Issued by Module Components Div, TAMURA CORPORATION
Hall Effect Current Sensors L01Z***S05 Series
Features:
Advantage:
Open Loop type
Printed circuit board mounting
Unipolar power supply
Aperture for cable or bus bar
Insulated plastic case according to
UL94V0
Excellent accuracy
Very good linearity
Low temperature drift
Wide frequency bandwidth
No insertion loss
High Immunity To External Interference
Optimised response time
Current overload capability
Specifications
Parameters
TA=25ºC, VCC=+5V, RL=10kΩ
Symbol L01Z050S05 L01Z100S05 L01Z150S05 L01Z200S05 L01Z300S05 L01Z400S05 L01Z500S05 L01Z600S05
Primary nominal current
If
50AT
100AT
150AT
200AT
400AT
Vof+1.5V
±0.045V
VREF1
±0.035V
Rated output voltage (at If)
Vo
Offset voltage1(at If=0A)
Vof
Saturation output voltage
Vo min/max
Vo min ≤ 0.5V, 4.5V ≤ Vo max
Output linearity2(0A~If)
εL
≤ ±1% (at If)
Power supply voltage
VCC
5V ±2%
Consumption current
Icc
≤ 15mA
tr
≤ 10μs (at di/dt = 100A / μs)
Response time3
500AT
600AT
≥ ± If × 1.25
Ifmax
Saturation current
300AT
Vof+1.5V ± 0.035V
VREF1 ± 0.030V
Thermal drift of gain4
TcVo ≤ ± 2mV/ºC
≤ ± 1.5mV/ºC
Thermal drift of offset
TcVof ≤ ± 2mV/ºC
≤ ± 1.0mV/ºC
Hysteresis error
(at If=0A→If→0A)
VOH
Insulation voltage
Vd
AC2500V for 1minute (sensing current 0.5mA), inside of through hole terminal
Insulation resistance
RIS
≥ 500MΩ (at DC500V), inside of through hole terminal
TA
-10ºC~+80ºC
TS
-15ºC~+85ºC
Ambient operation temperature
Ambient storage temperature
≤ 8mV
≤ 4mV
≤ 6mV
1
VREF = VCC./ 2 (ratiometric). After removal of core hysteresis— 2 Without offset — 3 Time between 90% input current full scale and 90% of sensor output full scale —
4
Without Thermal drift of offset
Electrical Performances
Frequency characteristic(L01Z600S05)
5.0
4
4.5
2
4.0
Output voltage (V)
Attenuation (dB)
6
-4
-6
3.5
3.0
2.5
2.0
1.5
-8
1.0
-10
0.5
0.1
L01ZXXXS05revD, March 2012
1
10
Frequency characteristic(kHz)
@ If=27AT(Arms)
100
Saturation characteristic(L01Z600S05)
TA=25ºC Pulsed
0.0
-1000 -800 -600 -400 -200
400
600
800
Input current (A)
Tamura reserve the right to modify its products in order to improve them without prior notice
1000
Mechanical dimensions
Lot No.
S05
L01Z
2.5
2.5
12
5.2
12.8
38 MAX
18.5 MAX
9
3
15
7.5
14.5
14.5
0.5
8
Terminal Number:
1. VOUT
2. GND
3. +Vcc(+5V)
4
4
9.5
27 MAX
2 - Ø1
NOTES
1. Unit is mm
2. Tolerance is 0.5mm
12 3
3 - □0.65
Terminal No.
Electrical connection diagram
12 3
VOUT
+If
RL = 10kΩ
-If
+VCC
GND
Package & Weight Information
Weight
Pcs/box
Pcs/carton
Pcs/pallet
45g
50
200
4800
很抱歉,暂时无法提供与“L01Z400S05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+138.028751+17.83775
- 5+125.527235+16.22215
- 10+120.8732910+15.62071
- 25+115.3067025+14.90133
- 50+111.4982250+14.40915
- 200+104.80233200+13.54383
- 600+100.25762600+12.95651
