MF51B474F4300
MF51B474F4300
    CANTHERM
    THERMISTOR NTC PREC 470K OHM 1%
MF51B474F4300 数据手册
MF58 MF51 PRECISION GLASS ENCAPSULATED NTC THERMISTORS (MF58 & MF51) MF58 Glass Shell Precision NTC Thermistors The MF58 is a NTC thermistor which is manufactured using a combination of ceramic and semiconductor techniques. It is equipped with tinned axial leads and then wrapped with purified glass. Applications Dimensions (mm) Temperature compensation and detection for: • Household appliances (air conditioners, micrwave ovens, electric fans, electric heaters etc.) • Office equipment (copiers, printers etc.) • Industrial, medical, environmental, weather and food processing equipment • Liquid level detection and flow rate measurement • Mobile phone battery • Apparatus coils, integrated circuits, quartz crystal oscillators and thermocouples. Features • Good stability and repeatability • High reliability • Wide range of resistance: 0.1~1000KΩ • Tight tolerance on resistance and Beta values • Usable in high-temperature and high-moisture environments • Small, light, strong package, • Suitable for automatic insertion on thru-hole PCBs • Rapid response • High sensitivity Specifications Main Techno-Parameter • Zero power resistance range (R25): 0.1~1000KΩ • Available tolerances of R25: F=±1% G=±2% H=±3% J=±5% K=±10% • B value (B25/50°C) range: 3100~4500K • Available tolerances of B value: ±0.5%, ±1%, ±2% • Dissipation factor: ≥2mW/°C (In Still Air) • Thermal time constant: ≤20S (In Still Air) • Operating temperature range: -55°C ~ +200°C • Rated Power: ≤50mW MF51-B Precision Glass Encapsulated NTC Thermistor for Temperature Measurement The MF51 NTC thermistor is a small chip thermistor encased in glass with bare radial copper leads. The chip is made from a new material using new techniques which provide benefits such as high precision, fast response, reliable stability, no aging effect and improved moisture resistance. Applications Dimensions (mm) It can be used in applications such as refrigeration, HVAC, heating equipment, electronic thermostats, liquid level sensing, automotive electronics, electronic dashboards, etc. Specifications The fourth pane shows the Beta value (B25/50C) The third pane shows the tolerance code of rated resistance. The second pane shows the rated resistance at 25C (R25). The first pane holds the dimensional code. Type high precision temp. measurement chip in glass NTC thermisor Note: Specifications can change without notice. MF51 Continued > MF51-B Physical Characteristics Model Dissi. Coef (mW/ºC) Thermal Time Constant (S) In still air In still air ≥ 1.0 ≤ 12 MF51-B Model B Value (25/50ºC) Rated Resistance R25 KΩ MF51B _ _3380 2 - 10 MF51B _ _3950 10 - 50 MF51B _ _3950 50 -100 MF51B _ _4150 100 - 350 Tolerance ± 1% ± 2% ± 3% ± 5% K Tolerance 3380 3950 3950 4150 * ± 2% ± 3% Operating Temp. (ºC) -50ºC–260ºC * If the tolerance of R25 is ±1%, the tolerance of B25/50 = ±1%. If the tolerance of R25 is ±2% or greater, the tolerance of B25/50 = ±2%. 8415 Mountain Sights Avenue • Montreal (Quebec), H4P 2B8, Canada Tel: (514) 739-3274 • 1-800-561-7207 • Fax: (514) 739-2902 • E-mail: sales@cantherm.com Website: www.cantherm.com | Division of Microtherm 2011/Jan MF51/MF58
MF51B474F4300
PDF文档中包含的物料型号为MF58和MF51,它们是玻璃封装精密NTC热敏电阻。
器件简介指出MF58采用陶瓷和半导体技术制造,具有镀锡轴向引线和纯化玻璃包裹。
MF51则是小型芯片热敏电阻,具有裸铜径向引线和玻璃封装。
引脚分配方面,MF58具有镀锡轴向引线,而MF51具有裸铜径向引线。
参数特性包括零功率电阻范围(R25)为0.1~1000KΩ,B值(B25/50°C)范围为3100~4500K,耗散因子≥2mW/°C,热时间常数≤20S(静止空气中),工作温度范围为-55°C至+200°C,额定功率≤50mW。
功能详解中,MF58和MF51均适用于温度补偿和检测,包括家用电器、办公设备、工业、医疗、环境、气象和食品加工设备等。
应用信息显示,MF58和MF51可用于空调、微波炉、复印机、打印机等多种设备的温度补偿和检测。
封装信息方面,MF58的尺寸为长3.8mm、直径1.8mm,MF51的尺寸为长2.0mm、直径0.5mm。
以上信息提供了对MF58和MF51型号的详细分析。
MF51B474F4300 价格&库存
很抱歉,暂时无法提供与“MF51B474F4300”相匹配的价格&库存,您可以联系我们找货
MF51B474F4300
