Issued by Module Components Div, TAMURA CORPORATION
Hall Effect Current Sensors L07P***D15 Series
Features:
Advantage:
Open Loop type
Dual integrated primary
Bipolar power supply
Printed circuit board mounting
Insulated plastic case according
to UL94V0
UL Recognition
Excellent accuracy and linearity
Wide nominal current range
Low temperature drift
Wide frequency bandwidth
No insertion loss
High Immunity To External Interference
Optimised response time
Current overload capability
Specifications
TA=25ºC, VCC=±15V, RL=10kΩ
Parameters
Symbol L07P003D15 L07P005D15 L07P010D15 L07P015D15 L07P020D15 L07P025D15 L07P030D15
3A
If
Primary nominal current
5A
10A
15A
20A
25A
30A
Ifmax
≥ ± If x 3
Rated output voltage
Vo
4V ±0.060V (at If)
Offset voltage1
Vof
≤ ±0.060V (at If = 0A)
Output linearity2(0A~If)
εL
≤ ±1% (at If)
Power supply voltage
VCC
±15V±5%
Consumption current
IC
≤ ±30mA
Response time3
tr
≤ 5μs (at di/dt = If / µs)
Thermal drift of gain4
TcVo
≤ ±0.1% / ºC
Thermal drift of offset
TcVof
≤ ±2.5mV / ºC
VOH
≤ 30mV (at If = 0A→If →0A)
Insulation voltage
Vd
AC2000V for 1minute (sensing current 0.5mA), primary secondary
Insulation resistance
RIS
≥ 500MΩ(at DC500V), primary secondary
TA
-30ºC~+80ºC
Saturation current
Hysteresis error
Ambient operation temperature
Ambient storage temperature
-40ºC~+85ºC
TS
1
2
3
After removal of core hysteresis— Without offset — Time between 10% input current full scale and 90% of sensor output full scale. each channel's value,non-measured circuit is set to 0A. — 4 Without Thermal drift of offset
Electrical Performances
Saturation characteristic
Frequency characteristic(L07P010D15)
15
6
10
2
Output voltage (V)
Attenuation (dB)
4
-4
-6
5
L07P003D15
L07P015D15
-5
L07P025D15
-8
-10
TA=25ºC Pulsed
-10
0.1
1
10
Frequency characteristic(kHz)
@ If=3Arms
L07PXXXD15revC, March 2012
100
-15
-100
-80
-60
-40
-20
Input current (A)
Tamura reserve the right to modify its products in order to improve them without prior notice
40
60
80
100
Mechanical dimensions
Terminal
Function
1
+VCC(+15V)
2
-VCC(-15V)
3
VOUT1
4
VOUT2
5
GND
6
Primary input
current1 (+)
7
Primary input
current1 (-)
8
Primary input
current2 (+)
9
Primary input
current2 (-)
4±1
11.2
12
NOTES
1. Unit is mm
2. Tolerance is 0.5mm
25
φD
φ0.6
φ0.8
φ1.4
φ1.6
3.6
7.2
UL 508 , CSA C22.2 No.14
(UL FILE No.E243511)
54321
VOUT1
VOUT2
• For use in Pollution Degree 2 Environment.
• Maximum Surrounding air temperature rating, 80˚C.
8
+If2
+VCC
-VCC
5 rectangular pins
0.25x0.5
UL Standard
6
7
-If1
6
5 4 3 2 1
Electrical connection diagram
+If1
7
1.5
A
3A
5A
10~15A
20~30A
8
4.75
16
9
9.4
11.2
4.75
RL = 10kΩ
9
-If2
GND
Package & Weight Information
Weight
Pcs/box
Pcs/carton
Pcs/pallet
12g
100
400
12800
很抱歉,暂时无法提供与“L07P025D15”相匹配的价格&库存,您可以联系我们找货
