393
    ADAFRUIT
    LAMP INCAND T1-3/4 MIDGE GROOVE
393 数据手册
Your specialist in innovating humidity & temperature sensors /DHT22 Standard AM2302 AM2302/DHT22 /DHT22 with big case and wires AM2302 AM2302/DHT22 /DHT22 Digital relative humidity & temperature sensor AM2302 AM2302/DHT22 1. Feature & Application Application:: *High precision *Capacitive type *Full range temperature compensated *Relative humidity and temperature measurement *Calibrated digital signal *Outstanding long-term stability *Extra components not needed *Long transmission distance, up to 100 meters *Low power consumption *4 pins packaged and fully interchangeable 2. Description: AM2302 output calibrated digital signal. It applys exclusive digital-signal-collecting-technique and humidity sensing technology, assuring its reliability and stability. Its sensing elements is connected with 8-bit single-chip computer. Every sensor of this model is temperature compensated and calibrated in accurate calibration chamber and the calibration-coefficient is saved in type of programme in OTP memory, when the sensor is detecting, it will cite coefficient from memory. Small size & low consumption & long transmission distance(100m) enable AM2302 to be suited in all kinds of harsh application occasions. Single-row packaged with four pins, making the connection very convenient. 3. Technical Specification: Model Power supply Output signal Sensing element Operating range Accuracy AM2302 3.3-5.5V DC digital signal via 1-wire bus Polymer humidity capacitor humidity 0-100%RH; humidity +-2%RH +-2%RH(Max +-5%RH); Resolution or sensitivity Repeatability Humidity hysteresis Long-term Stability Interchangeability humidity 0.1%RH; humidity +-1%RH; +-0.3%RH +-0.5%RH/year fully interchangeable Thomas Liu (Sales Manager) Email: thomasliu198518@aliyun.com -1- temperature -40~80Celsius temperature +-0.5Celsius temperature 0.1Celsius temperature +-0.2Celsius Your specialist in innovating humidity & temperature sensors 4. Dimensions: (unit----mm) Standard AM2302 AM2302’’s dimensions as above Big case case’’s dimensions as above Red wire--power supply, Black wire--GND Yellow wire--Data output 5. Electrical connection diagram: 6. Operating specifications: (1) Power and Pins Power's voltage should be 3.3-5.5V DC. When power is supplied to sensor, don't send any instruction to the sensor within one second to pass unstable status. One capacitor valued 100nF can be added between VDD and GND for wave filtering. (2) Communication and signal 1-wire bus is used for communication between MCU and AM2302. ( Our 1-wire bus is specially designed, it's different from Maxim/Dallas 1-wire bus, so it's incompatible with Dallas 1-wire bus.) Illustration of our 1-wire bus: Thomas Liu (Sales Manager) Email: thomasliu198518@aliyun.com -2- Your specialist in innovating humidity & temperature sensors 16 bits RH data+ 16 bits Temperature data+8 bit DATA= DATA=16 data+16 bitss check-sum Example: MCU has received 40 bits data from AM2302 as 0000 0010 1000 1100 0000 0001 0101 1111 1110 1110 16 bits RH data 16 bits T data check sum Here we convert 16 bits RH data from binary system to decimal system, 0000 0010 1000 1100 → 652 Binary system Decimal system RH=652/10=65.2%RH Here we convert 16 bits T data from binary system to decimal system, 0000 0001 0101 1111 → 351 Binary system Decimal system T=351/10=35.1 T=351/10=35.1℃ When highest bit of temperature is 1, it means the temperature is below 0 degree Celsius. Example: 1000 0000 0110 0101, T= minus 10.1℃ 16 bits T data Sum=0000 0010+1000 1100+0000 0001+0101 1111=1110 1110 Check-sum Check-sum=the last 8 bits of Sum=1110 1110 When MCU send start signal, AM2302 change from standby-status to running-status. When MCU finishs sending the start signal, AM2302 will send response signal of 40-bit data that reflect the relative humidity and temperature to MCU. Without start signal from MCU, AM2302 will not give response signal to MCU. One start signal for one response data from AM2302 that reflect the relative humidity and temperature. AM2302 will change to standby status when data collecting finished if it don't receive start signal from MCU again. See below figure for overall communication process, the interval of whole process must beyond 2 seconds. -----------------------------------------------------------------------------------------------------------------------------------1) Step 1: MCU send out start signal to AM2302 and AM2302 send response signal to MCU Thomas Liu (Sales Manager) Email: thomasliu198518@aliyun.com -3- Your specialist in innovating humidity & temperature sensors Data-bus's free status is high voltage level. When communication between MCU and AM2302 begins, MCU will pull low data-bus and this process must beyond at least 1~10ms to ensure AM2302 could detect MCU's signal, then MCU will pulls up and wait 20-40us for AM2302's response. When AM2302 detect the start signal, AM2302 will pull low the bus 80us as response signal, then AM2302 pulls up 80us for preparation to send data. See below figure: -----------------------------------------------------------------------------------------------------------------------------------2). Step 2: AM2302 send data to MCU When AM2302 is sending data to MCU, every bit's transmission begin with low-voltage-level that last 50us, the following high-voltage-level signal's length decide the bit is "1" or "0". See below figures: Attention: If signal from AM2302 is always high-voltage-level, it means AM2302 is not working properly, please check the electrical connection status. Thomas Liu (Sales Manager) Email: thomasliu198518@aliyun.com -4- Your specialist in innovating humidity & temperature sensors 7. Electrical Characteristics: Items Power supply Current supply Collecting period Condition DC Measuring Stand-by Second Min 3.3 1 40 Typical 5 Null 2 Max 6 1.5 50 Unit V mA uA Second 8. Attentions of application: (1) Operating and storage conditions We don't recommend the applying RH-range beyond the range stated in this specification. The AM2302 sensor can recover after working in abnormal operating condition to calibrated status, but will accelerate sensors' aging. (2) Attentions to chemical materials Vapor from chemical materials may interfere AM2302's sensitive-elements and debase AM2302's sensitivity. (3) Disposal when (1) & (2) happens Step one: Keep the AM2302 sensor at condition of Temperature 50~60Celsius, humidity 70%RH for 5 hours. (4) Attention to temperature's affection Relative humidity strongly depend on temperature, that is why we use temperature compensation technology to ensure accurate measurement of RH. But it's still be much better to keep the sensor at same temperature when sensing. AM2302 should be mounted at the place as far as possible from parts that may cause change to temperature. (5) Attentions to light Long time exposure to strong light and ultraviolet may debase AM2302's performance. (6) Attentions to connection wires The connection wires' quality will effect communication's quality and distance, high quality shielding-wire is recommended. (7) Other attentions * Welding temperature should be bellow 260Celsius. * Avoid using the sensor under dew condition. * Don't use this product in safety or emergency stop devices or any other occasion that failure of AM2302 may cause personal injury. Thomas Liu (Sales Manager) Email: thomasliu198518@aliyun.com -5-
很抱歉,暂时无法提供与“393”相匹配的价格&库存,您可以联系我们找货
