S22P015S05
S22P015S05
    TAMURA
    Module
    S22P015S05
S22P015S05 数据手册
Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors S22P Series Features: Advantages:              Closed Loop type Voltage output Unipolar power supply Configurable integrated primary Printed circuit board mounting UL recognised - plastic case material UL94V0  UL Recognition Specifications Parameters Primary nominal current Saturation current TA=25ºC, VCC=+5V, RL=10kΩ Symbol S22P006S05 S22P015S05 S22P025S05 If 6A 15A 25A Ifmax ≥ ± 18A ≥ ± 45A ≥ ± 75A Vo Rated output voltage Excellent accuracy and linearity Low temperature drift Wide frequency bandwidth No insertion loss High Immunity to external interferences Optimised response time Current overload capability Vof ±0.625V (at If) 1 Offset voltage (at If=0A) Vof Output voltage accuracy(at If) X 0.625V±0.010V(at If) Output linearity2(0A~If) εL ≤±0.2% (at If) Power supply voltage VCC +5V±5% 3 ICC Typ. 12.5mA (at If=0A) + 37.5mA / 22.5mA / 9mA (at If = 75A / 45A / 18A) tr ≤ 1.0μs (at di/dt = 100A/ μs) Thermal drift of gain5 TcVo ≤ ±0.05mV/ºC Thermal drift of offset TcVof Consumption current Response time 4 2.5V±0.050V 2.5V±0.020V -10ºC~25ºC : ≤±1.6mV/ºC 25ºC~85ºC : ≤±0.8mV/ºC 2.5V±0.015V -10ºC~25ºC : ≤±0.6mV/ºC -10ºC~25ºC : ≤±0.4mV/ºC 25ºC~85ºC : ≤±0.3mV/ºC 25ºC~85ºC : ≤±0.2mV/ºC Hysteresis error VOH ≤0.5mV (at If=0A→If→0A) Insulation voltage Vd AC 3kV for 1minute (Sensing current 0.5mA) Primary  Secondary Insulation resistance RIS ≥ 500MΩ (at DC500V), primary  secondary Ambient operation temperature TA -10ºC~+85ºC Ambient storage temperature TS 1 2 -25ºC~+100ºC 3 4 After removal of core hysteresis— Without offset — Conversion ratio1:2000— Time between 90% input current full scale and 90% of sensor output full 5 Without Thermal drift of offset scale — Electrical Performances Saturation characteristic(S22P025S05) 5.0 4 4.5 2 4.0 0 3.5 Output voltage (V) Attenuation (dB) Frequency characteristic(S22P025S05) 6 -2 -4 -6 -8 3.0 2.5 2.0 1.5 TA=25ºC Pulsed 1.0 -10 0.1 1 10 Frequency characteristic(kHz) @ If=1(Arms) 100 0.5 0.0 -100 -80 -60 -40 -20 0 20 Input current (A) Tamura reserve the right to modify its products in order to improve them without prior notice S22PXXXS05revD, April 2012 40 60 80 100 Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors S22P Series 23.5 0.5 5.5 3.5 Lot No 24 Mechanical dimensions ⑨ ⑧ ⑦ ③ ② ① ⑥ ⑤ ④ 0.8 22.2 0.7 5.08 2.54 2.54 3-(0.5×0.25) 10 12.7 5.08 7.6 1.9 Terminal number: 1. IN-1 (Primary input current (+)) 2. IN-2 (Primary input current (+)) 3. IN-3 (Primary input current (+)) 4. OUT-3(Primary input current (-)) 5. OUT-2(Primary input current (-)) 6. OUT-1(Primary input current (-)) 7. VOUT 8. GND 9. +VCC(+5V) Vcc GND Vout 7.66 NOTES 1. Unit is mm 2. Tolerance is 0.5mm IN 1 2 3 6 5 4 OUT Electrical connection diagram Connection diagram -If 7 +If 3 2 1 4 5 6 8 6 +If / 3 +VCC RL VOUT RL = 10kΩ +If GND IN 1 2 3 6 5 4 OUT IN 1 2 3 6 5 4 OUT IN 1 UL Standard UL 508 , CSA C22.2 No.14 (UL FILE No.E243511) • For use in Pollution Degree 2 Environment. • Maximum Surrounding air temperature rating, 85˚C. Package & Weight Information Weight Pcs/box Pcs/carton Pcs/pallet 8g 100 400 12000 Tamura reserve the right to modify its products in order to improve them without prior notice S22PXXXS05revD, April 2012 4 OUT 9 +If / 2 5 2 3
S22P015S05 价格&库存
很抱歉,暂时无法提供与“S22P015S05”相匹配的价格&库存,您可以联系我们找货
