REVISIONS
[.46
of ogies
y
t
r
ol
e
n
p
h
Pro Tec
ata
s
n
Se
29309
4X
B66R0340
±.08]
.018
±.003
SPECIFICATIONS:
1. DEVICE: SINGLE POLE, SINGLE THROW DUAL INLINE PACKAGE SNAP
ACTION
THERMOSTAT.
2. CONTACT RATING:
CYCLES
30000
VDC
48
100000
EPOXY
AMPS (RESISTIVE)
1
5
MAX
20mA
MIN
3. TEMPERATURE EXPOSURE LIMIT: 160°C (320°F)
SHORT TERM EXPOSURE LIMIT:260°C (500°F)
4. UNIT SEALED TO WITHSTAND VAPOR PHASE, WAVE AND DIP SOLDER OPERATIONS.
SEAL
5.
TERMINALS:
CUPRO-NICKEL.
BASE:
PPS
6. OPERATING TEMP REQUIREMENTS:
(CONTACTS TO OPEN ON RISING TEMP)
STAMP:
AIRPAX
66L060
55
60
65
40
61
4
MIN
NOM
MAX
MIN
NOM
MAX
MIN
HIGH
TEMP
°C
LOW
SIMULTANEOUS
WITH
2X
.050
[3.30]
.130
+.25
-.13
[5.72
.225
[10.16]
.0100
.400
SNAP
OF
DISC.
±.010
[6.35]
.250
[1.02]
.040
±.08]
[.46]
4X (R.018)
±.003
+.010
-.005
[.254
°C
±.25]
.300
[.25]
4X (R.010)
[1.27]
.300
DIFFERENTIAL
8. CO-PLANNER REQUIREMENT: TERMINALS TO BE FLAT WITHIN [.10]/.004.
[7.62
[7.63]
°C
25
MAX
7. CREEP: ALL CONTACT OPERATION (BOTH CLOSING & OPENING) MUST OCCUR
(DATE CODE)
2X
TEMP
NOM
[1.27
±.013]
[.25
±.0005
4X
4X
±.08]
.010
±.08]
.050
±.003
FLAT
±.003
[11.43]
.450
CUSTOMER
REF:GENERAL DYNAMICS
T
PIN #1 REF
Thermal Sensing Products
FSCM
GENERAL
SCHEMATIC
AT 30°C
DRAWN
CHECKED
(OPEN ON RISE)
A
66L060-0340
Frederick, Maryland
82415
WORKMANSHIP
CONSTITUTES
OUTLINE
PART
SPECIFICATION
OF
THIS
JMS
APPROVED
JJS
DATE
6600
S-604
DRAWING.
MR
1-22-01
THIRD ANGLE
PROJECTION
MATERIAL
NOTED
[MM]
INCH
INTERPRET DRAWING
FINISH
PER ANSI Y14.5M-1982
NONE
TOLERANCE
UNLESS NOTED
MM ± .13
INCH ± .005
ANGLES ± 1 °
SCALE
8-1
B66R0340
REVISION
GEN1068
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
T
REV.
B
很抱歉,暂时无法提供与“66L060-0340”相匹配的价格&库存,您可以联系我们找货
