STS210101L360500U129
    CANTHERM
    Axial
STS210101L360500U129 数据手册
STS2 Temperature sensor Replacement for KTY83 Applications - Household appliances - Electronics - Engineering - Automotive Benefits - Temperatures from -40°C up to +170°C - Excellent long-term temperature stability - High precision and reliability - No polarity reversal (+/-) possible TM Technical data type STS2 ratings 1010 Ω typ. resistance at 100°C (+-3%) operating temperature range -40°C ... +140 (145)°C min. insulation resistance (100 Vdc) 100 MΩ operating current 5 mA max. rated power 50 mW Standard types type execution drawing dimensions (mm) illustration technical description STS2 G918 housing PPS leads ETFE, AWG24, white STS2 U129 shrink sleeve Kynar® leads ETFE, AWG24, white STS2 CHIP chip only no insulation, no leads Temperature vs. resistance T°C -10 0 10 20 25 30 40 50 60 70 80 90 100 110 120 130 140 min. 735 806 881 959 1000 1039 1123 1210 1301 1396 1494 1596 1699 1806 1912 2024 2135 typ. 749 819 893 970 1010 1051 1137 1227 1321 1420 1522 1628 1737 1849 1963 2079 2197 max. 762 832 905 981 1020 1063 1151 1244 1342 1444 1550 1660 1775 1891 2014 2134 2258 ordering example 2500 STS2 1010 1 2000 L360 500 G918 resistance [Ω] Housing number Length of leads (+/- 10 mm) 1500 Leads white, AWG24, ETFE Tolerance (%) 1000 R at 25°C Type of sensor 500 0 T [°C] Remark: Values of electric resistance correspond almost exactly to KTY83. Above140°C the sensor may loose its linearity. RoHS compliant product TM Div. of Microtherm International Cooperation Canadian Thermostats & Control Devices, Ltd. Tel: (514) 739-3274 Fax: (514) 739-2902 8415 Mountain Sights Ave. Montreal, Canada H4P 2B8 1 (800) 561-7207 2016/AUGUST STS2 Subject to change without notice WEBSITE: www.cantherm.com E-Mail: sales@cantherm.com
物料型号:STS2 器件简介:温度传感器,可替代KTY83,适用于家用电器、电子产品、工程和汽车。 引脚分配:文档中未提供引脚分配信息。 参数特性: - 典型电阻值在100°C时为1010Ω(±3%) - 工作温度范围:-40°C至+140°C(或+145°C) - 最小绝缘电阻:100MΩ(100V直流) - 工作电流:5mA - 最大额定功率:50mW 功能详解:文档中未提供详细的功能解释。 应用信息:适用于温度范围从-40°C到+170°C,具有优异的长期温度稳定性、高精度和可靠性,且无需担心极性反转。 封装信息: - STS2 G918:PPS外壳,ETFE绝缘,AWG24线径,白色 - STS2 U129:Kynar收缩套管,ETFE绝缘,AWG24线径,白色 - STS2 CHIP:裸芯片,无绝缘,无引线
温度与电阻关系表提供了不同温度下的最小值、典型值和最大值。
订购示例说明了如何根据传感器类型、电阻值、长度、线径和公差进行订购。
STS210101L360500U129 价格&库存
很抱歉,暂时无法提供与“STS210101L360500U129”相匹配的价格&库存,您可以联系我们找货
