L34S400D15
L34S400D15
    TAMURA
    Module
    SENSOR CURRENT HALL 400A AC/DC
L34S400D15 数据手册
Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L34S***D15 Series Features: Advantage:             Open Loop type Panel mounting Bipolar power supply Large aperture Insulated plastic case according to UL94V0  UL Recognition Excellent accuracy and linearity Wide nominal current range Low temperature drift No insertion loss High Immunity To External Interference Optimised response time Current overload capability Specifications Parameters TA=25ºC, VCC=±15V, RL=10kΩ Symbol L34S200D15 L34S300D15 L34S400D15 L34S500D15 L34S600D15 L34S800D15 L34S1T0D15 L34S1T2D15 L34S1T5D15 Primary nominal current Saturation current If 200A 300A Ifmax ≥ ±600A ≥ ±900A 400A 500A 600A 800A 1000A 1200A ≥ ±1200A ≥ ±1500A ≥ ±1800A ≥ ±2400A ≥ ±2500A ≥ ±2500A ≥ ±2500A Rated output voltage Vo 4V ± 0.040V (at If) Offset voltage1 Vof ≤ ± 0.020V (at If=0A) εL ≤ ± 0.5% (at If) Power supply voltage VCC ± 15V ±5 % Consumption current Icc ≤ 25mA tr ≤ 5μs (at di/dt = 100A / μs) Thermal drift of gain4 TcVo ≤ ± 0.05% / ºC Thermal drift of offset TcVof ≤ ± 1.0 mV/ºC VOH ≤ 10mV (at If=0A→If→0A) Insulation voltage Vd AC3000V for 1minute (sensing current 0.5mA), inside of aperture  terminal Insulation resistance RIS ≥ 500MΩ (at DC500V), inside of aperture  terminal TA -30ºC~+80ºC Output linearity ( 0A, 0.5If , If) 2 Response time3 Hysteresis error Ambient operation temperature Ambient storage temperature -40ºC~+85ºC TS 1 After removal of core hysteresis— drift of offset 1500A 2 3 Without offset — Time between 10% input current full scale and 90% of sensor output full scale — 4 Without Thermal Electrical Performances Frequency characteristic(L34S1T0D15) 6 15 10 2 Output voltage (V) Attenuation (dB) 4 Saturation characteristic(L34S1T0D15) 0 -2 -4 -6 -8 5 0 -5 -10 TA=25ºC Pulsed -10 0.1 1 10 Frequency characteristic(kHz) @ If=60AT(Arms) L34SXXXD15revB, March 2012 100 -15 -4000 -3000 -2000 -1000 0 1000 Input current (A) Tamura reserve the right to modify its products in order to improve them without prior notice 2000 3000 4000 Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L34S***D15 Series Mechanical dimensions 16 Φ4.5 (HOLE) 4 Φ4.5 (HOLE) Lot No. 5.5×4.5 (SLOT HOLE) 11 NOTES 1. Unit is mm 2. Tolerance is 0.5mm 38.75 Current direction 78 (8.8) Terminal No. Connector 20.5 1 2 3 4 17 33.25 53.5 LE) 40.5 (HO Connector 65.5 3 .5 Φ 4 2 - 64.5 40.5 1.5 1 5 78 89.5 5 Manufacturer Part Number Old Part Number Molex 22-04-1041 5045-04A Terminal Number: 1: +VCC(+15V) 2: - VCC(-15V) 3: VOUT 4: GND 3 19 10 Electrical connection diagram +VCC -VCC 1 2 3 4 -If +If RL = 10kΩ VOUT GND UL Standard UL 508 , CSA C22.2 No.14 (UL FILE No.E243511) • For use in Pollution Degree 2 Environment. • Maximum Surrounding air temperature rating, 80˚C. CAUTION Do not wrap the primary conductor around the core part of the product for preventing to reduce the required Spacings. Package & Weight Information L34SXXXD15revB, March 2012 Weight Pcs/box Pcs/carton Pcs/pallet 165g 10 50 - Tamura reserve the right to modify its products in order to improve them without prior notice
L34S400D15 价格&库存
很抱歉,暂时无法提供与“L34S400D15”相匹配的价格&库存,您可以联系我们找货
