S27S300D15YM
S27S300D15YM
    TAMURA
    Module
    Current Sensor 300A 1 Channel Hall Effect, Closed Loop Bidirectional Module
S27S300D15YM 数据手册
Hall Effect Current Sensor S27S300D15YM Features:       Specifications Advantages:  Current or voltage output  Conversion ratio K = 1:2000  Panel mounting with Molex connector  Large aperture  Insulated plastic case according to  UL94V0  Closed Loop type Excellent accuracy and linearity Low temperature drift Wide frequency bandwidth No insertion loss High Immunity to external interferences Optimised response time Current overload capability TA=25ºC, VCC=±15V Parameters Symbol Rated Current If 300A Ifmax ± 500A (@ RM ≤ 5Ω) Maximum Current1 S27S300D15YM 300A 500A 300A 500A 300A 500A ±12V If = ± ADC Measuring resistance @ 85°C RM ±15V ±20V : : : : : : 0Ω ~ 39Ω 0Ω ~ 12Ω 0Ω ~ 58Ω 0Ω ~ 22Ω 15Ω ~ 93Ω 15Ω ~ 45Ω K 1 : 2000 Output Current IOUT ± 150mA Offset Current IOE ≤ ± 0.2mA @ If = 0A Output Current Accuracy X IOUT ± 0.4% (w/o Iof) Conversion Ratio Output Linearity εL ± 0.1% @ If Supply Voltage2 VCC ± 12V ~ ± 20V (± 5%) Consumption Current ICC ± 20mA (Output Current is not included) tr < 1.0μs @ di/dt = 100A / μs Output Temperature Characteristic TCIOUT ≤ ± 0.01 % / ºC @ If Offset Temperature Characteristic TCIOE ≤ ± 0.5mA max. @ If = 0A (-40ºC ~ +85ºC) Response Time 3 Hysteresis allowance IOH ≤ 0.08mA (0A  3 x If) Insulation Withstanding Vd AC 4000V, for 1minute (sensing current 0.5mA), inside of aperture  terminals Insulation Resistance RIS > 500MΩ (@ DC 500V) inside of aperture  terminals Frequency Bandwidth f DC .. 100 kHz Secondary Coil Resistance RS 25Ω @ TA = 70ºC 28Ω @ TA = 85ºC Operating Temperature TA – 40ºC ~ +85ºC Storage Temperature TS – 40ºC ~ +90ºC 1 @ VCC=±15V for 10 Seconds — 2 Rated Current is restricted by VCC — 3 Time between 10% input current full scale and 90% of sensor output full scale — < ± 0.3mA max. @ If = 0A (-10ºC ~ +70ºC) Electrical Performance data not yet available Hall Effect Current Sensor S27S300D15YM Mechanical dimensions in mm 68 60 If LABEL Molex 6410-03/A 2-Ø4.3 Ø54 4-(4.3x5.3) Ø20.1 29.5 44 3 2 1 56.5 3 2 1 46 20 Terminal function: 1. +VCC 2. OUTPUT 3. –VCC 21.85 44 46 Electrical connection diagram Voltage output RM Current output -VCC +VCC -VCC -If +If 3 2 1 +VCC VOUT IOUT GND GND Package & Weight Information Weight Pcs/box Pcs/carton Pcs/pallet 3 2 1 -If +If
S27S300D15YM 价格&库存
很抱歉,暂时无法提供与“S27S300D15YM”相匹配的价格&库存,您可以联系我们找货
