CR4220-10
CR4220-10
    CR
    Module
    Current Sensor 10A 1 Channel Transformer w/Conditioning Bidirectional Modular
CR4220-10 数据手册
Loop-Powered AC Current Transmitter DIN RAIL / PANEL MOUNT, AVERAGE RMS The CR4200 Series, Current Transmitters produce a calibrated 4-20 mADC signal that is proportional to the average RMS input AC current. Designed for multi-point current sensing, these devices provide excellent features in a value package. The output signal is generated from a user supplied 24 VDC power supply within the output current loop. Applications Multi-point current sensing and control panels Remote current sensing Monitor motor faults Monitor heating elements Monitor lighting elements CR4220 Transducers C Features Single Element - .79” Window 0.5 to 50 AAC Input Range Relatively low cost 35mm DIN rail or panel mount High Accuracy Easy wiring Interfaces with most commercially available instrumentation Connection diagram printed on case Regulatory Agencies Recognized to meet UL 61010B-1 Constructed to meet CAN/CSA-C22.2, No. 61010-1-2004 Meets requirement of IEC 61010-1 and BS EN 61010-1 CR4260 Two Element - .26” Window 0.5 to 30 AAC Input Range E199795 All single phase current transducers are available in split core design. Simply put an “S” at the end of the prefix* I.E. CR4220S-10 * Not UL Recognized CR Magnetics has a wide selection of current transformers to extend the range of any part. Contact factory for more information. Add suffix for input range PART NUMBERS CR4220(S) CR4260 - Single element with 4 - 20 mADC output (split core design) Two element with 4 - 20 mADC output* *Two element transducers are only available in ranges of 0.5 to 30 AAC 5 10 15 20 25 30 40 50 - 0- 5 AAC 0-10 AAC 0-15 AAC 0-20 AAC 0-25 AAC 0-30 AAC 0-40 AAC 0-50 AAC Ranges available up to and including 600 AAC The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 36 E-mail: sales@crmagnetics.com Loop-Powered AC Current Transmitter DIN RAIL / PANEL MOUNT, AVERAGE RMS SPECIFICATIONS Basic Accuracy:............................. 0.5% Linearity:........................................ 10% to 100% FS Thermal Drift:................................. 500 PPM/°C Operating Temperature:................. 0°C to +60°C Installation Category:..................... CAT II Vibration Tested To:.......................IEC 60068-2-6,1995 Pollution Degree:........................... 2 Insulation Voltage:......................... 2500 VDC Altitude:......................................... 2000 meter max. Frequency Range:........................ 50Hz - 400 Hz Calibration:.............Average Sensing, RMS Calibrated MTBF:........................... Greater than 100 K HoursCleaning:............. Water-dampened cloth Output Load:.................. 0 to 300 Ω Response Time:............. 250 ms max., 0-90%FS Relative Humidity:.......... 5% to 95%, Non-Condensing Supply Power:................ Loop Voltage 24 Vdc Compliance Voltage:...... 16 to 28 Vdc Torque Specs.:................ 3.0 inch lbs. (0.4Nm) Weight:............................ 0.5 lbs. C [26.6] 1.05 DIN RAIL MOUNTING CLIP [73.1][83.3] 2.88 3.28 1 2 3 4 OUTPUT 1 9 8 7 6 5 3 4 - + - + 1 2 Vdc + 9 8 7 6 5 L1 + OUTPUT 2 Vdc - + OUTPUT 1 + Vdc - - L2 [28.3] 1.12 [3.3] .13 Top View Optional Mounting [36.6] 1.44 End View CR4220 One Element - 4 - 20 mADC Output CR4260 Two Element 4 - 20 mADC Output [20.1] .79 [41.8] 1.65 [76.6] 3.02 [50.7] 2.00 [5.6] .22 TYP - + 1 2 3 4 OUTPUT 1 9 8 7 6 5 + Vdc - + 1 2 3 4 9 8 7 6 5 + + + OUTPUT 2 OUTPUT 1 - Vdc [88.7] 3.49 CR4220 [6.6] .26 Transducers [25] .98 [35] 1.38 [13.5] .53 CR4260 Two Element with external current transformer * CR4220 One Element with external current transformer * [64] [76.7] 2.52 3.02 [5.6] .22 TYP *Request CR Magnetics Low & Medium Voltage Current Transformers Catalog. CR4260 OUTLINE DRAWING CONNECTION DIAGRAM NOTE: The building installation must have a switch or circuit-breaker that is in close proximity and within easy reach of the operator. The switch or circuit breaker shall be marked as the disconnecting device for the equipment. The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 37 E-mail: sales@crmagnetics.com -
CR4220-10 价格&库存
很抱歉,暂时无法提供与“CR4220-10”相匹配的价格&库存,您可以联系我们找货
