SIT8009BC-82-XXS-125.000000Y
    SITIME(赛特时脉)
    SMD7050_4P
    有源晶振 125MHz SMD7050_4P
SIT8009BC-82-XXS-125.000000Y 数据手册
SiT8009B High Frequency, Low Power Oscillator ow Power, Standard Frequency Oscillator Features ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ Applications 100% pin-to-pin drop-in replacement to quartz-based XO Excellent total frequency stability as low as ±20 ppm Operating temperature from -40°C to 85°C. For 125°C and/or -55°C options, refer to SiT8919 and SiT8921 Low power consumption of 4.9 mA typical at 1.8V Standby mode for longer battery life Fast startup time of 5 ms LVCMOS/HCMOS compatible output Industry-standard packages: 2.0 x 1.6, 2.5 x 2.0, 3.2 x 2.5, 5.0 x 3.2, 7.0 x 5.0 mm x mm Instant samples with Time Machine II and field programmable oscillators RoHS and REACH compliant, Pb-free, Halogen-free and Antimony-free For AEC-Q100 oscillators, refer to SiT8924 and SiT8925 Ideal for GPON/EPON, network switches, routers. servers, embedded systems Ideal for Ethernet, PCI-E, DDR, etc. ◼ ◼ Electrical Characteristics All Min and Max limits are specified over temperature and rated operating voltage with 15 pF output load unless otherwise stated. Typical values are at 25°C and nominal supply voltage. Table 1. Electrical Characteristics Parameters Symbol Min. Typ. Max. Unit Condition Frequency Range Output Frequency Range f 115 – 137 MHz Frequency Stability and Aging Frequency Stability F_stab -20 – +20 ppm -25 – +25 ppm – +50 ppm -50 Inclusive of Initial tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, rated power supply voltage and load. Operating Temperature Range Operating Temperature Range T_use -20 – +70 °C Extended Commercial -40 – +85 °C Industrial Supply Voltage and Current Consumption Supply Voltage Current Consumption OE Disable Current Standby Current Vdd Idd I_OD I_std Contact SiTime for 1.5 V support 1.62 1.8 1.98 V 2.25 2.5 2.75 V 2.52 2.8 3.08 V 2.7 3.0 3.3 V 2.97 3.3 3.63 V 2.25 – 3.63 V – 6.2 7.5 mA No load condition, f = 125 MHz, Vdd = 2.8 V, 3.0 V, 3.3 V or 2.25 to 3.63 V – 5.5 6.4 mA No load condition, f = 125 MHz, Vdd = 2.5 V – 4.9 5.6 mA No load condition, f = 125 MHz, Vdd = 1.8 V – – 4.2 mA Vdd = 2.5 V to 3.3 V, OE = GND, Output in high-Z state – – 4.0 mA Vdd = 1.8 V, OE = GND, Output in high-Z state – 2.6 4.3 A ST = GND, Vdd = 2.8 V to 3.3 V, Output is weakly pulled down – 1.4 2.5 A ST = GND, Vdd = 2.5 V, Output is weakly pulled down – 0.6 1.3 A ST = GND, Vdd = 1.8 V, Output is weakly pulled down LVCMOS Output Characteristics Duty Cycle Rise/Fall Time DC 45 – 55 % Tr, Tf – 1 2 ns Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V, 20% - 80% – 1.3 2.5 ns Vdd =1.8 V, 20% - 80% All Vdds – 0.8 2 ns Vdd = 2.25 V - 3.63 V, 20% - 80% Output High Voltage VOH 90% – – Vdd IOH = -4 mA (Vdd = 3.0 V or 3.3 V) Output Low Voltage VOL – – 10% Vdd IOL = 4 mA (Vdd = 3.0 V or 3.3 V) Rev 1.06 15 March 2021 www.sitime.com SiT8009B High Frequency, Low Power Oscillator Table 1. Electrical Characteristics (continued) Parameters Symbol Min. Typ. Max. Unit Condition Input Characteristics Input High Voltage VIH 70% – – Vdd Pin 1, OE or ST Input Low Voltage VIL – – 30% Vdd Pin 1, OE or ST Input Pull-up Impedance Z_in 50 87 150 k Pin 1, OE logic high or logic low, or ST logic high 2 – – Pin 1, ST logic low M Startup and Resume Timing T_start – – 5 ms Measured from the time Vdd reaches its rated minimum value T_oe – – 122 ns f = 137 MHz. For other frequencies, T_oe = 100 ns + 3 * cycles T_resume – – 5 ms Measured from the time ST pin crosses 50% threshold Startup Time Enable/Disable Time Resume Time Jitter RMS Period Jitter T_jitt Peak-to-peak Period Jitter T_pk RMS Phase Jitter (random) T_phj – 1.9 3 ps f = 125 MHz, Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V – 1.8 4 ps f = 125 MHz, Vdd = 1.8 V – 12 25 ps f = 125 MHz, Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V – 14 30 ps f = 125 MHz, Vdd = 1.8 V – 0.5 0.9 ps Integration bandwidth = 900 kHz to 7.5 MHz – 1.3 2 ps Integration bandwidth = 12 kHz to 20 MHz Table 2. Pin Description Pin Symbol Functionality Output Enable 1 OE/ST ̅ ̅ ̅ /NC Standby No Connect Top View H[1]: specified frequency output L: output is high impedance. Only output driver is disabled. H[1]: specified frequency output L: output is low (weak pull down). Device goes to sleep mode. Supply current reduces to I_std. Any voltage between 0 and Vdd or Open[1]: Specified frequency output. Pin 1 has no function. 2 GND Power Electrical ground 3 OUT Output Oscillator output 4 VDD Power Power supply voltage[2] OE/ST ̅ ̅ ̅ /NC 1 4 VDD GND 2 3 OUT Figure 1. Pin Assignments Notes: 1. In OE or ST ̅ ̅ ̅ mode, a pull-up resistor of 10 kΩ or less is recommended if pin 1 is not externally driven. If pin 1 needs to be left floating, use the NC option. 2. A capacitor of value 0.1 µF or higher between Vdd and GND is required. Rev 1.06 Page 2 of 18 www.sitime.com SiT8009B High Frequency, Low Power Oscillator Table 3. Absolute Maximum Limits Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. Min. Max. Unit Storage Temperature Parameter -65 150 °C Vdd -0.5 4 V Electrostatic Discharge – 2000 V Soldering Temperature (follow standard Pb free soldering guidelines) – 260 °C Junction Temperature[3] – 150 °C Note: 3. Exceeding this temperature for extended period of time may damage the device. Table 4. Thermal Consideration[4] Package JA, 4 Layer Board JA, 2 Layer Board JC, Bottom 7050 142 273 30 5032 97 199 24 3225 109 212 27 2520 117 222 26 2016 152 252 36 (°C/W) (°C/W) (°C/W) Note: 4. Refer to JESD51 for JA and JC definitions, and reference layout used to determine the JA and JC values in the above table. Table 5. Maximum Operating Junction Temperature[5] Max Operating Temperature (ambient) Maximum Operating Junction Temperature 70°C 80°C 85°C 95°C Note: 5. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature. Table 6. Environmental Compliance Parameter Condition/Test Method Mechanical Shock MIL-STD-883F, Method 2002 Mechanical Vibration MIL-STD-883F, Method 2007 Temperature Cycle JESD22, Method A104 Solderability MIL-STD-883F, Method 2003 Moisture Sensitivity Level MSL1 @ 260°C Rev 1.06 Page 3 of 18 www.sitime.com SiT8009B High Frequency, Low Power Oscillator Test Circuit and Waveform[6] Vdd Vout Test Point tr Power Supply 4 3 1 2 80% Vdd 15pF (including probe and fixture capacitance) 0.1 uF tf 50% 20% Vdd High Pulse (TH) Low Pulse (TL) Vdd Period 1 kΩ OE/ST Function Figure 2. Test Circuit Figure 3. Waveform Note: 6. Duty Cycle is computed as Duty Cycle = TH/Period. Timing Diagrams 90% Vdd Vdd Vdd 50% Vdd Pin 4 Voltage T_start [7] T_resume ST Voltage No Glitch during start up CLK Output CLK Output HZ HZ T_resume: Time to resume from ST T_start: Time to start from power-off Figure 5. Standby Resume Timing ( ST ̅ ̅ ̅ Mode Only) Figure 4. Startup Timing (OE/ ST ̅ ̅ ̅ Mode) Vdd Vdd 50% Vdd OE Voltage OE Voltage T_oe 50% Vdd T_oe CLK Output CLK Output HZ HZ T_oe: Time to re-enable the clock output T_oe: Time to put the output in High Z mode Figure 6. OE Enable Timing (OE Mode Only) Figure 7. OE Disable Timing (OE Mode Only) Note: 7. SiT8009 has “no runt” pulses and “no glitch” output during startup or resume. Rev 1.06 Page 4 of 18 www.sitime.com SiT8009B High Frequency, Low Power Oscillator Performance Plots[8] 1.8 V 2.5 V 2.8 V 3.0 V 3.3 V 7.5 DUT1 DUT2 DUT3 DUT4 DUT5 DUT6 DUT7 DUT8 DUT9 DUT10 20 7.0 15 Frequency (ppm) Idd (mA) 6.5 6.0 5.5 5.0 4.5 10 5 0 -5 -10 -15 4.0 115 -20 117 119 121 123 125 127 129 131 133 135 -40 137 -30 -20 -10 0 Figure 8. Idd vs Frequency 1.8 V 2.5 V 2.8 V 3.0 V 1.8 V 3.3 V 40 50 60 70 80 2.5 V 2.8 V 3.0 V 3.3 V 54 53 3.0 Duty cycle (%) RMS period jitter (ps) 30 55 3.5 2.5 2.0 1.5 52 51 50 49 48 1.0 47 0.5 46 45 0.0 115 117 119 121 123 125 127 129 131 133 115 135 137 117 119 121 123 Figure 10. RMS Period Jitter vs Frequency 1.8 V 2.5 V 2.8 V 125 127 129 131 133 135 137 Frequency (MHz) Frequency (MHz) 3.0 V Figure 11. Duty Cycle vs Frequency 3.3 V 1.8 V 2.5 2.5 2.0 2.0 Fall time (ns) Rise time (ns) 20 Figure 9. Frequency vs Temperature, 1.8 V 4.0 1.5 1.0 0.5 2.5 V 2.8 V 3.0 V 3.3 V 1.5 1.0 0.5 0.0 0.0 -40 -30 -20 -10 0 10 20 30 40 50 60 70 -40 80 -30 -20 -10 0 10 20 30 40 50 60 70 80 Temperature (°C) Temperature (°C) Figure 12. 20%-80% Rise Time vs Temperature Rev 1.06 10 Temperature (°C) Frequency (MHz) Figure 13. 20%-80% Fall Time vs Temperature Page 5 of 18 www.sitime.com SiT8009B High Frequency, Low Power Oscillator Performance Plots[8] 2.5 V 2.8 V 3.0 V 3.3 V 1.8 V 0.9 1.8 0.8 IPJ (ps) IPJ (ps) 1.8 V 2.0 1.6 0.6 1.2 0.5 115 117 119 121 123 125 127 129 131 133 135 0.4 115 137 Frequency (MHz) 2.8 V 3.0 V 3.3 V 0.7 1.4 1.0 2.5 V 117 119 121 123 125 127 129 131 133 135 137 Frequency (MHz) Figure 14. RMS Integrated Phase Jitter Random (12 kHz to 20 MHz) vs Frequency[9] Figure 15. RMS Integrated Phase Jitter Random (900 kHz to 20 MHz) vs Frequency[9] Notes: 8. All plots are measured with 15 pF load at room temperature, unless otherwise stated. 9. Phase noise plots are measured with Agilent E5052B signal source analyzer. Integration range is up to 5 MHz for carrier frequencies below 40 MHz. Rev 1.06 Page 6 of 18 www.sitime.com SiT8009B High Frequency, Low Power Oscillator Programmable Drive Strength The SiT8009 includes a programmable drive strength feature to provide a simple, flexible tool to optimize the clock rise/fall time for specific applications. Benefits from the programmable drive strength feature are: ◼ Improves system radiated electromagnetic interference (EMI) by slowing down the clock rise/fall time ◼ Improves the downstream clock receiver’s (RX) jitter by decreasing (speeding up) the clock rise/fall time. ◼ Ability to drive large capacitive loads while maintaining full swing with sharp edge rates. The SiT8009 can support up to 30 pF or higher in maximum capacitive loads with up to 3 additional drive strength settings. Refer to the Rise/Fall Time Tables (Table 7 to 11) to determine the proper drive strength for the desired combination of output load vs. rise/fall time. SiT8009 Drive Strength Selection Tables 7 through 11 define the rise/fall time for a given capacitive load and supply voltage. 1. 2. For more detailed information about rise/fall time control and drive strength selection, see the SiTime Application Notes section. 3. 4. EMI Reduction by Slowing Rise/Fall Time Figure 16 shows the harmonic power reduction as the rise/fall times are increased (slowed down). The rise/fall times are expressed as a ratio of the clock period. For the ratio of 0.05, the signal is very close to a square wave. For the ratio of 0.45, the rise/fall times are very close to neartriangular waveform. These results, for example, show that the 11th clock harmonic can be reduced by 35 dB if the rise/fall edge is increased from 5% of the period to 45% of the period. trise=0.05 trise=0.1 trise=0.15 trise=0.2 trise=0.25 trise=0.3 trise=0.35 trise=0.4 trise=0.45 10 Harmonic amplitude (dB) 0 -10 -20 5. Select the table that matches the SiT8009 nominal supply voltage (1.8 V, 2.5 V, 2.8 V, 3.0 V, 3.3 V). Select the capacitive load column that matches the application requirement (5 pF to 30 pF) Under the capacitive load column, select the desired rise/fall times. The left-most column represents the part number code for the corresponding drive strength. Add the drive strength code to the part number for ordering purposes. Calculating Maximum Frequency Based on the rise and fall time data given in Table 7 through 11, the maximum frequency the oscillator can operate with guaranteed full swing of the output voltage over temperature as follows: Max Frequency = 1 5 x Trf_20/80 where Trf_20/80 is the typical value for 20%-80% rise/fall time. -30 Example 1 -40 Calculate fMAX for the following condition: -50 -60 ◼ Vdd = 3.3 V (Table 11) ◼ Capacitive Load: 30 pF ◼ Desired Tr/f time = 1.46 ns (rise/fall time part number code = U) -70 -80 1 3 5 7 9 11 Harmonic number Figure 16. Harmonic EMI reduction as a Function of Slower Rise/Fall Time Part number for the above example: Jitter Reduction with Faster Rise/Fall Time SiT8009BIU12-33E-136.986300 Power supply noise can be a source of jitter for the downstream chipset. One way to reduce this jitter is to speed up the rise/fall time of the input clock. Some chipsets may also require faster rise/fall time in order to reduce their sensitivity to this type of jitter. Refer to the Rise/Fall Time Tables (Table 7 to Table 11) to determine the proper drive strength. Drive strength code is inserted here. Default setting is “-” High Output Load Capability The rise/fall time of the input clock varies as a function of the actual capacitive load the clock drives. At any given drive strength, the rise/fall time becomes slower as the output load increases. As an example, for a 3.3 V SiT8009 device with default drive strength setting, the typical rise/fall time is 0.46 ns for 5 pF output load. The typical rise/fall time slows down to 1 ns when the output load increases to 15 pF. One can choose to speed up the rise/fall time to 0.72 ns by then increasing the driven strength setting on the SiT8009 to “F”. Rev 1.06 Page 7 of 18 www.sitime.com SiT8009B High Frequency, Low Power Oscillator Rise/Fall Time (20% to 80%) vs CLOAD Tables Table 7. Vdd = 1.8 V Rise/Fall Times for Specific CLOAD Table 8. Vdd = 2.5 V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Rise/Fall Time Typ (ns) Drive Strength \ CLOAD T E U F or "-": default 5 pF 0.93 0.78 0.70 0.65 15 pF n/ n/a 1.4a 8 1.3 0 30 pF n/a n/a n/a n/a Table 9. Vdd = 2.8 V Rise/Fall Times for Specific CLOAD R B T E U or "-": default F 5 pF 1.29 0.97 0.55 0.44 0.34 0.29 15 pF n/a n/a 1.12 1.00 0.88 0.81 5 pF 15 pF 30 pF R B T E U or "-": default F 1.45 1.09 0.62 0.54 0.43 0.34 n/a n/a 1.28 1.00 0.96 0.88 n/a n/a n/a n/a n/a n/a Table 10. Vdd = 3.0 V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Rise/Fall Time Typ (ns) Drive Strength \ CLOAD Drive Strength \ CLOAD Drive Strength \ CLOAD 30 pF n/a n/a n/a n/a n/a 1.48 R B T or "-": default E U F 5 pF 1.22 0.89 0.51 0.38 0.30 0.27 15 pF n/a n/a 1.00 0.92 0.83 0.76 30 pF n/a n/a n/a n/a n/a 1.39 Table 11. Vdd = 3.3 V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Drive Strength \ CLOAD R B T or "-": default E U 5 pF 1.16 0.81 0.46 0.33 0.28 15 pF n/a n/a 1.00 0.87 0.79 30 pF n/a n/a n/a n/a 1.46 F 0.25 0.72 1.31 Note: 10. “n/a” in Table 7 to Table 11indicates that the resulting rise/fall time from the respective combination of the drive strength and output load does not provide rail-to-rail swing and is not available. Rev 1.06 Page 8 of 18 www.sitime.com SiT8009B High Frequency, Low Power Oscillator Pin 1 Configuration Options (OE, ST ̅ ̅ ̅ , or NC) Pin 1 of the SiT8009 can be factory-programmed to support three modes: Output Enable (OE), standby (ST ̅ ̅ ̅ ) or No Connect (NC). These modes can also be programmed with the Time Machine using field programmable devices. Output Enable (OE) Mode In the OE mode, applying logic Low to the OE pin only disables the output driver and puts it in Hi-Z mode. The core of the device continues to operate normally. Power consumption is reduced due to the inactivity of the output. When the OE pin is pulled High, the output is typically enabled in
物料型号:SiT8009B
器件简介: - 该振荡器是针对网络设备如GPON/EPON、网络交换机、路由器、服务器和嵌入式系统设计的。 - 它提供了对以太网、PCI-E、DDR等应用的卓越总频率稳定性,低至±20ppm。 - 工作温度范围从-40°C到85°C,还有125°C和/或-55°C的选项。
引脚分配: - 1号引脚:OE/ST/NC,用于输出使能、待机模式或无连接。 - 2号引脚:GND,电源地。 - 3号引脚:OUT,振荡器输出。 - 4号引脚:VDD,电源供电电压。
参数特性: - 供电电压范围:1.62V至3.63V。 - 典型工作电流:在1.8V供电时为4.9mA。 - 待机模式电流:在2.8V供电时为2.6μA。 - 快速启动时间:5毫秒。 - LVCMOS/HCMOS兼容输出。 - 频率范围:115MHz至137MHz。
功能详解: - 该振荡器提供了可编程的驱动强度特性,以优化特定应用中的时钟上升/下降时间。 - 它还包括了一种减少电磁干扰(EMI)的特性,通过减慢时钟上升/下降时间来实现。
应用信息: - 适用于需要高精度时钟的应用,如网络通信设备和嵌入式系统。
封装信息: - 提供多种行业标准封装尺寸,包括2.0 x 1.6mm、2.5 x 2.0mm、3.2 x 2.5mm、5.0 x 3.2mm和7.0 x 5.0mm。
SIT8009BC-82-XXS-125.000000Y 价格&库存
很抱歉,暂时无法提供与“SIT8009BC-82-XXS-125.000000Y”相匹配的价格&库存,您可以联系我们找货
    • 10+9.60500
    • 35+8.58800
    • 100+7.70000
    库存:3000
