistance-temperature algorithms have gained wide spread acceptance in precision temperature metrology. ACCU-CURVE™ style thermistors are used in many applications that require a high degree of accuracy and reliability. Some of the most popular applications of NTC ACCU-CURVE™ thermistors include: • Temperature Measurement & Control • Temperature Sensors SELECTION CONSIDERATIONS FOR NTC ACCU-CURVE™ DEVICES Interchangeable ACCU-CURVE™ NTC thermistors are usually selected when a high degree of measurement accuracy is required over a wide temperature range. By modifying the Alpha equation, the resistance and temperature tolerances can be calculated for various temperature intervals. Because thermistors are non-linear with respect to their resistance-temperature characteristics, Alpha therefore is non-linear across their resistancetemperature range. As an example, a thermistor material curve with an Alpha of -4.4%/°C @ 25°C will have an Alpha of -3.8%/°C @ 50°C. For practical applications we recommend that the standardized R/T curves be used. ACCU-CURVE™ thermistors can dissipate 1mW/°C. As a result, the possibility of error induced by excessive current flow, which would defeat the level of accuracy these devices are capable of representing, may exist in some circuits. To prevent this type of error, Ametherm recommends that circuit design engineers select the highest R value their circuit will tolerate for applications > 5 Volts to minimize any self-heating of the thermistor device. Refer to the ACCU-CURVE™ Specifications table for resistance values and temperature tolerances. Ametherm offers two standard R/T curves, “C” & “W”, with temperature coefficients of resistance (Ω) of -4.4%/°C and -4.7%/°C, and Beta (ß) values of 3965°K and 4250°K. To determine the nominal resistance value of a thermistor at a specified temperature, multiply its resistance at 25°C value by the corresponding RT/R25 value for the desired temperature and applicable R-T curve from the ACCU-CURVE™. T: 800-808-2434 | 775-884-2434 (Outside the United States and Canada | www.ametherm.com | info@ametherm.com ACCU-CURVE™ Specifications Part Number Resistance @ 25°C (Ω) Accuracy Between 0°C to 70 °C Dissipation Constant mW/°C Thermal Time Constant τ = sec Beta Value Measured Between 0°C and 50°C Operating Temperature Range °C Max Power Rating (mW) Color (Optional): ACC101 2252 +/-0.1°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Brown ACC001 2252 +/-0.2°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Brown ACC011 2252 +/-0.5°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Brown ACC021 2252 +/-1.0°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Brown ACC102 3000 +/-0.1°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Red ACC002 3000 +/-0.2°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Red ACC012 3000 +/-0.5°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Red ACC022 3000 +/-1.0°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Red ACC103 5000 +/-0.1°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Orange ACC003 5000 +/-0.2°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Orange ACC013 5000 +/-0.5°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Orange ACC023 5000 +/-1.0°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Orange ACC104 10,000 +/-0.1°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Yellow ACC004 10,000 +/-0.2°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Yellow ACC014 10,000 +/-0.5°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Yellow ACC024 10,000 +/-1.0°C ≥2 ≤ 3.5 3892°K 0°C ≈ 70°C 250 Yellow ACW105 30,000 +/-0.1°C ≥2 ≤ 3.5 4143°K 0°C ≈ 70°C 250 Green ACW005 30,000 +/-0.2°C ≥2 ≤ 3.5 4143°K 0°C ≈ 70°C 250 Green ACW015 30,000 +/-0.5°C ≥2 ≤ 3.5 4143°K 0°C ≈ 70°C 250 Green ACW025 30,000 +/-1.0°C ≥2 ≤ 3.5 4143°K 0°C ≈ 70°C 250 Green ACW106 50,000 +/-0.1°C ≥2 ≤ 3.5 4143°K 0°C ≈ 70°C 250 Blue ACW006 50,000 +/-0.2°C ≥2 ≤ 3.5 4143°K 0°C ≈ 70°C 250 Blue ACW016 50,000 +/-0.5°C ≥2 ≤ 3.5 4143°K 0°C ≈ 70°C 250 Blue ACW026 50,000 +/-1.0°C ≥2 ≤ 3.5 4143°K 0°C ≈ 70°C 250 Blue ACW107 100,000 +/-0.1°C ≥2 ≤ 3.5 4143°K 0°C ≈ 70°C 250 Violet ACW007 100,000 +/-0.2°C ≥2 ≤ 3.5 4143°K 0°C ≈ 70°C 250 Violet ACW017 100,000 +/-0.5°C ≥2 ≤ 3.5 4143°K 0°C ≈ 70°C 250 Violet ACW027 100,000 +/-1.0°C ≥2 ≤ 3.5 4143°K 0°C ≈ 70°C 250 Violet *ACM011 10,000 +/-0.5°C ≥ 0.7 ≤6 3435°K -40C≈105C 300 Black *ACY011 10,000 +/-0.5°C ≥ 0.7 ≤6 3977°K -40C≈105C 300 Black *ACL011 50,000 +/-0.5°C ≥ 0.7 ≤6 3950°K -40C≈105C 300 Black * Denotes the following: • Different Beta • Operating temperature change • Maximum power allowed T: 800-808-2434 | 775-884-2434 (Outside the United States and Canada | www.ametherm.com | info@ametherm.com ACC-XXX “C” CURVE TEMP. °C 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 RT/R25 3.265 3.103 2.950 2.805 2.669 2.539 2.417 2.301 2.192 2.088 1.990 1.897 1.809 1.725 1.646 1.571 1.500 1.432 1.368 1.307 1.249 1.194 1.142 1.092 1.045 1.000 0.9573 0.9167 0.8777 0.8407 0.8057 0.7723 0.7403 0.7097 0.6807 0.6530 0.6267 0.6017 0.5777 0.5547 0.5327 0.5117 0.4917 0.4727 0.4543 0.4370 0.4200 0.4040 0.3890 0.3743 0.3603 0.3467 0.3340 0.3217 0.3099 0.2986 0.2878 0.2774 0.2675 0.2579 0.2488 0.2400 0.2316 0.2235 0.2157 0.2083 0.2011 0.1942 0.1876 0.1813 0.1752 ACC-XXX “W” CURVE TEMP. °C 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 RT/R25 3.265 3.103 2.950 2.805 2.669 2.539 2.417 2.301 2.192 2.088 1.990 1.897 1.809 1.725 1.646 1.571 1.500 1.432 1.368 1.307 1.249 1.194 1.142 1.092 1.045 1.000 0.9573 0.9167 0.8777 0.8407 0.8057 0.7723 0.7403 0.7097 0.6807 0.6530 0.6267 0.6017 0.5777 0.5547 0.5327 0.5117 0.4917 0.4727 0.4543 0.4370 0.4200 0.4040 0.3890 0.3743 0.3603 0.3467 0.3340 0.3217 0.3099 0.2986 0.2878 0.2774 0.2675 0.2579 0.2488 0.2400 0.2316 0.2235 0.2157 0.2083 0.2011 0.1942 0.1876 0.1813 0.1752 ACCU-CURVE™Resistance / Temperature Conversion Tables To determine the nominal resistance value of a thermistor at a specified temperature, multiply its R T / R 25 value for the desired temperature and R-T curve from the table above by its nominal resistance at 25 °C. Contact us today for more information or to order your free samples. T : 800-808-2434 775-884-2434 (Outside the US and Canada) F : 775-884-0670 www.ametherm.com info@ametherm.com 961 Fairview Drive Carson City, Nevada 89701 USA
ACY011 价格&库存
很抱歉,暂时无法提供与“ACY011”相匹配的价格&库存,您可以联系我们找货
