W83773GTR
W83773GTR
    NUVOTON(新唐)
    TSSOP8
    SENSORTEMPERATURESST8TSSOP
W83773GTR 数据手册
W83773G/SG W83773G / W83773SG Nuvoton H/W Monitoring IC DATE: OCTOBER 21TH, 2009 REVISION: 1.2 -I- W83773G/SG TABLE OF CONTENTS- 1. GENERAL DESCRIPTION ......................................................................................................... 1 1.1 2. Product Selection Guide ................................................................................................. 1 FEATURES ................................................................................................................................. 2 2.1 Monitoring Items - Temperature ..................................................................................... 2 2.2 General ........................................................................................................................... 2 2.3 Package .......................................................................................................................... 2 2.4 Application ...................................................................................................................... 2 3. KEY SPECIFICATIONS .............................................................................................................. 3 4. BLOCK DIAGRAM ...................................................................................................................... 4 5. PIN CONFIGURATION ............................................................................................................... 4 6. PIN DESCRIPTION ..................................................................................................................... 5 7. FUNCTIONAL DESCRIPTION.................................................................................................... 6 8. 7.1 General Description ........................................................................................................ 6 7.2 Access Interface ............................................................................................................. 7 7.3 Measured Temperature Data Format ............................................................................. 8 7.3.1 Measure Remote Temperature Data Format .................................................................... 8 7.3.2 Measure Local Temperature Data Format........................................................................ 8 7.4 Digital Filter ..................................................................................................................... 9 7.5 Fault Detect ................................................................................................................... 10 7.6 Conversion Rate and Moving Average ......................................................................... 10 CONTROL AND STATUS REGISTER ..................................................................................... 11 8.1 W83773G/SG Registers ............................................................................................... 11 8.2 Data Format of Temperature Registers ........................................................................ 12 8.3 Status Register 1 (SR1) ................................................................................................ 12 8.3.1 Status Register 2 (SR2).................................................................................................. 12 8.4 Configuration Register (C) ............................................................................................ 13 8.5 Conversion Rate Register (CR) .................................................................................... 13 - II - W83773G/SG 9. 10. 11. 12. 8.6 Filter Configure Register (RDTF) .................................................................................. 14 8.7 Ideality (IDEAA, IDEAB) ............................................................................................... 14 8.8 Remote Temperature B Enable (RTBE) *for W83773G-2/SG-2 only.......................... 14 ELECTRICAL CHARACTERISTIC ........................................................................................... 15 9.1 Absolute Maximum Ratings .......................................................................................... 15 9.2 DC Characteristics ........................................................................................................ 15 9.3 AC Characteristics ........................................................................................................ 16 TOP MARKING SPECIFICATIONS .......................................................................................... 17 10.1 W83773G and W83773SG TOP MARKING ................................................................. 17 10.2 W83773G-2 and W83773SG-2 TOP MARKING .......................................................... 17 PACKAGE SPECIFICATION .................................................................................................... 18 2 11.1 TSSOP (MSOP) 8L 3X3 MM ....................................................................................... 18 11.2 SOP8 150mil ................................................................................................................. 19 REVISION HISTORY ................................................................................................................ 20 - III - Publication Release Date: October 21, 2009 Revision 1.2 W83773G/SG 1. GENERAL DESCRIPTION The W83773G/SG, which integrates two remote and one local temperature sensors and a 2-wire TM System Management Bus (SMBus ) serial interface, is Nuvoton’s hardware monitoring IC specifically designed for PC, notebook and any embedded environments. Ideality factor configuration is also added in the W83L773G to eliminate temperature measurement error. The remote temperature sensor input can be connected to the thermal diode or transistor like 2N3904. With the two remote temperature sensors, the W83773G/SG can report the temperatures of both diodes in the Dual-core CPU. A 10-bit plus sign ADC (Analog to Digital Converter) with 0.125C resolution is built inside the W83773G/SG to convert the monitored temperature value. Programmable conversion rates and standby mode support low-power operation. The W83773G/SG is high temperature accuracy, low-power consumption, SMBus TM serial interface IC available in 8-pin, TSSOP (MSOP) and SOP packages. The working voltage is 3.3 V ±10%. 1.1 Product Selection Guide PART NUMBER FUNCTIONALITY SMBUS ADDRESS REMOTE W83773G 1001_100xb W83773G-2 1001_101xb W83773SG 1001_100xb W83773SG-2 1001_101xb PACKAGE LOCAL TSSOP-8 (MSOP-8) 2 1 SOP-8 -1- Publication Release Date: October 21, 2009 Revision 1.2 W83773G/SG 2. FEATURES 2.1 Monitoring Items - Temperature  Measure the temperature with high accuracy  One on-chip thermal sensor  Two remote temperature sensor inputs  Ideality Factor Configuration on two External Diodes.  Remote Diode Fault Detection. 2.2 General Features  Support SMBus  3.3V±10% VCC operation  10 bit plus sign remote temperature data format, 0.125C resolution  Programmable offset register for various thermal diodes  SMBus  Programmable conversion rates allow user to optimize the power consumption.  Report the temperatures of both diodes in the Dual-core CPU. 2.3 TM TM serial interface 2.0 compatible interface, supports TIMEOUT Package Type  W83773G in 8-pin TSSOP (MSOP)  W83773SG in 8-pin SOP 2.4 Applications  Desktop and Notebook computers, support down to 45nm processes and below. (Please refer to application notice for details)  Hardware Management  Servers  Embedded Applications -2- W83773G/SG 3. KEY SPECIFICATIONS  Local temperature range and accuracy  Remote temperature range and accuracy    Supply voltage Operating supply current Low Power Operation ADC resolution include sign bit  -40C to +125C (TA) Typ.  2C (20C~40C) *1 Max.  3C (-40C~125C) -40C to +127C (TD) Typ.  1C (25C ~70C) Typ.  2C (-40C ~127C) *2 Max.  3C (-40C~127C) 3.3V ± 10% 900 uA typ. 15μA Standby Current 10 Bits *1 Guaranteed by design from -40~125 degree C, 100% tested at 85 degree C. *2 Guaranteed by design from -40~127 degree C, 100% tested at 85 degree C. -3- Publication Release Date: October 21, 2009 Revision 1.2 W83773G/SG 4. BLOCK DIAGRAM xI Control Logic Current Generator SDA Command Coder/ DeCoder SCLK REGISTER BANK D 1+ (Local /Remote) Temperature Registers D 1- SMBus D 2+ D 2- Sensor Circuitry Analog Mux Configuration Registers ADC Local Thermal Sensor Status Registers 5. PIN CONFIGURATION 1 8 2 7 SCLK D1+ SDA D13 W83773G/SG 6 D2+ 4 5 D2- -4- VDD GND W83773G/SG 6. PIN DESCRIPTION PIN TYPE I/OD12ts PIN Attribute TTL level and schmitt trigger open drain output with 12 mA sink capability INts TTL level input pin and schmitt trigger AIN Input pin (Analog) POWER Positive power supply input GROUND Power supply ground PIN NAME NO PIN TYPE D1+ 1 AIN Connect to Thermal Diode Anode. D1- 2 AIN Connect to Thermal Diode Cathode. D2+ 3 AIN Connect to Thermal Diode Anode. D2- 4 AIN Connect to Thermal Diode Cathode. GND 5 VDD 6 POWER SDA 7 I/OD12 SCLK 8 INt s DESCRIPTION GROUND Power supply ground DC power supply, voltage input of 3.3V 10%. Digital I/O (Open drain). SMBus bidirectional serial data. Requires a pullup resistor. Digital Input (Open drain). SMBus serial clock input. Requires a pull-up resistor. -5- Publication Release Date: October 21, 2009 Revision 1.2 W83773G/SG 7. FUNCTIONAL DESCRIPTION 7.1 General Description The W83773G/SG provides two remote temperature sensor inputs which can be connected to the remote 2N3904 transistor, or CPU/GPU thermal diode, and one local on-die thermal sensor to detect the ambient temperature. The W83773G/SG supplies Ideality Factor Configuration on one External Diode to eliminate the temperature measurement error. In addition, the W83773G/SG also reports both temperatures of the external temperature zones and supports selectable conversion rates and modes for low power operation. The data format of the remote temperature is represented by a 10-bit plus sign, two’s complement word and 11-bit unsigned binary word with an LSB equal to 0.125C. The real temperature equals the measured temperature plus or minus the offset value. The offset value can be set in the offset registers. The date format of the offset registers is the same as the data format of the remote temperature. Local Temperature data is represented by an 8-bit plus sign, two’s complement format, with an LSB equal to 1C. -6- W83773G/SG 7.2 Access Interface The W83773G/SG/AG provides SMBus serial interface to read/write internal registers, and the SMBus address for read and write is 10011001b and 10011000b, respectively. The W83773G-2 and W83773SG-2 respond to hard-wire SMBus slave address as shown in Table 1.1 The first serial bus access timing is shown as followed: (a) Serial bus write to the internal address register followed by the data byte 0 7 8 0 7 8 SCLK 10 SDA 01 0 Start By Master 1 00 1 01 R/W D7 D6 Ack Ack by by 785R 773G Frame 1 Serial Bus Address Byte D5 D4 D3 D2 D1 D0 Ack Ack by by 785R 773G Frame 2 Internal Index Register Byte 0 7 8 SCLK (Continued) SDA (Continued) D7 D6 D5 D4 D3 D2 D1 D0 Ack Ack by by by 784R 785R 773G Frame 3 Data Byte Stop by Master (b) Serial bus read form the internal address register followed by the data byte 0 7 8 0 7 8 SCLK SDA 10 Start By Master 01 0 1 1 00 01 R/W D7 D6 Ack ack by by 773G Frame 1 Serial Bus Address Byte 1 2 3 4 5 6 10 01 0 1 1 00 01 D4 D3 D2 D1 D0 ack Ack by by 773G 785R Frame 2 Internal Index Register Byte 785R 0 D5 7 8 0 1 2 3 4 5 D7 D6 D5 D4 D3 D2 6 7 D1 D0 8 SCLK(Continued) SDA(Continued) Frame 3 Serial Bus Byte R/W Ack ack by by 773G 785R by Frame 4 Data Byte 784R Ack Stop by Master ack no Ack by by 785R Master Figure 2. Serial Bus read from Internal Address Register followed by the Data Byte -7- Publication Release Date: October 21, 2009 Revision 1.2 W83773G/SG 7.3 Measured Temperature Data Format The W83773G/SG can measure the remote temperature with the resolution of 11-bit two’s complement format, as well as the local temperature with the resolution of 8-bit two’s complement format. 7.3.1 Measure Remote Temperature Data Format Table 7.3.1 shows the remote temperature data with 11-bit two’s complement format. Table 7.3.1 Measured Remote Temperature Data Format TEMPERATURE 7.3.2 8-BIT DIGITAL OUTPUT HIGH BYTE 8-BIT DIGITAL OUTPUT LOW BYTE +127.875°C 0111,1111 111X,XXXX +25.750°C 0001,1001 110X,XXXX +2.250°C 0000,0010 010X,XXXX +1.125°C 0000,0001 001X,XXXX +0.000°C 0000,0000 000X,XXXX - 1.125°C 1111,1110 111X,XXXX - 2.250°C 1111,1101 110X,XXXX - 25.750°C 1110,0110 010X,XXXX - 127.875°C 1000,0000 001X,XXXX Measure Local Temperature Data Format Table 7.3.2 shows the local temperature data with 8-bit two’s complement format. Table 7.3.2 Measured Local Temperature Data Format TEMPERATURE 8-BIT DIGITAL OUTPUT +127°C 0111,1111 +25°C 0001,1001 +2°C 0000,0010 +1°C 0000,0001 +0°C 0000,0000 - 1°C 1111,1111 - 2°C 1111,1110 - 25°C 1110,0111 - 128°C 1000,0000 -8- W83773G/SG 7.4 Digital Filter The W83773G/SG provides three Digital Filter levels to suppress erroneous remote temperature readings due to noise. The register address to set the digital filter is at Filter Configure Resister. If set bits = , then no filter is selected. If set bits = or , then filter level 1 is selected. If set bits = , then level 2 is selected. Figure 7.4.1 shows the step response of reading remote temperature with different filter level, and Figure 7.4.2 shows the impulse response. Temperature (oC) 5 0 4 5 4 0 No Filter Level 3 5 Filter Level 1 Filter Level 2 3 0 2 5 0 5 1 1 2 0 5 0 SAMPLE NUMBER 2 5 Figure 7.4.1 Step Response of reading remote temperature Temperature (oC) 5 0 4 5 4 0 No Filter Level 3 5 Filter Level 1 Filter Level 2 3 0 2 5 0 5 1 1 2 0 5 0 SAMPLE NUMBER 2 5 Figure 7.4.2 Impulse Response of reading remote temperature -9- Publication Release Date: October 21, 2009 Revision 1.2 W83773G/SG 7.5 Fault Detect Table 7.5 shows the response of Fault Detection if the false connection of D+ and D- occurs after power-up. Please also refer to the W83L771AWG_773G_775G Application Note 2.pdf for implementation. Table 7.5 response of Fault Detect 7.6 Connection Status Register bit Measured Remote A or B Temperature (D+, D-) (OPENA or OPENB) (VDD, Floating) 1 +127.875 ℃ (GND, Floating) 1 +127.875 ℃ (Floating, Floating) 1 +127.875 ℃ Short 1 +127.875 ℃ Conversion Rate and Moving Average The W83773G/SG provides an embedded moving average into conversion rate selection. Each conversion rate can set a couple of proper noise rejection and average supply current. - 10 - W83773G/SG 8. CONTROL AND STATUS REGISTER 8.1 W83773G/SG Registers REGISTER NAME READ ADDRESS WRITE ADDRESS (HEX) (HEX) (HEX) POWER ON DEFAULT STATES BINARY / HEX DECIMAL Local Temperature (LT) 00h Read Only 0000,0000b / 00h 0 Remote Temperature A High Byte (RTAHB) 01h Read Only 0000,0000b / 00h 0 Status Register 1 (SR1) 02h Read Only 0000,0000b / 00h 0 Configuration (C) 03h 09h 0000,0001b / 01h 1 Conversion Rate (CR) 04h 0Ah 0000,1000b / 08h 8 Remote Temperature A Low Byte (RTALB) 10h Read Only 0000,0000b / 00h 0 Remote Temperature A Offset High Byte (RTAOHB) 11h 11h 0000,0000b / 00h 0 Remote Temperature A Offset Low Byte (RTAOLB) 12h 12h 0000,0000b / 00h 0 Remote Temperature B Offset High Byte (RTBOHB) 15h 15h 0000,0000b / 00h 0 Remote Temperature B Offset Low Byte (RTBOLB) 16h 16h 0000,0000b / 00h 0 Status Register 2 (SR2) 17h Read Only 0000,0000b / 00h 0 Remote Temperature B High Byte (RTBHB) 24h Read Only 0000,0000b / 00h 0 Remote Temperature B Low Byte (RTBLB) 25h Read Only 0000,0000b / 00h 0 Remote Diode Temperature Filter (RDTFA, RDTFB) BFh BFh 0000,0000b / 00h 0 Remote Diode A ideality (IDEAA) E3h E3h 1000,0100b / 84h 132 Remote Diode B ideality (IDEAB) E4h E4h 1000,0100b / 84h 132 Remote Temperature B Enable (RTBE) Write Only E8h 0101,0101b / 55h 85 Read Manufacturer’s ID (RMID) FEh Read Only 0101,1100b / 5Ch 92 Read Die Revision (RDR) FFh Read Only 0001,0000b /10h 16 0001,0001b /11h 17 0001,0011b /13h 19 *For W83773G-2/SG-2 only. - 11 - Publication Release Date: October 21, 2009 Revision 1.2 W83773G/SG 8.2 Data Format of Temperature Registers (LT, RTAHB, RTALB, RTBHB, RTBLB, RTAOHB, RTAOLB, RTBOHB, RTBOLB) REGISTER: LT, RTHB, LHS, RHSHB, LLS, RLSHB,RTAOHB, RTBOHB DATA FORMAT: TWO’S COMPLEMENT FORMAT BIT D7 D6 D5 D4 D3 D2 D1 D0 VALUE Sign 64 32 16 8 4 2 1 Unit: ℃ REGISTER: RTLB, RHSLB, RTAOLB, RTBOLB DATA FORMAT: TWO’S COMPLEMENT FORMAT BIT D7 D6 D5 D4 D3 D2 D1 D0 VALUE 0.5 0.25 0.125 0 0 0 0 0 8.3 Status Register 1 (SR1) BIT FLAG NAME D7 Busy D6 Reserve D5 Reserve D4 Reserve D3 Reserve D2 OPENA D1 Reserve D0 Reserve 8.3.1 BIT DESCRIPTION ‘1’ indicates ADC is busy converting. ‘1’ indicates Remote Diode 1 is disconnected. Status Register 2 (SR2) FLAG NAME D7 Reserve D6 Reserve D5 Reserve D4 Reserve D3 Reserve D2 OPENB D1 Reserve D0 Reserve DESCRIPTION ‘1’ indicates a Remote Diode 2 is disconnected. - 12 - W83773G/SG 8.4 Configuration Register (C) BIT 8.5 FLAG NAME DESCRIPTION D7 Reserved D6 STOP/ RUN If this bit is set to ‘1’, Device enters standby mode. D5 0 No definition and can be read as 0. D4 Reserved D3 0 D2 Reserved D1 0 No definition and can be read as 0. D0 Reserved Reserved No definition and can be read as 0. Conversion Rate Register (CR) REGISTER: CR (DEFAULT CONVERSION RATE: 16HZ) (OPENA, OPENB) (01,10) 00 11 Temp. sensor 1 local + 1remote(A or B) 2 remote + 1 local 1 local BIT Frequency/Time(Sec) Average Frequency/Time(Sec) Average IVDD IVDD Frequency/Time(Sec) Average IVDD 00h 0.0625Hz/16 == 0.0625Hz/16 == 0.0625Hz/16 == 01h 0.125Hz/8 == 0.125Hz/8 == 0.125Hz/8 == 02h 0.25Hz/4 == 0.25Hz/4 == 0.25Hz/4 == 03h 0.5Hz/2 211uA 0.5Hz/2 211uA 0.5Hz/2 211uA 04h 1Hz/1 232uA 1Hz/1 232uA 1Hz/1 232uA 05h 2Hz/0.5 331uA 2Hz/0.5 331uA 2Hz/0.5 331uA 06h 4Hz/0.25 393uA 4Hz/0.25 393uA 4Hz/0.25 393uA 07h 8Hz/0.125 589uA 8Hz/0.125 589uA 8Hz/0.125 589uA 08h 16Hz/0.0625 833uA 16Hz/0.0625 833uA 16Hz/0.0625 833uA 09h-FFh Reserve Reserve - 13 - Reserve Publication Release Date: October 21, 2009 Revision 1.2 W83773G/SG 8.6 Filter Configure Register (RDTF) BIT COMMAND DESCRIPTION 0 No definition and can be read as 0. RDTFB =: No Filter Selected Filter Level = or : Filter Level 1 Selected =: Filter Level 2 Selected RDTFA =: No Filter Selected Filter Level = or : Filter Level 1 Selected =: Filter Level 2 Selected D0 Reserve 8.7 Ideality (IDEAA, IDEAB) The Ideality factor is dependant upon the process that was used in the fabrication of the particular diode. REGISTER: IDEAA, IDEAB (DEFAULT IDEALITY: 1.003(MMBT3904)) BIT Range 86h 0.9851~0.9924 85h 0.9925~1.0000 84h 1.0001~1.0076 83h 1.0077~1.0153 82h 1.0154~1.0232 81h 1.0233~1.0312 80h 1.0313~1.0393 7Fh 1.0394~1.0476 7Eh 1.0477~1.0560 7Dh 1.0561~1.0645 7Ch 1.0646~1.0731 7Bh 1.0732~1.0819 00h-7Ah, 87h-FFh 8.8 Reserved Remote Temperature B Enable (RTBE) *for W83773G-2/SG-2 only. The remote temperature B channel of W83773G-2/W83773SG-2 is default disabled, it is used to make the design convenience for dual core CPU and single core CPU optional on a platform. Write 0Eh into CR[E8h] to enable the Remote Temperature B channel. Write 0Fh into CR[E8h] to disable the Remote Temperature B channel. - 14 - W83773G/SG 9. ELECTRICAL CHARACTERISTIC 9.1 Absolute Maximum Ratings PARAMETER RATING UNIT Power Supply Voltage V Input Voltage Operating Temperature* 3.3V  10% -0.3 to +3.6 -40 to +125 C Storage Temperature -50 to +150 C V *Guaranteed by design, 100% test at 85 degreeC. Note: Exposure to conditions beyond those listed under Absolute Maximum Ratings may adversely affect the life and reliability of the device. 9.2 DC Characteristics (Ta = 0 C to 85 C, VDD = 3.3V  10%, VSS = 0V) PARAMETER SYM. MIN. TYP. MAX. UNIT CONDITIONS I/OD12ts - TTL level bi-directional pin with source-sink capability of 12 mA and schmitt-trigger level input Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V VDD = 3.3 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V VDD = 3.3 V Hysteresis VTH 0.5 1.2 V VDD = 3.3 V Output Low Voltage VOL 0.4 V IOL = 12 mA Input High Leakage ILIH +10 A VIN = VDD Input Low Leakage ILIL -10 A VIN = 0V OD12 - Open-drain output pin with sink capability of 12 mA Output Low Voltage INts VOL 0.4 V IOL = 12 mA - TTL level Schmitt-triggered input pin Input Low Voltage Threshold Vt- 0.5 0.8 1.1 V VDD = 3.3 V Input High Voltage Threshold Vt+ 1.6 2.0 2.4 V VDD = 3.3 V Hysteresis VTH 0.5 1.2 V VDD = 3.3 V Input High Leakage ILIH +10 A VIN = VDD Input Low Leakage ILIL -10 A VIN = 0 V - 15 - Publication Release Date: October 21, 2009 Revision 1.2 W83773G/SG 9.3 AC Characteristics Timing for W83773G/SG : PARAMETER SYMBOL SCL clock period t SCL 2.5 uS Start condition hold time tHD;SDA 1.5 uS Stop condition setup-up time tSU;STO 1 uS DATA to SCL setup time tSU;DAT 120 nS DATA to SCL hold time tHD;DAT 5 nS SCL and SDA rise time tR 1.0 uS SCL and SDA fall time tF 300 nS - - 16 - MIN. MAX. UNIT W83773G/SG 10. TOP MARKING SPECIFICATIONS 10.1 W83773G and W83773SG TOP MARKING 773G GBA 915B FIRST LINE 773SG GBA 915B IC PART NUMBER: 773G (W83773G), 773SG (W83773SG) Tracking Code 1 Second Line G Assembly house code BA Mask version Tracking Code 2 Third Line 9 The package is made in 2009 15 Week: 15 B IC version 10.2 W83773G-2 and W83773SG-2 TOP MARKING 773G-2 GBA 915D FIRST+ LINE 773SG-2 GBA 915D IC PART NUMBER: 773G-2 (W83773G-2), 773SG-2 (W83773SG-2) Tracking Code 1 Second Line G Assembly house code BA Mask version Tracking Code 2 Third Line 9 The package is made in 2009 15 Week: 15 D IC version : A means version A; B means version B; D means version D - 17 - Publication Release Date: October 21, 2009 Revision 1.2 W83773G/SG 11. PACKAGE SPECIFICATION 11.1 TSSOP (MSOP) 8L 3X3 MM2 - 18 - W83773G/SG 11.2 SOP8 150mil 8 5 E 4 1 Control demensions are in milmeters . E  - 19 - Publication Release Date: October 21, 2009 Revision 1.2 W83773G/SG 12. REVISION HISTORY VERSION DATE PAGE DESCRIPTION 1.0 02/14/2008 N.A. 1.1 01/15/2009 1,11,14,17 First published version. 1. Added W83773G-2/SG-2 info. 2. Modified the typo of Ideality CR[E3~E4h] default value. 1. Modified key specifications. 1.2 10/21/2009 2. Modified AC specification. All 3. Added application notices information. 4. Fixed the typo. Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. - 20 -
W83773GTR
物料型号:W83773G/SG
器件简介: - W83773G/SG是Nuvoton公司生产的硬件监控IC,专为PC、笔记本电脑和嵌入式环境设计。 - 集成了两个远程温度传感器和一个本地温度传感器,以及2线制系统管理总线(SMBus)串行接口。 - 支持硬件监控,如温度测量,并具有高精度和低功耗特性。
引脚分配: - 芯片有8个引脚,包括SCLK(串行时钟输入)、SDA(串行数据双向I/O)、D1+/D1-和D2+/D2-(远程温度传感器输入)、VDD(电源输入)、GND(地)。
参数特性: - 工作电压为3.3V±10%。 - 本地温度范围-40°C至+125°C,远程温度范围-40°C至+127°C。 - 10位ADC分辨率,0.125°C的最小分辨率。
功能详解: - 提供两个远程温度传感器输入,可以连接到热二极管或类似2N3904的晶体管。 - 支持可编程转换率和待机模式,以支持低功耗操作。 - 包含数字滤波器以抑制噪声。 - 具有故障检测功能。
应用信息: - 适用于桌面和笔记本电脑,支持45nm及以下工艺。 - 适用于硬件管理、服务器和嵌入式应用。
封装信息: - 提供8引脚TSSOP(MSOP)和SOP封装。
W83773GTR 价格&库存
很抱歉,暂时无法提供与“W83773GTR”相匹配的价格&库存,您可以联系我们找货
