Issued by Module Components Div, TAMURA CORPORATION
Hall Effect Current Sensors S23P***D15 Series
Features:
Advantage:
Closed Loop type
Current or voltage output
Conversion ratio KN = 1:2000
Printed circuit board mounting
Integrated primary
Insulated plastic case according to
UL94V0
UL Recognition
Specifications
Parameters
Symbol
Primary nominal current
Excellent accuracy and linearity
Low temperature drift
Wide frequency bandwidth
No insertion loss
High Immunity to external interferences
Optimised response time
Current overload capability
TA=25ºC, VCC=±15V
S23P50/100D15
If
50A
100A
Ifmax
± 110A (at RM≤71Ω)
± 160A (at RM≤25Ω)
Measuring resistance(If = ±ADC at 85°C)
RM
0Ω~217Ω (at VCC = ±12V)
0Ω~327Ω (at VCC = ±15V)
0Ω~57Ω (at VCC = ±12V)
45Ω~114Ω (at VCC = ±15V)
Conversion Ratio
KN
1 : 2000
1 : 2000
IO
25mA
50mA
1
Maximum current (at 85°C)
Rated output current
2
Output current accuracy (at If)
X
IO ±0.25%
Offset current3(at If=0A)
IOf
≤ ±0.15mA
εL
≤ ±0.15% (at If)
VCC
± 12V .. ± 15V ± 5%
Consumption current
ICC
≤ ±16mA (Output current is not included)
Response rime4
tr
≤ 0.5μs (at di/dt = 100A / μs)
TcIo
≤ ±0.01%/ºC
TcIof
≤ ±0.5mA max. (at TA= -25ºC +85ºC)
Hysteresis error
IOH
≤ 0.3mA (at If=0A → If → 0A)
Insulation voltage
Vd
AC5000V, for 1minute (sensing current 0.5mA), Primary Secondary
Insulation resistance
RIS
≥ 500MΩ (at DC500V) Primary Secondary
Secondary coil resistance
RS
115Ω (at TA = 70ºC)
121Ω (at TA = 85ºC)
Ambient operation temperature
TA
–40ºC ~ +85ºC
Ambient storage temperature
TS
–40ºC ~ +90ºC
2
Output linearity (0A~If)
Power supply voltage
Thermal drift of gain
1
5
Thermal drift of offset current
1
At VCC=±15V ,Ifmax Operating Time: ≤ 10 Seconds. Maximum current is restricted by V CC — 2 Without offset current— 3 After removal of core
hysteresis— 4 Time between 90% input current full scale and 90% of sensor output full scale — 5 Without Thermal drift of offset current
Electrical Performances
Frequency characteristic
6
10
8
4
6
2
Output voltage (V)
Attenuation (dB)
Saturation characteristic(RM=100Ω)
-4
-6
4
2
-4
-8
-6
-10
-8
0.1
1
10
Frequency characteristic(kHz)
@ If=3(Arms) RM=100Ω
S23PXXXD15revC, April 2012
100
-10
-200
TA=25ºC Pulsed
-150
-100
-50
100
Input current (A)
Tamura reserve the right to modify its products in order to improve them without prior notice
150
200
Mechanical dimensions
NOTES
1. Unit is mm
2. Tolerance is 0.5mm
0.6
2.54±0.3
1
+1
1.4
12.7 ±0.4
(7.75)
3.5 -0.3
23 ±0.5
Terminal number:
1. –Vcc(-15V)
2. +Vcc(+15V)
3. IOUT
0.7
1.91±0.3
2.54±0.3
2.54±0.3
2.54±0.3
Connection specific
1.The primary connection
6Pins 1.4×1mm
Recommended PCB hole diameter:Φ2mm
11.43±0.3
2.The secondary connection
3Pins 0.7×0.6mm
Recommended PCB hole diameter:Φ1.2mm
15.73 ±0.5
Primary input current (+)
Primary input current (-)
33.3±0.5
Electrical connection diagram
+If
Voltage
output
Current
output
S23PxxxD15
At If = 50A & VCC = ±15VDC
0Ω ≤ RM≤ 327Ω
At If = 100A & VCC = ±15VDC
45Ω ≤ RM ≤ 114Ω
VOUT
-VCC
-If
+VCC
RM
-VCC
+VCC
GND
IOUT
GND
UL Standard
UL 508 , CSA C22.2 No.14 (UL FILE No.E243511)
• For use in Pollution Degree 2 Environment.
• Maximum Surrounding air temperature rating, 85˚C.
CAUTION
Provide two min. 100 by 85 mm, 0.5 mm thick cupper conductor-cum-heat sink as primary conductor of each side
for safe usage. The primary conductor temperature and PCB should not exceed 100˚C.
Package & Weight Information
Weight
Pcs/box
Pcs/carton
Pcs/pallet
26g
100
400
9600
很抱歉,暂时无法提供与“S23P50/100D15”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+117.713411+15.28450
- 5+106.843635+13.87312
- 10+102.8057410+13.34882
- 25+97.9717525+12.72115
- 50+94.6678750+12.29216
- 400+86.30633400+11.20645
- 800+83.96643800+10.90263
